Enable scroll lock on Wayland
Hi, after update to Plasma 6 and start using Wayland Sroll Lock key is doing nothing. Is any way to enable it like in X11?
Go to System SettingsKeyboard → and then the Hardware (tab)… There you will see the option to Turn on the NumLock on Plasma startup.
The Scroll Lock, however, doesn’t seem to have a software control; at least none that I can find. How was it enabled in X11?
Here is a somewhat dated post which might be of some use.
It looks like you had basically the question once before (in 2023):
Did you find anything useful back then?
Cheers.
I’ve found how to enable in X11, but it’s applicable Wayland :frowning:
