With the 6.0.11 kernel I again get the message on boot:
[FAILED] Failed to start **Load Kernel Modules**.
The same problem as with the previous two updates:
As before I have reverted to the 5.19 kernel and all is fine.
Is there anything I might need to change|add|remove anywhere to fix this problem or should I just remain patient that a future kernel update may fix the problem?
To me, it looks like the kernel version you try and get that error from is MIA. How or why I can’t tell. I’d recommend you boot into the still working one and reinstall the pro0bleematic one, version 6 if I remember correctly:
After my post there was an update to linux60-nvidia-390xx 390.157-2, as mentioned here:
I installed the update and my desktop system was able to boot to a graphical environment with the 6.0.xx kernel, thus apparently fixing the Failed to start **Load Kernel Modules** problem.
