For some reason netflix keeps lagging and stuttering. I have a fresh install of manjaro with the nvidia proprietary driver installed. Also mozzila feels a bit laggy.
**System:**
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=08c4897b-412a-4722-a3ea-7f2a73382988 ro quiet apparmor=1
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
**Machine:**
Type: Desktop System: Gigabyte product: Z390 AORUS MASTER v: N/A
serial: <filter>
Mobo: Gigabyte model: Z390 AORUS MASTER-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F10b date: 08/07/2019
**CPU:**
Info: 8-Core model: Intel Core i9-9900K bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: C (12)
microcode: DE L2 cache: 16 MiB
bogomips: 115232
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
**Graphics:**
Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] driver: nvidia v: 460.32.03
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1e81
Display: x11 server: X. Org 1.20.10 compositor: kwin_x11 driver:
loaded: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 162 s-size: 602x341mm (23.7x13.4")
s-diag: 692mm (27.2")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 163
size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
OpenGL: renderer: GeForce RTX 2080 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 460.32.03
direct render: Yes
**Audio:**
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Device-2: NVIDIA TU104 HD Audio driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:10f8
Device-3: Trust Full HD Webcam type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-11.2:6 chip ID: 145f:02aa serial: <filter>
Sound Server: ALSA v: k5.9.16-1-MANJARO
**Network:**
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
bus ID: 00:14.3 chip ID: 8086:a370
IF: wlo1 state: down mac: <filter>
Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: efa0 bus ID: 00:1f.6 chip ID: 8086:15bc
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
**Drives:**
Local Storage: total: 1.82 TiB used: 14.72 GiB (0.8%)
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B2QEXM7
temp: 40.9 C
**Partition:**
ID-1: / raw size: 301.29 GiB size: 295.56 GiB (98.10%)
used: 14.69 GiB (5.0%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw size: 99 MiB size: 95 MiB (95.96%)
used: 31.7 MiB (33.4%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
**Swap:**
**Sensors:**
System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 41%
**Info:**
Processes: 330 Uptime: 41m wakeups: 1 Memory: 15.57 GiB
used: 4.44 GiB (28.6%) Init: systemd v: 247 Compilers: gcc: N/A
Packages: 1268 pacman: 1258 lib: 400 flatpak: 0 snap: 10 Shell: Bash
v: 5.1.0 running in: konsole inxi: 3.2.02
