Hello Everyone,
I have a Dell XPS 9350 laptop that I use a USB-C adapter to connect to an external display (Dell U2717D) with my setup. The monitor is detected and everything works correctly, my issue is as follows:
Problem:
When connecting the USB-C cable to my external Dell monitor, the resolution on my laptop’s screen changes. Everything becomes super small in terms of fonts and resolution and I am no longer able to use the laptop screen as a secondary display. I have the scaling set to 200% on my laptop’s internal display, and 100% set on the External Dell Monitor.
When I unplug the USB-C, everything resets correctly on my laptop screen and I am able to use it without any issues.
I am attaching my system information below:
sudo inxi --admin --verbosity=7 --filter --no-host --width ✔
Kernel: 5.18.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=501de8bc-72f3-4eb8-8dd8-eb0381f16ebc ro
resume=UUID=2314cba6-fa6e-443b-8fc2-de4d6ad99ffe apparmor=1
Console: pty pts/0 wm: gnome-shell DM: GDM v: 42.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Dell product: XPS 13 9350 v: N/A serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 076F9T v: A00 serial: <filter> UEFI: Dell v: 1.13.0
date: 02/10/2020
ID-1: BAT0 charge: 53.2 Wh (100.0%) condition: 53.2/57.5 Wh (92.5%)
volts: 8.7 min: 7.6 model: SMP DELL JHXPY53 type: Li-poly serial: <filter>
status: full
Device-1: hid-dc:2c:26:27:0b:49-battery model: Keychron K3 serial: N/A
charge: N/A status: discharging
RAM: total: 7.63 GiB used: 4.07 GiB (53.3%)
Array-1: capacity: 16 GiB slots: 2 EC: None max-module-size: 8 GiB
note: est.
Device-1: System Board Memory type: LPDDR3 detail: synchronous size: 4 GiB
speed: 1867 MT/s volts: curr: 1.2 width (bits): data: 64 total: 64
manufacturer: SK Hynix part-no: H9CCNNNBJTMLAR-NUD serial: <filter>
Device-2: System Board Memory type: LPDDR3 detail: synchronous size: 4 GiB
Info: model: Intel Core i5-6200U socket: U3E1 bits: 64 type: MT MCP
arch: Skylake gen: core 6 built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2761 high: 2787 min/max: 400/2800 base/boost: 2300/2300
scaling: driver: intel_pstate governor: powersave volts: 0.9 V
ext-clock: 100 MHz cores: 1: 2772 2: 2736 3: 2787 4: 2749 bogomips: 19204
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel arch: Gen9 process: Intel 14n built: 2015-16 ports:
active: DP-1,eDP-1 empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Device-2: Microdia Integrated Webcam HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0c45:670c class-ID: 0e02
Device-3: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-1.4:5 chip-ID: 046d:085c
class-ID: 0102 serial: <filter>
Display: server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
compositor: gnome-shell driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1800 s-size: <missing: xdpyinfo>
Monitor-1: DP-1 mapped: XWAYLAND0 pos: primary,left model: Dell U2717D
serial: <filter> built: 2017 res: 3200x1800 hz: 60 dpi: 280 gamma: 1.2
size: 290x170mm (11.42x6.69") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
Monitor-2: eDP-1 mapped: XWAYLAND3 pos: primary,right model: Sharp 0x144a
built: 2015 res: 2560x1440 hz: 60 dpi: 108 gamma: 1.2
size: 600x340mm (23.62x13.39") diag: 337mm (13.3") ratio: 16:9
modes: 3200x1800
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
bus-ID: 3-1.4:5 v: kernel chip-ID: 046d:085c alternate: snd_soc_skl
class-ID: 0102 bus-ID: 00:1f.3 chip-ID: 8086:9d70 serial: <filter>
class-ID: 0403
Device-2: Logitech C922 Pro Stream Webcam type: USB
Sound Server-1: ALSA v: k5.18.5-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.0 running: no
Sound Server-3: PipeWire v: 0.3.52 running: yes
Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 3a:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF: wlp58s0 state: up mac: <filter>
bus-ID: 1-3:2 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 238.47 GiB used: 34.99 GiB (14.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM951 NVMe 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: BXV77D0Q temp: 39.9 C scheme: GPT
ID-1: / raw-size: 72 GiB size: 70.32 GiB (97.67%) used: 23.34 GiB (33.2%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 501de8bc-72f3-4eb8-8dd8-eb0381f16ebc
used: 26.6 MiB (27.7%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: 7294-110C
ID-3: /home raw-size: 80 GiB size: 78.19 GiB (97.74%)
used: 11.14 GiB (14.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5 label: N/A uuid: 82acc9d6-e635-41ea-86f7-b8d09946a03e
Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
ID-1: swap-1 type: partition size: 10.84 GiB used: 489.1 MiB (4.4%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 2314cba6-fa6e-443b-8fc2-de4d6ad99ffe
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 499 MiB fs: ntfs label: N/A
uuid: 4CB29579B295686A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 75.04 GiB fs: ntfs label: DRIVE
uuid: 022401A424019C33
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-5:3 info: Microdia Integrated Webcam HD type: Video
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 3-1:2 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Device-1: 3-1.1:3 info: VIA Labs USB 2.0 BILLBOARD type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s chip-ID: 2109:0103
class-ID: 1100 serial: <filter>
Device-2: 3-1.2:4
info: SHARKOON GmbH 2.4GHz Wireless rechargeable vertical mouse [More&Better]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-3: 3-1.4:5 info: Logitech C922 Pro Stream Webcam type: Video,Audio
power: 500mA chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Device-4: 3-1.5:6 info: VIA Labs USB Billboard Device type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 2109:8817 class-ID: 1100 serial: <filter>
Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-6: 4-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Device-1: 4-1.3:3 info: Alcor Micro Mass Storage Device type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
chip-ID: 058f:8468 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 42.0 C pch: 37.5 C mobo: 39.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 278 Uptime: 7h 25m wakeups: 70 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: pacman: 1539 lib: 459 flatpak: 0 Shell: Zsh (sudo) v: 5.9
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.19
If anyone could offer any assistance on how to manage an external display + internal laptop display correctly, it would be greatly appreciated.
Thanks,
Asif
