I recently encountered issues when using emacs with specific features. By digging further I tracked the problem down to different emacs versions available via pamac, i.e.
- Emacs (client)
- Emacs (client)(emacs-wayland)
The latter enables PGTK and solved my issues.
Now I am wondering why non-compatible packages are available via pamac. Is this something related to wayland, i.e. I can enable/ disable wayland on my system?
Or is it generally left to the user to pick and install the compatible package?
Or alternatively, should I contact the maintainer of the non-compatible package and file this issue there?
This is my system:
>>> inxi --admin --verbosity=8 --filter --no-host --width
Kernel: 6.12.68-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=4c2ea2f1-3cfa-4377-8778-97f19f2453fe rw quiet
cryptdevice=UUID=ac37595d-5b67-408c-82b8-547a678e97e6:luks-ac37595d-5b67-408c-82b8-547a678e97e6
root=/dev/mapper/luks-ac37595d-5b67-408c-82b8-547a678e97e6
udev.log_priority=3
Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
Type: Desktop System: MSI product: MS-7798 v: 1.0
serial: <superuser required>
Mobo: MSI model: B75MA-P45 (MS-7798) v: 1.0 serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: American Megatrends v: 1.9
date: 09/30/2013
Device-1: hidpp_battery_0 model: Logitech M720 Triathlon Multi-Device Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 24 GiB available: 23.4 GiB used: 3.58 GiB (15.3%)
Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Corsair part-no: CML8GX3M2A1600C9 serial: N/A
Device-2: ChannelA-DIMM1 type: DDR3 detail: synchronous size: 8 GiB
manufacturer: Hynix/Hyundai part-no: HMT41GU6AFR8A-PB serial: <filter>
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
Device-4: ChannelB-DIMM1 type: DDR3 detail: synchronous size: 8 GiB
Info: model: Intel Core i5-3450S bits: 64 type: MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1600 min/max: 1600/2800 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1600 2: 1600 3: 1600 4: 1600 bogomips: 22408
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid xsave
xsaveopt xtopology xtpr
disabled
STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 590.48.01
alternate: nouveau,nvidia_drm non-free: 550-580.xx+ status: current (as of
2025-11; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
compositor: kwin_wayland driver: X: loaded: nvidia
gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-1 model: Idek Iiyama PL2792Q serial: <filter> built: 2021
res: mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 109 gamma: 1.2 chroma: red:
x: 0.671 y: 0.333 green: x: 0.298 y: 0.627 blue: x: 0.141 y: 0.051 white:
x: 0.322 y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: 2560x1440, 2048x1280, 1920x1200, 1920x1080, 1600x1200,
1680x1050, 1600x900, 1280x1024, 1440x900, 1280x720, 1024x768, 800x600,
720x576, 720x480, 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 25.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB display-ID: :1.0
API: Vulkan v: 1.4.335 layers: 4 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 590.48.01
device-ID: 10de:2504 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: corectrl, nvidia-settings, nvidia-smi
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
class-ID: 0403
API: ALSA v: k6.12.68-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Edimax AC1200 USB WiFi Adapter driver: rtw_8822bu type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 3-3:2
chip-ID: 7392:f822 class-ID: 0000 serial: <filter>
IF: wlp0s20u3 state: up mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2
chip-ID: 0a12:0001 class-ID: e001
Device-1: bitlk_mobi_stick maj-min: 254:3 type: Crypto dm: dm-3
Components:
p-1: sdd1 maj-min: 8:49 size: 119.01 GiB
Device-2: bitlk_daniel_stick maj-min: 254:4 type: Crypto dm: dm-4
Components:
p-1: sdd2 maj-min: 8:50 size: 30 GiB
Device-3: bitlk_bibliothek_stick maj-min: 254:5 type: Crypto dm: dm-5
Components:
p-1: sdd3 maj-min: 8:51 size: 30 GiB
Device-4: bitlk_wiki_stick maj-min: 254:6 type: Crypto dm: dm-6
Components:
p-1: sdd4 maj-min: 8:52 size: 30 GiB
Device-5: bitlk_work_stick maj-min: 254:7 type: Crypto dm: dm-7
Components:
p-1: sdd5 maj-min: 8:53 size: 30 GiB
Device-6: luks-ac37595d-5b67-408c-82b8-547a678e97e6 maj-min: 254:0
type: LUKS dm: dm-0 size: 232.59 GiB
Components:
p-1: sda2 maj-min: 8:2 size: 232.59 GiB
Device-7: luks-8e70af97-5288-4227-b43f-15c7ae8b158e maj-min: 254:2
type: LUKS dm: dm-2 size: 931.51 GiB
Components:
p-1: sdb1 maj-min: 8:17 size: 931.51 GiB
Device-8: luks-97478fb5-267e-493d-8774-49eef2f55050 maj-min: 254:1
type: LUKS dm: dm-1 size: 465.76 GiB
Components:
p-1: sdc1 maj-min: 8:33 size: 465.76 GiB
Local Storage: total: 1.83 TiB used: 1.19 TiB (65.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: Flash Drive FIT
size: 239.02 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: 1100 scheme: GPT
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 123.55 GiB (54.2%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ac37595d-5b67-408c-82b8-547a678e97e6 label: System
uuid: 4c2ea2f1-3cfa-4377-8778-97f19f2453fe
used: 472 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 04E7-F02F
ID-3: /mnt/org/bibliothek raw-size: 30 GiB size: 30 GiB (100.00%)
used: 8.54 GiB (28.5%) fs: fuseblk dev: /dev/dm-5 maj-min: 254:5
mapped: bitlk_bibliothek_stick label: N/A uuid: N/A
ID-4: /mnt/org/daniel raw-size: 30 GiB size: 30 GiB (100.00%)
used: 15.6 GiB (52.0%) fs: fuseblk dev: /dev/dm-4 maj-min: 254:4
mapped: bitlk_daniel_stick label: N/A uuid: N/A
ID-5: /mnt/org/mobi raw-size: 119.01 GiB size: 119.01 GiB (100.00%)
used: 34.43 GiB (28.9%) fs: fuseblk dev: /dev/dm-3 maj-min: 254:3
mapped: bitlk_mobi_stick label: N/A uuid: N/A
ID-6: /mnt/org/wiki raw-size: 30 GiB size: 30 GiB (100.00%)
used: 6.19 GiB (20.6%) fs: fuseblk dev: /dev/dm-6 maj-min: 254:6
mapped: bitlk_wiki_stick label: N/A uuid: N/A
ID-7: /mnt/org/work raw-size: 30 GiB size: 30 GiB (100.00%)
used: 83.5 MiB (0.3%) fs: fuseblk dev: /dev/dm-7 maj-min: 254:7
mapped: bitlk_work_stick label: N/A uuid: N/A
ID-8: /run/media/schatzi/Data raw-size: 465.76 GiB
size: 457.38 GiB (98.20%) used: 361.42 GiB (79.0%) fs: ext4 dev: /dev/dm-1
maj-min: 254:1 mapped: luks-97478fb5-267e-493d-8774-49eef2f55050
label: Data uuid: aea89950-6192-4055-8c45-0991f2477684
ID-9: /run/media/schatzi/Extra raw-size: 931.51 GiB
size: 915.81 GiB (98.31%) used: 667.65 GiB (72.9%) fs: ext4 dev: /dev/dm-2
maj-min: 254:2 mapped: luks-8e70af97-5288-4227-b43f-15c7ae8b158e
label: Extra uuid: a584c501-ec7f-44d1-8912-433590b0e4a3
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdd1 maj-min: 8:49 size: 119.01 GiB fs: bitlocker
label: 20IAV502790N-0 Mobi 20.06.2023
uuid: 19a7082b-3c22-4c74-b120-5145a4be6aea
ID-2: /dev/sdd2 maj-min: 8:50 size: 30 GiB fs: bitlocker
label: 20IAV502790N-0 Daniel 22.06.2023
uuid: 31203ad1-da38-4cc3-a989-36c1904f0ce1
ID-3: /dev/sdd3 maj-min: 8:51 size: 30 GiB fs: bitlocker
label: 20IAV502790N-0 Bibliothek 20.06.2023
uuid: 2cf5acb6-cd16-469d-9969-fe23c47bfb15
ID-4: /dev/sdd4 maj-min: 8:52 size: 30 GiB fs: bitlocker
label: 20IAV502790N-0 Wiki 20.06.2023
uuid: 02985be4-7822-4688-af77-2b2f231f9ec5
ID-5: /dev/sdd5 maj-min: 8:53 size: 30 GiB fs: bitlocker
label: 20IAV502790N-0 Iav 20.06.2023
uuid: 40082e01-5629-41e6-9622-4efe2c06129c
Device-1: 1-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 1-4:4 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
chip-ID: 214b:7250 class-ID: 0900
Hub-3: 1-4.3:5 info: Monterey BakkerElkhuizen Wired Keyboard S-board 840
Design USB-Hub ports: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 100mA chip-ID: 0566:3020 class-ID: 0900
Device-1: 1-4.3.2:6 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-4.3.3:7 info: Monterey BakkerElkhuizen Wired Keyboard S-board
840 Design type: keyboard,HID driver: hid-generic,usbhid interfaces: 2
rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 100mA
chip-ID: 0566:3013 class-ID: 0300
Hub-4: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-5: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Hub-6: 2-1.5:3 info: Realtek 4-Port USB 2.0 Hub ports: 2 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5412
Device-1: 2-1.5.1:4 info: Silicon Motion - Taiwan (formerly Feiya ) Flash
Drive type: mass storage driver: usb-storage interfaces: 1 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 300mA
chip-ID: 090c:1000 class-ID: 0806 serial: <filter>
Hub-7: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
Device-1: 3-3:2 info: Edimax AC1200 USB WiFi Adapter type: Network
driver: rtw_8822bu interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 504mA chip-ID: 7392:f822 class-ID: 0000
serial: <filter>
Hub-8: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-9: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
System Temperatures: cpu: 31.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 2061 libs: 464 tools: pamac pm: flatpak pkgs: 0
1: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
2: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
3: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
4: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
7: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
8: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 332
1: cpu: 15.0% command: konsole pid: 4120 mem: 280.0 MiB (1.1%)
2: cpu: 11.0% command: firefox pid: 1999 mem: 274.1 MiB (1.1%)
3: cpu: 9.4% command: firefox pid: 1745 mem: 487.4 MiB (2.0%)
4: cpu: 5.3% command: kwin_wayland pid: 976 mem: 238.6 MiB (0.9%)
5: cpu: 5.2% command: zsh pid: 4130 mem: 8.34 MiB (0.0%)
Memory top: 5 of 332
1: mem: 1355.0 MiB (5.6%) command: pamac-manager pid: 2575 cpu: 4.7%
2: mem: 487.4 MiB (2.0%) command: firefox pid: 1745 cpu: 9.4%
3: mem: 390.8 MiB (1.6%) command: plasmashell pid: 1157 cpu: 1.3%
4: mem: 280.0 MiB (1.1%) command: konsole pid: 4120 cpu: 15.0%
5: mem: 274.1 MiB (1.1%) command: firefox pid: 1999 cpu: 11.0%
Processes: 332 Power: uptime: 12m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 9.33 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.3.9 running-in: konsole inxi: 3.3.40
Thanks,
Daniel
