Enabling Mouse Scroll Options in KDE
Hey!
I read this thread about unlocking more options to configure the mouse on manjaro. I want to the change the scroll speed of my usb mouse.
The problem is, that when I copy the file into the X11-conf folder, my touchpad isn't working anymore (same problem like op in the thread). I get the full settings for my usb mouse, but I'm losing my touchpad. Is there a quick fix to that?
I guess you need to specify the device using the MatchIs$Device options
It is ideas only - please verify
Section "InputClass"
    MatchIsMouse "on"
    MatchIsTouchpad "off"
EndSection
Well, it broke my system. I couldn't boot to kde. Had to revert it.
As I said - please verify - and I don't think both should be used - only one :slight_smile:
A good source is https://wiki.archlinux.org/index.php/Xorg
Undo the modifications you made, remove the /etc/X11/xorg.conf.d/11-evdev.conf if you created one
sudo rm -r /etc/X11/xorg.conf.d/11-evdev.conf
and first try only with this with no other edits:
sudo ln -s /usr/share/X11/xorg.conf.d/10-evdev.conf /etc/X11/xorg.conf.d/10-evdev.conf
Did that. I can't use my touchpad, but I get all the settings for my usb mouse.
if you remove the mouse from the USB port, does the touchpad and the settings for it works ?
No, the touchpad won't work, even if I reboot without the usb mouse.
Some systems has settings that enables/disables devices when connected.
Does KDE have an option for disabling touchpad when a mouse is attached? It could be such setting - but I don't know - not a KDE user.
Yes, it has that option, but sadly the Mouse advanced options will not be enabled without what i mentioned in that post
Both use libinput but KCM_Mouse is failing to simple settings without that file.
KDE has such an option, but it's not activated.
And I can't even select that option now, because it can't find my touchpad.
What suprisingly does work is the simple tab on the touchpad. It recognizes it as a left mouse click.
remove the file /etc/X11/xorg.conf.d/10-evdev.conf reboot so the touchpad is detected and disable the option that the touchpad is disabled when the mouse is connected, add again the file to get the mouse options to advanced ... I hope you get my idea.
Yeah I got it, but as you can see in my screenshot the option is not selected. So it won't disable my touchpad when I connect the usb mouse.
(The option in german says: Touchpad abschalten, wenn eine Maus angeschlossen ist == Disable Touchpad, when a mouse is connected)
can i see the
cat /usr/share/X11/xorg.conf.d/30-touchpad.conf
I don't have such a file.
All I got in /usr/share/X11/xorg.conf.d/ is:
10-amdgpu.conf  10-evdev.conf  10-nvidia-drm-outputclass.conf  10-quirks.conf  10-radeon.conf  40-libinput.conf
lets go back a bit
xinput --list
and i will think about something
If the touchpad is not shown, then better remove again the /etc/X11/xorg.conf.d/10-evdev.conf so we have the entire list even if the mouse will not have the advanced options.
I removed /etc/X11/xorg.conf.d/10-evdev.conf and this is my output from xinput:
[alex@lightning ~]$ xinput --list
⎡ Virtual core pointer                          id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ GAMEING Rapoo Gaming Device Mouse         id=12   [slave  pointer  (2)]
⎜   ↳ GAMEING Rapoo Gaming Device Consumer Control      id=15   [slave  pointer  (2)]
⎜   ↳ USB OPTICAL MOUSE                         id=16   [slave  pointer  (2)]
⎜   ↳ DELL0825:00 06CB:7E92 Touchpad            id=17   [slave  pointer  (2)]
⎜   ↳ SynPS/2 Synaptics TouchPad                id=22   [slave  pointer  (2)]
⎣ Virtual core keyboard                         id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ Power Button                              id=6    [slave  keyboard (3)]
    ↳ Video Bus                                 id=7    [slave  keyboard (3)]
    ↳ Video Bus                                 id=8    [slave  keyboard (3)]
    ↳ Power Button                              id=9    [slave  keyboard (3)]
    ↳ Sleep Button                              id=10   [slave  keyboard (3)]
    ↳ GAMEING Rapoo Gaming Device               id=11   [slave  keyboard (3)]
    ↳ GAMEING Rapoo Gaming Device Keyboard      id=13   [slave  keyboard (3)]
    ↳ GAMEING Rapoo Gaming Device System Control        id=14   [slave  keyboard (3)]
    ↳ Intel HID events                          id=18   [slave  keyboard (3)]
    ↳ Intel HID 5 button array                  id=19   [slave  keyboard (3)]
    ↳ Dell WMI hotkeys                          id=20   [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=21   [slave  keyboard (3)]
    ↳ GAMEING Rapoo Gaming Device Consumer Control      id=23   [slave  keyboard (3)]
This will be a bit tricky as your xinput sees 2 touchpads
Add the following lines to /usr/share/X11/xorg.conf.d/40-libinput.conf
    Option "Tapping" "True"
    Option "TapingDrag" "True"
    Option "DisableWhileTyping" "True"
    Option "AccelProfile" "adaptive"
    Option "AccelSpeed" "0.4"
    Option "SendEventsMode" "disabled-on-external-mouse"
and remove any traces of synaptic.conf file from /etc/X11/xorg.conf.d/ or elsewhere
You can then create the 30-touchpad.conf in /usr/share/X11/xorg.conf.d/ with this lines:
    Identifier "libinput touchpad catchall"
    MatchIsTouchpad "on"
    MatchDriver "libinput"
    Option "Tapping" "on"
    Option "ScrollMethod" "edge"
    Option "TappingDrag" "on"
    Option "TappingDragLock" "on"
    Option "NaturalScrolling" "off"
    MatchDevicePath "/dev/input/event*"
EndSection
and eventually try again the 11-evdev.conf mentioned initially ...
Where should I add the lines to the files?
I've got 5 sections, I'm unsure where to add the lines.
        Identifier "libinput pointer catchall"
        MatchIsPointer "on"
        Driver "libinput"
EndSection
        Identifier "libinput keyboard catchall"
        MatchIsKeyboard "on"
        Driver "libinput"
EndSection
        Driver "libinput"
EndSection
        Identifier "libinput touchscreen catchall"
        MatchIsTouchscreen "on"
        Driver "libinput"
EndSection
        Identifier "libinput tablet catchall"
        MatchIsTablet "on"
        Driver "libinput"
EndSection
To were it mentions
right under
Driver "libinput"
The thing is, i always had second thought about editing those files, so make sure you revert if is not helping. Try first only with the 30-touchpad.conf + 11-evdev.conf from before.
