i,
I’d been running 5.9.16-1 for the last 5 months no issue but saw that it was no longer supported so I updated my kernel to 5.10 LTS.
After installing the newer kernel and rebooted I got the following error on screen:
EFI stub: ERROR: Failed to open file initramfs-5.10-x86_64.img
EFI stub: ERROR: Failed to load initrd!
EFI stub: ERROR: efi_main() failedFailed to execute Manjaro Linux 5.10(\Manjaro\vmlinuz-5.10-x86_64): Not found
Dropped into a chroot session and I can provide the following:
mhwd-kernel -li
* linux510
* linux511
* linux54
* linux59
inxi -Fza
System: Kernel: 5.6.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 misobasedir=manjaro misolabel=MANJARO_ARCHITECT_2003 quiet systemd.show_status=1 Console: tty 1 Distro: Manjaro Linux base: Arch Linux Machine: Type: Laptop System: Notebook product: PCX0DX v: N/A serial: N/A Chassis: type: 10 serial: N/A Mobo: Notebook model: PCX0DX serial: N/A UEFI: INSYDE v: 1.07.07 date: 06/17/2020 Battery: ID-1: BAT0 charge: 70.3 Wh (100.0%) condition: 70.3/70.7 Wh (99.5%) volts: 12.8 min: 11.4 model: Notebook BAT type: Li-ion serial: <filter> status: Full CPU: Info: 8-Core model: Intel Core i7-10875H socket: U3E1 bits: 64 type: MT MCP arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: C8 cache: L2: 16 MiB flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 73625 Speed: 900 MHz min/max: 800/5100 MHz base/boost: 2178/8300 volts: 0.8 V ext-clock: 100 MHz Core speeds (MHz): 1: 900 2: 901 3: 900 4: 900 5: 901 6: 900 7: 901 8: 900 9: 900 10: 900 11: 901 12: 900 13: 900 14: 900 15: 901 16: 900 Vulnerabilities: Type: itlb_multihit status: KVM: Split huge pages Type: l1tf status: Not affected Type: mds status: Not affected Type: meltdown status: Not affected Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling Type: tsx_async_abort status: Not affected Graphics: Device-1: Intel UHD Graphics vendor: CLEVO/KAPOK driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300 Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: CLEVO/KAPOK driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300 Device-3: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 1-8:2 chip-ID: 5986:9102 class-ID: 0e02 Display: server: X.org 1.20.11 driver: loaded: modesetting alternate: fbdev,intel,vesa tty: 240x67 Message: Advanced graphics data unavailable in console for root. Audio: Device-1: Intel Comet Lake PCH cAVS vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403 Device-2: NVIDIA TU106 High Definition Audio vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403 Sound Server-1: ALSA v: k5.6.15-1-MANJARO running: yes Sound Server-2: JACK v: 0.125.0 running: no Sound Server-3: PulseAudio v: 14.2 running: no Sound Server-4: PipeWire v: 0.3.26 running: no Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 3000 bus-ID: 42:00.0 chip-ID: 10ec:8168 class-ID: 0200 IF: enp66s0 state: down mac: <filter> Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 3000 bus-ID: 44:00.0 chip-ID: 8086:2723 class-ID: 0280 IF: wlp68s0 state: down mac: <filter> Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0029 class-ID: e001 Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: N/A rfk-block: hardware: no software: no address: see --recommends Drives: Local Storage: total: 5.51 TiB used: 996.62 GiB (17.7%) ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 211070WD temp: 39.9 C SMART: yes health: PASSED on: 52d 12h cycles: 253 read-units: 180,178 [92.2 GB] written-units: 1,549,517 [793 GB] ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 2B2QEXE7 temp: 38.9 C SMART: yes health: PASSED on: 78d 18h cycles: 185 read-units: 242,546 [124 GB] written-units: 2,433,114 [1.24 TB] ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Seagate model: BUP BK size: 3.64 TiB block-size: physical: 4096 B logical: 512 B serial: <filter> rev: 0304 SMART Message: A mandatory SMART command failed. Various possible causes. ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Ultra size: 57.28 GiB block-size: physical: 512 B logical: 512 B serial: <filter> rev: 1.00 SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure? Partition: ID-1: / raw-size: 100 GiB size: 97.93 GiB (97.93%) used: 30.19 GiB (30.8%) fs: ext4 block-size: 4096 B dev: /dev/dm-6 maj-min: 254:6 mapped: vg02-lvol--root ID-2: /boot raw-size: 767 MiB size: 765.5 MiB (99.80%) used: 593.6 MiB (77.5%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1 maj-min: 259:3 ID-3: /home raw-size: 10 GiB size: 9.78 GiB (97.81%) used: 262.9 MiB (2.6%) fs: ext4 block-size: 4096 B dev: /dev/dm-7 maj-min: 254:7 mapped: vg02-lvol--home Swap: Alert: No swap data was found. Sensors: System Temperatures: cpu: 66.0 C mobo: N/A gpu: nouveau temp: 44.0 C Fan Speeds (RPM): N/A Info: Processes: 311 Uptime: 2m wakeups: 1 Memory: 31.06 GiB used: 912.1 MiB (2.9%) Init: systemd v: 247 tool: systemctl Compilers: gcc: 10.2.0 Packages: 1443 pacman: 1422 lib: 399 flatpak: 21 Shell: systemd (sudo) running-in: tty 1 inxi: 3.3.04
ls /boot/*
/boot/amd-ucode.img
/boot/initramfs-5.4-x86_64-fallback.img
/boot/initramfs-5.4-x86_64.img
/boot/initramfs-5.9-x86_64-fallback.img
/boot/initramfs-5.9-x86_64.img
/boot/intel-ucode.img
/boot/linux54-x86_64.kver
/boot/linux59-x86_64.kver
/boot/vmlinuz-5.4-x86_64
/boot/vmlinuz-5.9-x86_64/boot/EFI:
BOOT
Linux
systemd/boot/Manjaro:
amd-ucode.img
initramfs-5.10-x86_64-fallback.img
initramfs-5.11-x86_64-fallback.img
initramfs-5.11-x86_64.img
intel-ucode.img
linux510-x86_64.kver
linux511-x86_64.kver
linux54-x86_64.kver
vmlinuz-5.10-x86_64
vmlinuz-5.11-x86_64
vmlinuz-5.4-x86_64/boot/loader:
entries
loader.conf
random-seed/boot/memtest86+:
memtest.bin
parted -l
Model: WDC WDS100T2B0C-00PXH0 (nvme)
Disk /dev/nvme0n1: 1000GB
Partition Table: gpt
Disk Flags:Number Start End Size File system Name Flags
1 1049kB 1000GB 1000GB Linux LVM lvmModel: Samsung SSD 970 EVO 1TB (nvme)
Disk /dev/nvme1n1: 1000GB
1 1049kB 805MB 804MB fat32 EFI system partition boot, esp
2 806MB 1000GB 999GB Linux LVM lvm
Any help on what I can do to resolve would be much appreciated.
TIA
Jade
