Emacsclient as desktop application
Dear All,
I am trying using emacs as a daemon by enabling and starting the systemd service emacs.service. Thus launching the emacsclient via XDG desktop application using the following code:
#!/usr/bin/env xdg-open
[Desktop Entry]
Name=Emacs (Client)
GenericName=Text Editor
Comment=Edit text
MimeType=text/english;text/plain;text/x-makefile;text/x-c++hdr;text/x-c++src;text/x-chdr;text/x-csrc;text/x-java;text/x-moc;text/x-pascal;text/x-tcl;text/x-tex;application/x-shellscript;text/x-c;text/x-c++;
Exec=/usr/bin/emacsclient -с -a "" %F
Icon=emacs
Type=Application
Terminal=false
Categories=Development;TextEditor;Utility;
StartupWMClass=Emacs
However, when I click on the icon "Emacs (Client)" nothing happens. I can start emacsclient from the terminal running 'emacsclient -c -a ""' and it works without issues. I have tried both with and without the xdg-open shebang. Nothing change.
Can you please help me?
Thanks in advance for your time!
BR
I think that is not correct (emacsclient: unrecognized option '-с', EDIT: it is actually an Es (Cyrillic) :rofl:), should be a lower case c. Also, I am not sure the %F argument helps. I have two related desktop files that works (you might not want the -n flag):
  • With new frame: Exec=emacsclient -cna "".
  • Without new frame: Exec=emacsclient -na "".
Check if that works, they should even if the daemon has not started, since they will do that then. Also try the exact command from CLI.
I have tried starting emacs daemon as emacs -Q and the emacsclient desktop works like a charm... So it's a configuration issue. I will try debugging that (although emacs --debug-init didn't give any type of error O.o)
Thank for your help!! :slight_smile:
Are you running that as root or as your user?
If as root, try running as a user service:
sudo systemctl disable --now emacs
systemctl --user enable --now emacs
