Greetings all.
Yesterday I got a new laptop with Manjaro + Plasma preinstalled. Today I installed emacs and it’s fine in console mode. But it refuses open a window whatever way I try to launch it.
emacs & or emacs -D & in konsole give me
Undefined color: “WINDOW_FOREGROUND”
and nothing shows up in KSystemLog. Everything is up to date.
Any idea?
Thanks, alcofribas
PS If this is not the right place for this query please tell me.
Thanks you very much for the tip. I overcame my initial panic and went through the long list of command-line options in the emacs manual. When I do
$ emacs --no-x-resources &
I get a primitive looking UI but something that I can use. On the other hand, considering WINDOW_FOREGROUND as an environment variable always gets me that same error message.
So the problem seems to be either with X or GTK resources. There is long chapter in the manual about how these two are used in emacs, but their syntax is really different from that all-caps style.
I’ll experiment a bit more. Thanks again, alcofribas
Not yet! The first priority is getting the meta key on emacs to work the way I am used to. Getting nice icons takes a back seat. Quite a lot of key combinations are captured by Plasma… this deserves a righteous rant one day, but not on this polite, helpful and very responsive site.
OK, I got it after a little search. It’s a bug that’s mentioned in a 2017 Arch forum, and I got the following more detailed version in a 2014 Centos forum.
It’s a bug in both KDE (as shipped) and Mate (EPEL). They use X resources and expect them to be preprocessed (replacing WINDOW_FOREGROUND with some colour). But X resources are no longer preprocessed in Centos7. There are bugzilla entries for both but nothing happens. For KDE you can turn off something like “apply colour scheme to non-KDE apss” as a workaround. For Mate you can delete all X resources with “xrdb /dev/null” before you start emacs (or any other legacy program).
The proposed workaround was for KDE4 and doesn’t seem possible anymore, but the xrdb trick worked for me. I find it quite amazing that this bug is still around after all those years.
I also faced this problem. But after I installed a software like mpv-git( other softwares which have graphical interfaces maybe work I guess) from AUR, ran it and rebooted the system, this problem had been solved. Maybe the system dismisses something important.
