Yesterday I turned on my computer and the audio on the left side stopped working and started to have some crackles in the audio, in an attempt to solve the problem I thought it would be an excellent idea to uninstall and reinstall pulseaudio, I did it with pamac, after that I restarted my computer and it continued the same thing, but I noticed that the volume icon in the taskbar on the left side disappeared, I tried to open the audio settings through the system settings and it was not there and it continued to work only on the right side with crackles until it just stopped to work once and for all, and now the problem that was crackling and lack of sound on the left side turned into total loss of sound.
Inxi Information
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b1f38e37-58c8-41be-94c6-f4061cd43bbb rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: B250M-D3H v: N/A serial: <filter>
Mobo: Gigabyte model: B250M-D3H-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F2 date: 11/25/2016
RAM: total: 15.59 GiB used: 3.45 GiB (22.1%)
Info: Quad Core model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 9E (158) stepping: 9 microcode: EA cache: L2: 6 MiB
bogomips: 24008
Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 900 3: 900
4: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: ASUSTeK
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:21c4 class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 95 s-size: 513x292mm (20.2x11.5")
s-diag: 590mm (23.2")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 96 size: 509x286mm (20.0x11.3")
diag: 584mm (23")
OpenGL: renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.48 TiB used: 22.95 GiB (1.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000VM002-1CT162
type: HDD rpm: 5900 serial: <filter> rev: SC23 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SUV400S37120G
size: 111.79 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 87RA scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST500DM002-1BD142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: KC65 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Cruzer Blade
size: 7.45 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.26 scheme: MBR
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 22.95 GiB (5.0%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: b1f38e37-58c8-41be-94c6-f4061cd43bbb
used: 292 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: NO_LABEL
uuid: 4C3D-3FEA
ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs label: Novo volume
uuid: ECBE7DB4BE7D77C2
ID-2: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: N/A
uuid: 6418-69ED
ID-3: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdb3 maj-min: 8:19 size: 111.17 GiB fs: ntfs label: N/A
uuid: 04D01CC4D01CBE3C
ID-5: /dev/sdb4 maj-min: 8:20 size: 518 MiB fs: ntfs label: N/A
uuid: 1C54D05F54D03D68
ID-6: /dev/sdd1 maj-min: 8:49 size: 3.24 GiB fs: iso9660
ID-7: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 99C0-51B6
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-3:2 info: SanDisk Cruzer Blade type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5567 class-ID: 0806 serial: <filter>
Device-2: 1-4:3 info: Cooler Master Masterkeys Lite L Combo RGB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 2516:0042 class-ID: 0301
Device-3: 1-5:4 info: Personal Communication Systems SNES Gamepad type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.0 speed: 1.5 Mb/s
power: 500mA chip-ID: 0810:e501 class-ID: 0300
Device-4: 1-6:5 info: Logitech G502 Proteus Spectrum Optical Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
Processes: 200 Uptime: 11m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1263 lib: 335
flatpak: 0 snap: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.08
pulseaudio -v
pulseaudio -v  ✔  8s 
I: [pulseaudio] main.c: setrlimit(RLIMIT_NICE, (31, 31)) failed: Operation not permitted
I: [pulseaudio] main.c: setrlimit(RLIMIT_RTPRIO, (9, 9)) failed: Operation not permitted
I: [pulseaudio] core-util.c: Successfully gained nice level -11.
I: [pulseaudio] main.c: This is PulseAudio 15.0
I: [pulseaudio] main.c: Page size is 4096 bytes
I: [pulseaudio] main.c: Machine ID is 4035fd1802204a3f935b61a309a24bc9.
I: [pulseaudio] main.c: Session ID is 2.
I: [pulseaudio] main.c: Using runtime directory /run/user/1000/pulse.
I: [pulseaudio] main.c: Using state directory /home/renatin/.config/pulse.
I: [pulseaudio] main.c: Using modules directory /usr/lib/pulse-15.0/modules.
I: [pulseaudio] main.c: Running in system mode: no
I: [pulseaudio] main.c: System supports high resolution timers
I: [pulseaudio] cpu-x86.c: CPU flags: CMOV MMX SSE SSE2 SSE3 SSSE3 SSE4_1 SSE4_2
I: [pulseaudio] svolume_mmx.c: Initialising MMX optimized volume functions.
I: [pulseaudio] remap_mmx.c: Initialising MMX optimized remappers.
I: [pulseaudio] svolume_sse.c: Initialising SSE2 optimized volume functions.
I: [pulseaudio] remap_sse.c: Initialising SSE2 optimized remappers.
I: [pulseaudio] sconv_sse.c: Initialising SSE2 optimized conversions.
I: [pulseaudio] svolume_orc.c: Initialising ORC optimized volume functions.
I: [pulseaudio] database.c: Successfully opened 'device-volumes' database file '/home/renatin/.config/pulse/4035fd1802204a3f935b61a309a24bc9-device-volumes.tdb'.
I: [pulseaudio] module.c: Loaded "module-device-restore" (index: #0; argument: "").
I: [pulseaudio] database.c: Successfully opened 'stream-volumes' database file '/home/renatin/.config/pulse/4035fd1802204a3f935b61a309a24bc9-stream-volumes.tdb'.
I: [pulseaudio] module.c: Loaded "module-stream-restore" (index: #1; argument: "").
I: [pulseaudio] database.c: Successfully opened 'card-database' database file '/home/renatin/.config/pulse/4035fd1802204a3f935b61a309a24bc9-card-database.tdb'.
I: [pulseaudio] module.c: Loaded "module-card-restore" (index: #2; argument: "").
I: [pulseaudio] module.c: Loaded "module-augment-properties" (index: #3; argument: "").
I: [pulseaudio] module.c: Loaded "module-switch-on-port-available" (index: #4; argument: "").
I: [pulseaudio] (alsa-lib)parser.c: UCM is not supported for this HDA model (HDA NVidia at 0xf7080000 irq 17)
I: [pulseaudio] (alsa-lib)main.c: error: failed to import hw:1 use case configuration -6
I: [pulseaudio] (alsa-lib)main.c: error: failed to import HDA NVidia use case configuration -6
I: [pulseaudio] alsa-ucm.c: UCM not available for card HDA NVidia
I: [pulseaudio] alsa-util.c: Error opening PCM device front:1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device iec958:1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround21:1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround40:1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround41:1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround50:1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround51:1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device surround71:1: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM a52:1
I: [pulseaudio] alsa-util.c: Error opening PCM device a52:1: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dca:1
I: [pulseaudio] alsa-util.c: Error opening PCM device dca:1: No such file or directory
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-0.conf
I: [pulseaudio] alsa-util.c: Successfully attached to mixer 'hw:1'
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1: No such file or directory
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-1.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,1
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,1: No such file or directory
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-2.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,2
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,2: No such file or directory
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-3.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,3
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,3: No such file or directory
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-4.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,4
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,4: No such file or directory
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/hdmi-output-5.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,5
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,5: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,6: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,6
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,6: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,7: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,7
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,7: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,8: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,8
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,8: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,9: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,9
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,9: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:1,10: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:1,10
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:1,10: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hw:1: No such file or directory
I: [pulseaudio] module-card-restore.c: Restoring port latency offsets for card alsa_card.pci-0000_01_00.1.
I: [pulseaudio] card.c: alsa_card.pci-0000_01_00.1: active_profile: off
I: [pulseaudio] module-card-restore.c: Profile '' was previously automatically selected for card alsa_card.pci-0000_01_00.1.
I: [pulseaudio] card.c: Created 0 "alsa_card.pci-0000_01_00.1"
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-0 (3).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-1 (7).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-2 (8).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-3 (9).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-4 (10).
I: [pulseaudio] module-alsa-card.c: ELD device found for port hdmi-output-5 (11).
I: [pulseaudio] module.c: Loaded "module-alsa-card" (index: #6; argument: "device_id="1" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"").
I: [pulseaudio] module-udev-detect.c: Card /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1 (alsa_card.pci-0000_01_00.1) module loaded.
I: [pulseaudio] (alsa-lib)parser.c: UCM is not supported for this HDA model (HDA Intel PCH at 0xf7140000 irq 133)
I: [pulseaudio] (alsa-lib)main.c: error: failed to import hw:0 use case configuration -6
I: [pulseaudio] (alsa-lib)main.c: error: failed to import HDA Intel PCH use case configuration -6
I: [pulseaudio] alsa-ucm.c: UCM not available for card HDA Intel PCH
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-front-mic.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-rear-mic.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-internal-mic.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-dock-mic.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-linein.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-aux.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-video.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-tvtuner.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-fm.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-mic-line.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-headphone-mic.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-input-headset-mic.conf
I: [pulseaudio] alsa-util.c: Successfully attached to mixer 'hw:0'
I: [pulseaudio] alsa-util.c: Error opening PCM device iec958:0: No such file or directory
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-output.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-output-lineout.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-output-speaker.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-output-headphones.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/analog-output-headphones-2.conf
I: [pulseaudio] alsa-mixer.c: Loading path config: /usr/share/pulseaudio/alsa-mixer/paths/iec958-stereo-output.conf
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM a52:0
I: [pulseaudio] alsa-util.c: Error opening PCM device a52:0: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dca:0
I: [pulseaudio] alsa-util.c: Error opening PCM device dca:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,1: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,1
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,1: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,2: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,2
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,2: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,3: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,3
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,3: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,4: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,4
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,4: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,5: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,5
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,5: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,6: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,6
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,6: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,7: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,7
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,7: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,8: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,8
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,8: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,9: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,9
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,9: No such file or directory
I: [pulseaudio] alsa-util.c: Error opening PCM device hdmi:0,10: No such file or directory
I: [pulseaudio] (alsa-lib)pcm.c: Unknown PCM dcahdmi:0,10
I: [pulseaudio] alsa-util.c: Error opening PCM device dcahdmi:0,10: No such file or directory
I: [pulseaudio] module-card-restore.c: Restoring port latency offsets for card alsa_card.pci-0000_00_1f.3.
I: [pulseaudio] card.c: alsa_card.pci-0000_00_1f.3: active_profile: output:analog-stereo+input:analog-stereo
I: [pulseaudio] module-card-restore.c: Profile 'input:analog-stereo' was previously automatically selected for card alsa_card.pci-0000_00_1f.3.
I: [pulseaudio] module-card-restore.c: Restoring profile 'input:analog-stereo' for card alsa_card.pci-0000_00_1f.3.
I: [pulseaudio] card.c: Created 1 "alsa_card.pci-0000_00_1f.3"
I: [pulseaudio] alsa-util.c: Trying to disable ALSA period wakeups, using timers only
I: [pulseaudio] alsa-util.c: ALSA period wakeups disabled
I: [pulseaudio] alsa-source.c: Successfully opened device front:0.
I: [pulseaudio] alsa-source.c: Selected mapping 'Analog Stereo' (analog-stereo).
I: [pulseaudio] alsa-source.c: Successfully enabled mmap() mode.
I: [pulseaudio] alsa-source.c: Successfully enabled timer-based scheduling mode.
I: [pulseaudio] module-device-restore.c: Restoring port for source source:alsa_input.pci-0000_00_1f.3.analog-stereo.
I: [pulseaudio] module-device-restore.c: Restoring volume for source alsa_input.pci-0000_00_1f.3.analog-stereo: front-left: 30421 / 46%, front-right: 30421 / 46%
I: [pulseaudio] module-device-restore.c: Restoring mute state for source alsa_input.pci-0000_00_1f.3.analog-stereo: unmuted
I: [pulseaudio] source.c: Created source 0 "alsa_input.pci-0000_00_1f.3.analog-stereo" with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
I: [pulseaudio] source.c: alsa.resolution_bits = "16"
I: [pulseaudio] source.c: device.api = "alsa"
I: [pulseaudio] source.c: device.class = "sound"
I: [pulseaudio] source.c: alsa.class = "generic"
I: [pulseaudio] source.c: alsa.subclass = "generic-mix"
I: [pulseaudio] source.c: alsa.name = "ALC892 Analog"
I: [pulseaudio] source.c: alsa.id = "ALC892 Analog"
I: [pulseaudio] source.c: alsa.subdevice = "0"
I: [pulseaudio] source.c: alsa.subdevice_name = "subdevice #0"
I: [pulseaudio] source.c: alsa.device = "0"
I: [pulseaudio] source.c: alsa.card = "0"
I: [pulseaudio] source.c: alsa.card_name = "HDA Intel PCH"
I: [pulseaudio] source.c: alsa.long_card_name = "HDA Intel PCH at 0xf7140000 irq 133"
I: [pulseaudio] source.c: alsa.driver_name = "snd_hda_intel"
I: [pulseaudio] source.c: device.bus_path = "pci-0000:00:1f.3"
I: [pulseaudio] source.c: sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
I: [pulseaudio] source.c: device.bus = "pci"
I: [pulseaudio] source.c: device.vendor.id = "8086"
I: [pulseaudio] source.c: device.vendor.name = "Intel Corporation"
I: [pulseaudio] source.c: device.product.id = "a2f0"
I: [pulseaudio] source.c: device.product.name = "200 Series PCH HD Audio"
I: [pulseaudio] source.c: device.form_factor = "internal"
I: [pulseaudio] source.c: device.string = "front:0"
I: [pulseaudio] source.c: device.buffering.buffer_size = "352800"
I: [pulseaudio] source.c: device.buffering.fragment_size = "176400"
I: [pulseaudio] source.c: device.access_mode = "mmap+timer"
I: [pulseaudio] source.c: device.profile.name = "analog-stereo"
I: [pulseaudio] source.c: device.profile.description = "Analog Stereo"
I: [pulseaudio] source.c: device.description = "Built-in Audio Analog Stereo"
I: [pulseaudio] source.c: module-udev-detect.discovered = "1"
I: [pulseaudio] source.c: device.icon_name = "audio-card-pci"
I: [pulseaudio] alsa-source.c: Using 2.0 fragments of size 176400 bytes (1000.00ms), buffer size is 352800 bytes (2000.00ms)
I: [pulseaudio] alsa-source.c: Time scheduling watermark is 20.00ms
I: [pulseaudio] alsa-source.c: Successfully enabled deferred volume.
I: [pulseaudio] alsa-source.c: Hardware volume ranges from -16.00 dB to 60.00 dB.
I: [pulseaudio] alsa-source.c: Fixing base volume to -60.00 dB
I: [pulseaudio] alsa-source.c: Using hardware volume control. Hardware dB scale supported.
I: [pulseaudio] alsa-source.c: Using hardware mute control.
I: [alsa-source-ALC892 Analog] util.c: Successfully enabled SCHED_RR scheduling for thread, with priority 5.
I: [alsa-source-ALC892 Analog] alsa-source.c: Starting capture.
I: [pulseaudio] core.c: default_source: (unset) -> alsa_input.pci-0000_00_1f.3.analog-stereo
I: [pulseaudio] module.c: Loaded "module-alsa-card" (index: #7; argument: "device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"").
I: [pulseaudio] module-udev-detect.c: Card /devices/pci0000:00/0000:00:1f.3/sound/card0 (alsa_card.pci-0000_00_1f.3) module loaded.
I: [pulseaudio] module-udev-detect.c: Found 2 cards.
I: [pulseaudio] module.c: Loaded "module-udev-detect" (index: #5; argument: "").
I: [pulseaudio] module.c: Loaded "module-dbus-protocol" (index: #8; argument: "").
I: [pulseaudio] module.c: Loaded "module-native-protocol-unix" (index: #9; argument: "").
W: [pulseaudio] module.c: module-combine is deprecated: Please use module-combine-sink instead of module-combine!
W: [pulseaudio] module-combine.c: We will now load module-combine-sink. Please make sure to remove module-combine from your configuration.
I: [pulseaudio] module-device-restore.c: Restoring volume for sink combined: front-left: 65536 / 100%, front-right: 65536 / 100%
I: [pulseaudio] module-device-restore.c: Restoring mute state for sink combined: unmuted
I: [pulseaudio] sink.c: Created sink 0 "combined" with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
I: [pulseaudio] sink.c: device.class = "filter"
I: [pulseaudio] sink.c: device.description = "Simultaneous Output"
I: [pulseaudio] sink.c: device.icon_name = "audio-card"
I: [pulseaudio] source.c: Created source 1 "combined.monitor" with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
I: [pulseaudio] source.c: device.description = "Monitor of Simultaneous Output"
I: [pulseaudio] source.c: device.class = "monitor"
I: [pulseaudio] source.c: device.icon_name = "audio-input-microphone"
I: [combine] util.c: Successfully enabled SCHED_RR scheduling for thread, with priority 6.
I: [pulseaudio] core.c: default_sink: (unset) -> combined
I: [pulseaudio] module.c: Loaded "module-combine-sink" (index: #12; argument: "").
I: [pulseaudio] module.c: Loaded "module-combine" (index: #11; argument: "").
I: [pulseaudio] module.c: Loaded "module-gsettings" (index: #10; argument: "").
I: [pulseaudio] module-default-device-restore.c: Restoring default sink 'combined'.
I: [pulseaudio] core.c: configured_default_sink: (unset) -> combined
I: [pulseaudio] module-default-device-restore.c: Restoring default source 'noechosource'.
I: [pulseaudio] core.c: configured_default_source: (unset) -> noechosource
I: [pulseaudio] module.c: Loaded "module-default-device-restore" (index: #13; argument: "").
I: [pulseaudio] module.c: Loaded "module-always-sink" (index: #14; argument: "").
I: [pulseaudio] module.c: Loaded "module-intended-roles" (index: #15; argument: "").
I: [pulseaudio] module.c: Loaded "module-suspend-on-idle" (index: #16; argument: "").
I: [pulseaudio] module.c: Loaded "module-console-kit" (index: #17; argument: "").
I: [pulseaudio] client.c: Created 0 "Login Session 2"
I: [pulseaudio] core.c: exit_idle_time: 20 -> 0
I: [pulseaudio] module.c: Loaded "module-systemd-login" (index: #18; argument: "").
I: [pulseaudio] module.c: Loaded "module-position-event-sounds" (index: #19; argument: "").
I: [pulseaudio] module.c: Loaded "module-role-cork" (index: #20; argument: "").
I: [pulseaudio] module.c: Loaded "module-filter-heuristics" (index: #21; argument: "").
I: [pulseaudio] module.c: Loaded "module-filter-apply" (index: #22; argument: "").
W: [pulseaudio] cli-command.c: stat('/etc/pulse/default.pa.d'): No such file or directory
I: [pulseaudio] main.c: Daemon startup complete.
I: [pulseaudio] alsa-sink.c: Successfully opened device front:0.
I: [pulseaudio] alsa-sink.c: Selected mapping 'Analog Stereo' (analog-stereo).
I: [pulseaudio] alsa-sink.c: Successfully enabled mmap() mode.
I: [pulseaudio] alsa-sink.c: Successfully enabled timer-based scheduling mode.
I: [pulseaudio] module-device-restore.c: Restoring port for sink sink:alsa_output.pci-0000_00_1f.3.analog-stereo.
I: [pulseaudio] module-device-restore.c: Restoring volume for sink alsa_output.pci-0000_00_1f.3.analog-stereo: front-left: 26949 / 41%, front-right: 26949 / 41%
I: [pulseaudio] module-device-restore.c: Restoring mute state for sink alsa_output.pci-0000_00_1f.3.analog-stereo: unmuted
I: [pulseaudio] sink.c: Created sink 1 "alsa_output.pci-0000_00_1f.3.analog-stereo" with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
I: [pulseaudio] sink.c: alsa.resolution_bits = "16"
I: [pulseaudio] sink.c: device.api = "alsa"
I: [pulseaudio] sink.c: device.class = "sound"
I: [pulseaudio] sink.c: alsa.class = "generic"
I: [pulseaudio] sink.c: alsa.subclass = "generic-mix"
I: [pulseaudio] sink.c: alsa.name = "ALC892 Analog"
I: [pulseaudio] sink.c: alsa.id = "ALC892 Analog"
I: [pulseaudio] sink.c: alsa.subdevice = "0"
I: [pulseaudio] sink.c: alsa.subdevice_name = "subdevice #0"
I: [pulseaudio] sink.c: alsa.device = "0"
I: [pulseaudio] sink.c: alsa.card = "0"
I: [pulseaudio] sink.c: alsa.card_name = "HDA Intel PCH"
I: [pulseaudio] sink.c: alsa.long_card_name = "HDA Intel PCH at 0xf7140000 irq 133"
I: [pulseaudio] sink.c: alsa.driver_name = "snd_hda_intel"
I: [pulseaudio] sink.c: device.bus_path = "pci-0000:00:1f.3"
I: [pulseaudio] sink.c: sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
I: [pulseaudio] sink.c: device.bus = "pci"
I: [pulseaudio] sink.c: device.vendor.id = "8086"
I: [pulseaudio] sink.c: device.vendor.name = "Intel Corporation"
I: [pulseaudio] sink.c: device.product.id = "a2f0"
I: [pulseaudio] sink.c: device.product.name = "200 Series PCH HD Audio"
I: [pulseaudio] sink.c: device.form_factor = "internal"
I: [pulseaudio] sink.c: device.string = "front:0"
I: [pulseaudio] sink.c: device.buffering.buffer_size = "352800"
I: [pulseaudio] sink.c: device.buffering.fragment_size = "176400"
I: [pulseaudio] sink.c: device.access_mode = "mmap+timer"
I: [pulseaudio] sink.c: device.profile.name = "analog-stereo"
I: [pulseaudio] sink.c: device.profile.description = "Analog Stereo"
I: [pulseaudio] sink.c: device.description = "Built-in Audio Analog Stereo"
I: [pulseaudio] sink.c: module-udev-detect.discovered = "1"
I: [pulseaudio] sink.c: device.icon_name = "audio-card-pci"
I: [pulseaudio] source.c: Created source 2 "alsa_output.pci-0000_00_1f.3.analog-stereo.monitor" with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
I: [pulseaudio] source.c: device.description = "Monitor of Built-in Audio Analog Stereo"
I: [pulseaudio] source.c: device.string = "0"
I: [pulseaudio] alsa-sink.c: Using 2.0 fragments of size 176400 bytes (1000.00ms), buffer size is 352800 bytes (2000.00ms)
I: [pulseaudio] alsa-sink.c: Time scheduling watermark is 20.00ms
I: [pulseaudio] alsa-sink.c: Successfully enabled deferred volume.
I: [pulseaudio] alsa-sink.c: Hardware volume ranges from -179.00 dB to 0.00 dB.
I: [pulseaudio] alsa-sink.c: Fixing base volume to 0.00 dB
I: [pulseaudio] alsa-sink.c: Using hardware volume control. Hardware dB scale supported.
I: [pulseaudio] alsa-sink.c: Using hardware mute control.
I: [alsa-sink-ALC892 Analog] util.c: Successfully enabled SCHED_RR scheduling for thread, with priority 5.
I: [alsa-sink-ALC892 Analog] alsa-sink.c: Starting playback.
I: [pulseaudio] module-combine-sink.c: Configuring new sink: alsa_output.pci-0000_00_1f.3.analog-stereo
I: [pulseaudio] module-stream-restore.c: Restoring mute state for sink input sink-input-by-media-role:filter.
I: [pulseaudio] sink-input.c: Created input 0 "Simultaneous output on Built-in Audio Analog Stereo" on alsa_output.pci-0000_00_1f.3.analog-stereo with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
I: [pulseaudio] sink-input.c: media.name = "Simultaneous output on Built-in Audio Analog Stereo"
I: [pulseaudio] sink-input.c: media.role = "filter"
I: [pulseaudio] sink-input.c: module-stream-restore.id = "sink-input-by-media-role:filter"
I: [pulseaudio] sink.c: Changed port of sink 1 "alsa_output.pci-0000_00_1f.3.analog-stereo" to analog-output-headphones
I: [pulseaudio] module-device-restore.c: Restoring volume for sink alsa_output.pci-0000_00_1f.3.analog-stereo.
I: [pulseaudio] module-device-restore.c: Restoring mute state for sink alsa_output.pci-0000_00_1f.3.analog-stereo.
I: [pulseaudio] module-combine-sink.c: Unconfiguring sink: alsa_output.pci-0000_00_1f.3.analog-stereo
I: [pulseaudio] sink-input.c: Freeing input 0 "Simultaneous output on Built-in Audio Analog Stereo"
I: [pulseaudio] sink.c: Freeing sink 1 "alsa_output.pci-0000_00_1f.3.analog-stereo"
I: [pulseaudio] source.c: Freeing source 2 "alsa_output.pci-0000_00_1f.3.analog-stereo.monitor"
I: [pulseaudio] alsa-sink.c: Successfully opened device surround71:0.
I: [pulseaudio] alsa-sink.c: Selected mapping 'Analog Surround 7.1' (analog-surround-71).
I: [pulseaudio] module-device-restore.c: Restoring volume for sink alsa_output.pci-0000_00_1f.3.analog-surround-71: front-left: 3685 / 6%, front-right: 26090 / 40%, rear-left: 3685 / 6%, rear-right: 26090 / 40%, front-center: 26090 / 40%, lfe: 26090 / 40%, side-left: 3685 / 6%, side-right: 26090 / 40%
I: [pulseaudio] module-device-restore.c: Restoring mute state for sink alsa_output.pci-0000_00_1f.3.analog-surround-71: unmuted
I: [pulseaudio] sink.c: Created sink 2 "alsa_output.pci-0000_00_1f.3.analog-surround-71" with sample spec s16le 8ch 44100Hz and channel map front-left,front-right,rear-left,rear-right,front-center,lfe,side-left,side-right
I: [pulseaudio] sink.c: device.string = "surround71:0"
I: [pulseaudio] sink.c: device.buffering.buffer_size = "1411200"
I: [pulseaudio] sink.c: device.buffering.fragment_size = "705600"
I: [pulseaudio] sink.c: device.profile.name = "analog-surround-71"
I: [pulseaudio] sink.c: device.profile.description = "Analog Surround 7.1"
I: [pulseaudio] sink.c: device.description = "Built-in Audio Analog Surround 7.1"
I: [pulseaudio] source.c: Created source 3 "alsa_output.pci-0000_00_1f.3.analog-surround-71.monitor" with sample spec s16le 8ch 44100Hz and channel map front-left,front-right,rear-left,rear-right,front-center,lfe,side-left,side-right
I: [pulseaudio] source.c: device.description = "Monitor of Built-in Audio Analog Surround 7.1"
I: [pulseaudio] alsa-sink.c: Using 2.0 fragments of size 705600 bytes (1000.00ms), buffer size is 1411200 bytes (2000.00ms)
I: [pulseaudio] alsa-sink.c: Time scheduling watermark is 5.03ms
I: [pulseaudio] module-combine-sink.c: Configuring new sink: alsa_output.pci-0000_00_1f.3.analog-surround-71
I: [pulseaudio] remap.c: Using generic matrix remapping
I: [pulseaudio] sink-input.c: Created input 1 "Simultaneous output on Built-in Audio Analog Surround 7.1" on alsa_output.pci-0000_00_1f.3.analog-surround-71 with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
I: [pulseaudio] sink-input.c: media.name = "Simultaneous output on Built-in Audio Analog Surround 7.1"
I: [pulseaudio] module-suspend-on-idle.c: Source alsa_input.pci-0000_00_1f.3.analog-stereo idle for too long, suspending ...
I: [alsa-source-ALC892 Analog] alsa-source.c: Device suspended...
I: [pulseaudio] module-suspend-on-idle.c: Sink combined idle for too long, suspending ...
I: [pulseaudio] sink-input.c: Freeing input 1 "Simultaneous output on Built-in Audio Analog Surround 7.1"
I: [pulseaudio] module-combine-sink.c: Device suspended...
I: [pulseaudio] module-combine-sink.c: Unconfiguring sink: alsa_output.pci-0000_00_1f.3.analog-surround-71
I: [pulseaudio] sink.c: Freeing sink 2 "alsa_output.pci-0000_00_1f.3.analog-surround-71"
I: [pulseaudio] source.c: Freeing source 3 "alsa_output.pci-0000_00_1f.3.analog-surround-71.monitor"
I: [pulseaudio] sink.c: Created sink 3 "alsa_output.pci-0000_00_1f.3.analog-stereo" with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
I: [pulseaudio] source.c: Created source 4 "alsa_output.pci-0000_00_1f.3.analog-stereo.monitor" with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
I: [pulseaudio] sink.c: Changed port of sink 3 "alsa_output.pci-0000_00_1f.3.analog-stereo" to analog-output-headphones
I: [pulseaudio] sink.c: Freeing sink 3 "alsa_output.pci-0000_00_1f.3.analog-stereo"
I: [pulseaudio] source.c: Freeing source 4 "alsa_output.pci-0000_00_1f.3.analog-stereo.monitor"
I: [pulseaudio] sink.c: Created sink 4 "alsa_output.pci-0000_00_1f.3.analog-surround-71" with sample spec s16le 8ch 44100Hz and channel map front-left,front-right,rear-left,rear-right,front-center,lfe,side-left,side-right
I: [pulseaudio] source.c: Created source 5 "alsa_output.pci-0000_00_1f.3.analog-surround-71.monitor" with sample spec s16le 8ch 44100Hz and channel map front-left,front-right,rear-left,rear-right,front-center,lfe,side-left,side-right
^CI: [pulseaudio] main.c: Got signal SIGINT.
I: [pulseaudio] main.c: Exiting.
I: [pulseaudio] main.c: Daemon shutdown initiated.
I: [pulseaudio] module.c: Unloading "module-filter-apply" (index: #22).
I: [pulseaudio] module.c: Unloaded "module-filter-apply" (index: #22).
I: [pulseaudio] module.c: Unloading "module-filter-heuristics" (index: #21).
I: [pulseaudio] module.c: Unloaded "module-filter-heuristics" (index: #21).
I: [pulseaudio] module.c: Unloading "module-role-cork" (index: #20).
I: [pulseaudio] module.c: Unloaded "module-role-cork" (index: #20).
I: [pulseaudio] module.c: Unloading "module-position-event-sounds" (index: #19).
I: [pulseaudio] module.c: Unloaded "module-position-event-sounds" (index: #19).
I: [pulseaudio] module.c: Unloading "module-systemd-login" (index: #18).
I: [pulseaudio] client.c: Freed 0 "Login Session 2"
I: [pulseaudio] module.c: Unloaded "module-systemd-login" (index: #18).
I: [pulseaudio] module.c: Unloading "module-console-kit" (index: #17).
I: [pulseaudio] module.c: Unloaded "module-console-kit" (index: #17).
I: [pulseaudio] module.c: Unloading "module-suspend-on-idle" (index: #16).
I: [pulseaudio] sink-input.c: Created input 2 "Simultaneous output on Built-in Audio Analog Surround 7.1" on alsa_output.pci-0000_00_1f.3.analog-surround-71 with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
I: [pulseaudio] module-combine-sink.c: Resumed successfully...
I: [alsa-source-ALC892 Analog] alsa-source.c: Trying resume...
I: [alsa-source-ALC892 Analog] alsa-util.c: Trying to disable ALSA period wakeups, using timers only
I: [alsa-source-ALC892 Analog] alsa-util.c: ALSA period wakeups disabled
I: [alsa-source-ALC892 Analog] alsa-source.c: Time scheduling watermark is 20.00ms
I: [alsa-source-ALC892 Analog] alsa-source.c: Resumed successfully...
I: [pulseaudio] module.c: Unloaded "module-suspend-on-idle" (index: #16).
I: [pulseaudio] module.c: Unloading "module-intended-roles" (index: #15).
I: [pulseaudio] module.c: Unloaded "module-intended-roles" (index: #15).
I: [pulseaudio] module.c: Unloading "module-always-sink" (index: #14).
I: [pulseaudio] module.c: Unloaded "module-always-sink" (index: #14).
I: [pulseaudio] module.c: Unloading "module-default-device-restore" (index: #13).
I: [pulseaudio] module.c: Unloaded "module-default-device-restore" (index: #13).
I: [pulseaudio] module.c: Unloading "module-combine-sink" (index: #12).
I: [alsa-sink-ALC892 Analog] alsa-sink.c: Increasing wakeup watermark to 7.98 ms
I: [alsa-sink-ALC892 Analog] alsa-sink.c: Underrun!
I: [alsa-sink-ALC892 Analog] alsa-sink.c: Increasing wakeup watermark to 15.96 ms
I: [pulseaudio] sink-input.c: Freeing input 2 "Simultaneous output on Built-in Audio Analog Surround 7.1"
I: [pulseaudio] core.c: default_sink: combined -> alsa_output.pci-0000_00_1f.3.analog-surround-71
I: [pulseaudio] sink.c: Freeing sink 0 "combined"
I: [pulseaudio] source.c: Freeing source 1 "combined.monitor"
I: [pulseaudio] module.c: Unloaded "module-combine-sink" (index: #12).
I: [pulseaudio] module.c: Unloading "module-combine" (index: #11).
I: [pulseaudio] module.c: Unloaded "module-combine" (index: #11).
I: [pulseaudio] module.c: Unloading "module-gsettings" (index: #10).
I: [pulseaudio] module.c: Unloaded "module-gsettings" (index: #10).
I: [pulseaudio] module.c: Unloading "module-native-protocol-unix" (index: #9).
I: [pulseaudio] module.c: Unloaded "module-native-protocol-unix" (index: #9).
I: [pulseaudio] module.c: Unloading "module-dbus-protocol" (index: #8).
I: [pulseaudio] module.c: Unloaded "module-dbus-protocol" (index: #8).
I: [pulseaudio] module.c: Unloading "module-alsa-card" (index: #7).
I: [pulseaudio] core.c: default_sink: alsa_output.pci-0000_00_1f.3.analog-surround-71 -> (unset)
I: [pulseaudio] sink.c: Freeing sink 4 "alsa_output.pci-0000_00_1f.3.analog-surround-71"
I: [pulseaudio] source.c: Freeing source 5 "alsa_output.pci-0000_00_1f.3.analog-surround-71.monitor"
I: [pulseaudio] core.c: default_source: alsa_input.pci-0000_00_1f.3.analog-stereo -> (unset)
I: [pulseaudio] source.c: Freeing source 0 "alsa_input.pci-0000_00_1f.3.analog-stereo"
I: [pulseaudio] card.c: Freed 1 "alsa_card.pci-0000_00_1f.3"
I: [pulseaudio] module.c: Unloaded "module-alsa-card" (index: #7).
I: [pulseaudio] module.c: Unloading "module-alsa-card" (index: #6).
I: [pulseaudio] card.c: Freed 0 "alsa_card.pci-0000_01_00.1"
I: [pulseaudio] module.c: Unloaded "module-alsa-card" (index: #6).
I: [pulseaudio] module.c: Unloading "module-udev-detect" (index: #5).
I: [pulseaudio] module.c: Unloaded "module-udev-detect" (index: #5).
I: [pulseaudio] module.c: Unloading "module-switch-on-port-available" (index: #4).
I: [pulseaudio] module.c: Unloaded "module-switch-on-port-available" (index: #4).
I: [pulseaudio] module.c: Unloading "module-augment-properties" (index: #3).
I: [pulseaudio] module.c: Unloaded "module-augment-properties" (index: #3).
I: [pulseaudio] module.c: Unloading "module-card-restore" (index: #2).
I: [pulseaudio] module.c: Unloaded "module-card-restore" (index: #2).
I: [pulseaudio] module.c: Unloading "module-stream-restore" (index: #1).
I: [pulseaudio] module.c: Unloaded "module-stream-restore" (index: #1).
I: [pulseaudio] module.c: Unloading "module-device-restore" (index: #0).
I: [pulseaudio] module.c: Unloaded "module-device-restore" (index: #0).
I: [pulseaudio] main.c: Daemon terminated.
