The default encrypted installation does not provide a separate home partition.
I’ll like to have encrypted installation with a separate home partition.
What partitioning scheme should I use? Please let me know the size and flags and any other important details.
Isn’t there the option to do encryption as well as LVM?
That way you can have your separate /home partition.
edit:
just tried in a VM with my not current manjaro-xfce iso from january this year
and it seems that this is not possible with the standard Manjaro installer
