Hi, Iβm trying to set up Green With Envy to under-clock my GPU in my laptop (thermal issues).
Installed it from flathub without any problems.
Realized I need to set coolbits in order to underclock, looked at the video and the readme for green with envy, the file was located elsewhere on manjaro.
The file /etc/X11/mhwd.d/nvidia.conf was there but just contained a comment.
I ran nvidia-xsettings specifying it to write to file and not its default path.
I rebooted, black screen.
So my best fix was to go into tty, delete /etc/X11/mhwd.d/nvidia.conf and reboot. Iβm now back at square one.
Why does my computer not boot successfully after I use nvidia-xsettings ?
Graphic driver used is video-hybrid-amd-nvidia-prime.
config :
ββββββββββββββββββ ββββββββ mathieub@IdeaPad16Pro5
ββββββββββββββββββ ββββββββ ----------------------
ββββββββββββββββββ ββββββββ OS: Manjaro Linux x86_64
ββββββββββββββββββ ββββββββ Host: 82L5 IdeaPad 5 Pro 16ACH6
ββββββββ ββββββββ Kernel: 6.1.103-1-MANJARO
ββββββββ ββββββββ ββββββββ Uptime: 8 mins
ββββββββ ββββββββ ββββββββ Packages: 1929 (pacman), 6 (flatpak)
ββββββββ ββββββββ ββββββββ Shell: bash 5.2.26
ββββββββ ββββββββ ββββββββ Resolution: 1920x1200
ββββββββ ββββββββ ββββββββ DE: Plasma 6.0.5
ββββββββ ββββββββ ββββββββ WM: KWin
ββββββββ ββββββββ ββββββββ Theme: [Plasma], Adwaita [GTK2/3]
ββββββββ ββββββββ ββββββββ Icons: [Plasma], breeze-dark [GTK2/3]
ββββββββ ββββββββ ββββββββ Terminal: konsole
CPU: AMD Ryzen 5 5600H with Radeon Graphics (12) @ 3.300GHz
GPU: AMD ATI Radeon Vega Series / Radeon Vega Mobile Series
GPU: NVIDIA GeForce RTX 3050 Mobile
Memory: 2458MiB / 15341MiB
the us of
sudo nvidia-xconfig -c /etc/X11/mhwd.d/nvidia.conf -o /etc/X11/mhwd.d/nvidia.conf
Generated the following file
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 550.107.02
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
This is a bit of mess sorry, does anyone know why mhwd would generate an empty nvidia.conf file or why the one created by nvidia-xsettings does not work.
Thank you.
