Influxdb-cli installation in manjaro
I am trying to install the following package:
https://aur.archlinux.org/packages/influxdb-cli/
but the following command fails with error:
Is there any way to install influxdb client?
You can either use Pamac to install the said AUR package
pamac build influxdb-cli
or yay using this command
yay -S influxdb-cli
You can see the man page of yay for more information (man yay).
Please read this:
especially this bit:
:pray:
Thanks.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
