When starting my system with an Stable Kernel, it lands into emergency shell.
Due this the system is not booting.:
sudo fsck.vfat -r -t /dev/nvme0n1p1
[sudo] Passwort für pheiduck:
fsck.fat 4.2 (2021-01-31)
There are differences between boot sector and its backup.
This is mostly harmless. Differences: (offset:original/backup)
65:01/00
1) Copy original to backup
2) Copy backup to original
3) No action
[123?q]? 2
How can I solve this?
System Info:
Kernel: 6.10.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.10-x86_64
root=UUID=2858d787-58d2-4b32-bfe2-dcd848223859 rw rootflags=subvol=@
cryptdevice=UUID=ec00de08-393b-4d8c-a1ed-853a4de311ee:cryptroot quiet
splash udev.log_priority=3 amd_pstate=active
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: light-locker,xfce4-screensaver dm: LightDM v: 1.32.0
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <filter> part-nu: SKU uuid: f1be0f0b-83c9-788a-bfae-244bfe5cd0c0
UEFI: American Megatrends v: 5013 date: 03/22/2024
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 32 GiB available: 31.25 GiB used: 4.57 GiB (14.6%)
Device-1: DIMM_A1 type: no module installed
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK32GX4M2B3200C16 serial: N/A
Device-3: DIMM_B1 type: no module installed
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 9 3900X socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701033
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2001 high: 4063 min/max: 550/4673 base/boost: 3800/4650
scaling: driver: amd-pstate-epp governor: powersave volts: 1.1 V
ext-clock: 100 MHz cores: 1: 3777 2: 3597 3: 3600 4: 3775 5: 3645 6: 4063
7: 550 8: 550 9: 3500 10: 550 11: 550 12: 550 13: 550 14: 550 15: 550
16: 550 17: 550 18: 550 19: 3599 20: 3937 21: 3566 22: 3828 23: 550 24: 550
bogomips: 182451
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xtopology
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 0b:00.0
chip-ID: 1002:731f class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2
chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung SyncMaster
serial: <filter> built: 2009 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 587mm (23.1") ratio: 16:9, 15:9 modes:
max: 1920x1080 min: 640x480
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (radeonsi
navi10 LLVM 18.1.8 DRM 3.57 6.10.5-1-MANJARO) device-ID: 1002:731f
memory: 7.81 GiB unified: no
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
Device-4: Logitech [G533 Wireless Headset Dongle]
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 046d:0a66 class-ID: 0300
API: ALSA v: k6.10.5-1-MANJARO status: kernel-api
Server-2: PipeWire v: 1.2.2 status: n/a (root, process) with:
1: pipewire-pulse status: active 2: pipewire-media-session status: active
3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:3
chip-ID: 0a12:0001 class-ID: e001
Device-1: cryptroot maj-min: 254:0 type: LUKS dm: dm-0 size: 419.26 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:4 size: 419.26 GiB
Local Storage: total: 1.82 TiB used: 118.85 GiB (6.4%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 48.9 C
scheme: GPT
SMART: yes health: PASSED on: 11d 9h cycles: 2,093
read-units: 6,823,828 [3.49 TB] written-units: 5,806,992 [2.97 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 45.9 C
scheme: GPT
SMART: yes health: PASSED on: 7d 20h cycles: 2,093
read-units: 8,653,937 [4.43 TB] written-units: 7,971,963 [4.08 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 2B6Q temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 48d 22h cycles: 1408
written: 4.44 TiB
ID-1: / raw-size: 419.26 GiB size: 419.26 GiB (100.00%)
used: 75.76 GiB (18.1%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: cryptroot label: N/A uuid: N/A
used: 27.7 MiB (5.4%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:2 label: N/A uuid: C380-DE14
ID-3: /home raw-size: 419.26 GiB size: 419.26 GiB (100.00%)
ID-4: /run/media/pheiduck/Daten raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 43.06 GiB (4.6%) fs: btrfs
block-size: 4096 B dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 3704c1e0-6710-4592-8b0b-28322fd45bbd
ID-1: swap-1 type: zram size: 15.63 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24 dev: /dev/zram0
ID-1: /dev/nvme1n1p1 maj-min: 259:3 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-2: /dev/nvme1n1p2 maj-min: 259:5 size: 418.41 GiB fs: ntfs
label: Windoof uuid: 1E16606116603C41
ID-3: /dev/nvme1n1p3 maj-min: 259:6 size: 778 MiB fs: ntfs label: N/A
uuid: 6AA27E6AA27E3AA1
Device-1: 1-1:2 info: Logitech C922 Pro Stream Webcam type: video,audio
Device-2: 1-2:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-2:2 info: Logitech [G533 Wireless Headset Dongle]
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Device-2: 3-4:3 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 5-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 5-3.2:4 info: Metadot Das Keyboard 4 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 24f0:204a class-ID: 0300
Device-2: 5-4:3 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Hub-7: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 42.0 C mobo: 46.0 C gpu: amdgpu temp: 53.0 C
mem: 50.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Processes: 490 Power: uptime: 23m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 256 default: graphical tool: systemctl
Packages: 1372 pm: pacman pkgs: 1357 libs: 386 tools: pamac pm: flatpak
pkgs: 15 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.15p5
default: Zsh v: 5.9 running-in: xfce4-terminal inxi: 3.3.35
