"emergency mode" after Timeshift snapshot recovery
I made / boot a separate partition because grub doesn’t work with btrfs. So I had to do / boot ext4. This is how they explained it to me.
Since /boot is a seprated partition, you need to mount /boot also and then chroot :wink:
sudo mount -U 901e9437-31d8-4a4f-ac41-d7e585b7cc79 /mnt/boot
A few years ago this has been true :wink:
https://btrfs.wiki.kernel.org/index.php/FAQ#Does_grub_support_Btrfs.3F
  • I do use grub
  • i do use btrfs for /
  • i do use zstd=9 !!!
  • I don’t have /boot (but i did configure /boot so that btrfs does not use compression there :wink: )
  • i do use zstd with initramfs (to save space even in /boot because kernels actually do decompress even zstd)
    The only thing btrfs can’t do at this time is to store the last boot-entry on btrfs (GRUB_DEFAULT=saved does not work with btrfs)
[manjaro /]# update-grub
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
Found linux image: /boot/vmlinuz-4.19-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.19-x86_64.img
Found initrd fallback image: /boot/initramfs-4.19-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdb4.  Check your device.map.
Found Windows 10 on /dev/sda1
Found Windows 10 on /dev/sda2
Found Manjaro Linux on /dev/sda8
Found Windows 10 on /dev/sdb1
done
I don’t understand what the mistakes are
Ok I try to explain it more simple:
  1. When creating a snapshot on btrfs with timeshift, it only saves files on btrfs and therefore skipped the boot partition.
  2. When creating a snapshot with rsync on timeshift, then it does not use the btrfs snapshot feature and therefore should also backup /boot (which is ext4).
The mistake is that the files on /boot are not on your btrfs partition: /@/boot and therefore timeshift skip it when using the btrfs snapshot feature on timeshift. That results in updated boot files, but rolled back modules, when rolling back.
So i would suggest to:
  • boot a live cd/usb
  • mount /boot also !
  • chroot into your installation
Now you should see /boot with the kernel and initramfs!
then please:
install kernel 5.10 with mhwd-kernel
https://wiki.manjaro.org/index.php/Manjaro_Kernels
look wehter the kernel in /boot/… changed
look wehter the modules in /lib/modules/kernel-version are present
look wehter the generation of the initramfs did work (timestamp of /boot/
This is the first step. When this succeeded we will work from there on
I tried to install the kernel
# mhwd-kernel -i linux510
:: Synchronizing package databases ...
error: failed to update core (unable to lock database)
error: failed to update extra (unable to lock database)
error: failed to update community (unable to lock database)
error: failed to update multilib (unable to lock database)
error: failed to synchronize all databases
And I couldn’t do it.
Then I tried to update the system, but the same thing came out
# pacman -Syyyu
then i found a solution to this problem
rm -f /var/lib/pacman/db.lck
and now I can update.
But the update will make my system the freshest, and I would like to revert to my old snapshot. Is it possible?
was the rigth thing to do :+1:
Don’t update the complete system (pacman). In this special case you only have to install the kernel (mhwd-kernel …)
You will have the old system, but the new kernel. this will help us to boot again. :wink:
 core                                                              169.6 KiB   427 KiB/s 00:00 [#######################################################] 100%
 extra                                                            1893.0 KiB   431 KiB/s 00:04 [#######################################################] 100%
 community                                                           6.6 MiB   283 KiB/s 00:24 [#######################################################] 100%
 multilib                                                          174.6 KiB   262 KiB/s 00:01 [#######################################################] 100%
The following packages are out of date, please update your system first:
Do you want to continue anyway? [y/N] y
error: no targets specified (use -h for help)
I tried to solve the problem myself but wasted too much time. Say that mhwd-kernel does not work in a chroot environment. How do I install the kernel via pacman?
[manjaro /]# pacman -Sy linux510
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
resolving dependencies...
Packages (1) linux510-5.10.61-1
Total Download Size:    73.84 MiB
Total Installed Size:   78.23 MiB
Net Upgrade Size:      -71.11 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 linux510-5.10.61-1-x86_64                                          73.8 MiB   133 KiB/s 09:27 [#######################################################] 100%
(1/1) checking keys in keyring        [#######################################################] 100%
(1/1) checking package integrity                                                               [#######################################################] 100%
(1/1) loading package files        [#######################################################] 100%
(1/1) checking for file conflicts                                                              [#######################################################] 100%
(1/1) checking available disk space                                                            [#######################################################] 100%
(1/2) Removing linux initcpios...
(2/2) Save Linux kernel modules
(1/1) upgrading linux510        [#######################################################] 100%
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
  -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.61-1-MANJARO
  -> Running build hook: [base]
  -> Running build hook: [udev]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
  -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
(4/5) Updating Grub-Bootmenu
done
(5/5) Restore Linux kernel modules
ls: cannot access 'backup': No such file or directory
==> Warning:
         -> Kernel has been updated. Modules of the current kernel
         -> have been backed up so you can continue to use your
         -> computer. However, the new kernel will only work
         -> at next boot.
[manjaro /]# grub-update
bash: $'\320\277\320grub-update': command not found
done
Thank you for the tip. I didn’t know mhwd-kernel does not work in chroot. I never used it in chroot myself @megavolt
So does it boot ? IF yes, you are save for now.
But we have to do something so that this never will happen again:
  • unmount /boot ! so that the /boot partition is invisible, and mount it at /mnt
    now you should have an empty dir /boot
  • update grub to 2.04-1 or newer
  • modify /boot (inside /) so that btrfs will never compress files inside /boot
    Can_I_disable_compression_on_a_file
    Do this with no (for no compression) for /boot
    Read the warning there
    FS#63235 : [grub] 2.04 missing support for zstd on btrfs
    This is only for safety. In case your GRUB is old this is needed ! If your GRUB is new this is not necessary
  • move all data from /mnt (your outside /boot partition) with rsync to /boot (inside /)
  • change the fstab, so that the /boot partition will not be mounted again
    comment the line with /boot in it with an starting #
  • create a new grub.cfg, so that grub does not try to get the kernel from the /boot (external partition) but from btrfs /boot
After that you are really save (and can rollback any time)
no, now I am greeted with a new conclusion.
there may be one additional problem. Did you use compession in btrfs ?
what version is your grub ? 2.xx or 2.04-1 ?
only for safety:
  • you did mount the right snapshot (!!!) from your btrfs at ??? (maybe /mnt/)
    so you could see there /mnt/home/, /mnt/usr … and an empty /mnt/boot (!!!), and /mnt/boot was empty (!!!)
  • you did mount /boot inside your ???/boot (maybe /mnt/boot/)
    so you could see /mnt/boot/grub with all files included and a kernel and initramdisk at /mnt/boot/…
  • you did chroot after that
    so you could see now /boot/grub with all files included and the kernel at /boot/…
  • you did update your kernel
  • you did recreate initramdisk with mkinitcpio
  • you did recreate grub configfile
    (some commands may have included others already)
:point_down: So reinstalling grub seems to be a good idea
(sorry, i myself did use GPT even with BIOS)
I guess you forgot to mention that grub needs be installed again and since it is a pure old school BIOS:
So @gadzhi I believe, since it is a BIOS, the partition table must be also MS-DOS (and not GPT), therefore you need to reinstall grub (overwrite the MBR for the new boot location):
:warning: Do this in chroot!
grub-install --force --target=i386-pc --recheck --boot-directory=/boot /dev/sda
grub-mkconfig -o /boot/grub/grub.cfg
This should fix it…
# grub-install --version
grub-install (GRUB) 2.06~1~manjaro
i mounted like this:
[manjaro@manjaro ~]$ sudo mount -o subvol=@ -U abd07649-4af0-49fa-906b-c8cc116b98e6 /mnt
[manjaro@manjaro ~]$ sudo mount -U 901e9437-31d8-4a4f-ac41-d7e585b7cc79 /mnt/boot
[manjaro@manjaro ~]$ manjaro-chroot /mnt /bin/bash
as far as I understand, yes
I don’t know what it is, but I entered these commands a few days ago.
[manjaro /]# grub-install --force --target=i386-pc --recheck --boot-directory=/boot /dev/sda
Installing for i386-pc platform.
Installation finished. No error reported.
[manjaro /]# grub-mkconfig -o /boot/grub/grub.cfg
done
sorry
Since all 3 of us don’t know what there really happens. Then i would suggest:
Stop grub when grub-menu shows
Let it show (edit) the boot - entry it is gona use.
There examine
  • which device grub uses
  • where grub will look for the kernel
  • where grub will look for the initramfs
  • which startline will grub give to the kernel
  • does kernel mount @ or does it mount default ?
take this to a note on paper :wink: or take a photo
Then check these places
  • there must be such device with this uid or devicename for grub
  • the kernel (vmlinuz…) there must have an date from like in your notes and a reasonable size
  • the initramfs must have a date from yesterday (you may look into it with mc) and a reasonable size
  • look for the exact kernel version. Are there the needed files in /lib/modules/ with this exact directory. are the modules realy there ? Test with du
    du --summarize --human-readable 5.10.59-1-MANJARO
    88M 5.10.59-1-MANJARO
Don´t compare my sizes for initramfs because it may contain other modules, and is compressed with zstd
 ls -lA
insgesamt 141812
-rw-r--r-- 1 root root    40960 19. Jul 21:16 amd-ucode.img
drwxr-xr-x 3 root root     4096  1. Jan 1970  efi
drwxr-xr-x 1 root root        6  1. Jan 1970  efi_backup
drwxr-xr-x 1 root root      122 12. Feb 2020  grml
drwxr-xr-x 1 root root      182 17. Aug 20:03 grub
-rw-r--r-- 1 root root 28835270 28. Aug 16:38 initramfs-4.19-x86_64-fallback.img
-rw-r--r-- 1 root root  9844849 28. Aug 16:38 initramfs-4.19-x86_64.img
-rw-r--r-- 1 root root 29406909 28. Aug 16:39 initramfs-5.10-x86_64-fallback.img
-rw-r--r-- 1 root root  9381096 28. Aug 16:39 initramfs-5.10-x86_64.img
-rw-r--r-- 1 root root 33090801 28. Aug 16:39 initramfs-5.13-x86_64-fallback.img
-rw-r--r-- 1 root root  9528972 28. Aug 16:39 initramfs-5.13-x86_64.img
-rw-r--r-- 1 root root       23 15. Aug 13:51 linux419-x86_64.kver
-rw-r--r-- 1 root root       22 15. Aug 15:10 linux510-x86_64.kver
-rw-r--r-- 1 root root       22 15. Aug 15:14 linux513-x86_64.kver
drwxr-xr-x 1 root root       22 13. Jul 17:00 memtest86+
-rw-r--r-- 1 root root  5986112 17. Aug 20:02 vmlinuz-4.19-x86_64
-rw-r--r-- 1 root root  9387104 17. Aug 20:02 vmlinuz-5.10-x86_64
-rw-r--r-- 1 root root  9681216 17. Aug 20:02 vmlinuz-5.13-x86_64
something to compare while in grub editor:
menuentry 'Manjaro Linux' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-3487ba3d-1cba-4cdc-a043-c420ebca2aca' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod btrfs
set root='hd0,gpt2'
if [ x$feature_platform_search_hint = xy ]; then
  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt2 --hint-efi=hd0,gpt2 --hint-baremetal=ahci0,gpt2  3487ba3d-1cba-4cdc-a043-c420ebca2aca
else
  search --no-floppy --fs-uuid --set=root 3487ba3d-1cba-4cdc-a043-c420ebca2aca
fi
linux	/@/boot/vmlinuz-5.13-x86_64 root=UUID=3487ba3d-1cba-4cdc-a043-c420ebca2aca rw rootflags=subvol=@  bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash modprobe.blacklist=ccp udev.log_priority=3 audit=0 sysrq_always_enabled=1
initrd	/@/boot/amd-ucode.img /@/boot/initramfs-5.13-x86_64.img
be aware, my /boot is already on btrfs :wink:
