English output in CLI
While I like to learn different languages I find it sometimes hard to follow the outputs that people post to get help with a problem
Lots of “Hola Amigos” “Guten Tag und auf Wienerschnitzel” "Mesdames et Messieurs " and “#¤!+” .
It makes it harder to help, and since I did not find anything on it I thought a one line tutorial is in order.
Prefix your command with:
LC_ALL=C
Example:
You need help and want to post the output of sudo pacman -Syu:
LC_ALL=C sudo pacman -Syu
This will make the output in english:
~/ LC_ALL=C sudo pacman -Syu
core is up to date 0.0 B 0.00B/s 00:00 [c o o o o o o o o ] 0%
extra is up to date 0.0 B 0.00B/s 00:00 [c o o o o o o o o ] 0%
community is up to date 0.0 B 0.00B/s 00:00 [c o o o o o o o o ] 0%
multilib is up to date 0.0 B 0.00B/s 00:00 [c o o o o o o o o ] 0%
:: Starting full system upgrade…
warning: dkms: local (2.2.0.3+git151023-5) is newer than extra (2.2.0.3-16)
warning: ufw-extras: local (0.3.0.g2d8cf5b-1) is newer than community (0.3-1)
there is nothing to do
That may be easier to understand than:
~/ sudo pacman -Syu
:: Synkroniserer pakkedatabaser…
core er oppdatert 0,0 B 0,00B/s 00:00 [c o o o o o o o o o o o o o o o o o o o o o o ] 0%
extra er oppdatert 0,0 B 0,00B/s 00:00 [c o o o o o o o o o o o o o o o o o o o o o o ] 0%
community er oppdatert 0,0 B 0,00B/s 00:00 [c o o o o o o o o o o o o o o o o o o o o o o ] 0%
multilib er oppdatert 0,0 B 0,00B/s 00:00 [c o o o o o o o o o o o o o o o o o o o o o o ] 0%
:: Starter full systemoppgradering…
advarsel: dkms: lokal (2.2.0.3+git151023-5) er nyere enn extra (2.2.0.3-16)
advarsel: ufw-extras: lokal (0.3.0.g2d8cf5b-1) er nyere enn community (0.3-1)
det er ingenting igjen å gjøre
If you need to post an image of a program then you can start it from your terminal and put LC_ALL=C in front of the command - Like this:
LC_ALL=C octopi
This will start Octopi with english output.
LC_ALL=C pamac-manager
will start Pamac with english output.
If this will mess up your your locale settings?
No - it won’t - so just start using it!
It is as easy as that!
Nice one. So what does the =C stand for, since it turns it into english? Central?
C Defaults to english.
Since english it the one language we all have on our boxes it is a default and the only one that will work all over.
Since I don’t have spanish installed LC_ALL=es_ES will not work here so that too will become the default english.
I am not sure what it precisely stands for but I’ll take Central :slight_smile:
LC_ALL is the environment variable that overrides the other localisation settings
Ah, so the C is actually just something that is not a locale option, so it will default to english.
Just tested with LC_ALL=B and it also defaults back to english. :slight_smile:
Nice find indeed.
I think Cancel your locale settings for this command, sounds good.
And you can always use
LANG=en_US.UTF-8 some-command
