Dying Light wont run using Primusrun....
So! Hello all!
I have an issue when i try to play games on steam through proton occassionally that they just seem to start and crash, now as for Dying Light, i set the launch options in steam,
PROTON_LOG=1 primusrun %command%
so i can get an output log of whats exactly going on. well whenever i dont use primusrun,or optirun for that matter, the game starts, but of course performance tanks, and im not sure exactly if this is a mesa issue, or an issue just with proton, or some mismatch of two or more issues.
Here is the output log for reference, and I am using proton to run the game as when i tried to run it using the native linux binary i couldnt start the game at all. Something to do with GLEW incompatabilities and some libraries not loading correctly that I just could not fix.
https://pastebin.com/rDRLQgiQ
Any help is greatly appreciated, as I've tried a few methods already trying to get this game to work at all with primus. Cheers :grinning:
Some good information to include would be
inxi -Fxxxza --no-host
System: Kernel: 5.3.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.3-x86_64
root=UUID=ef717435-7ce9-4921-b254-0f0fc06d9c90 rw quiet splash iommu=pt
intel_iommu=on vfio-pci.ids=8086:1e31
Desktop: i3 4.17.1 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Portable System: Alienware product: M14xR2 v: A16 serial:
Mobo: Alienware model: M14xR2 v: A16 serial: UEFI: Alienware v: A16
date: 05/28/2018
Battery: ID-1: BAT1 charge: 26.2 Wh condition: 26.2/64.5 Wh (41%) volts: 16.3/14.8
model: SDI PABAS0241231 type: Li-ion serial: status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial:
charge: 55% (should be ignored) rechargeable: yes status: Discharging
CPU: Topology: Quad Core model: Intel Core i7-3630QM bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 6144 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38334
Speed: 1197 MHz min/max: 1200/3400 MHz Core speeds (MHz): 1: 1197 2: 1197
3: 1198 4: 1199 5: 1197 6: 1197 7: 1197 8: 1198
Type: l1tf
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0166
Device-2: NVIDIA GK107M [GeForce GT 650M] driver: N/A bus ID: 01:00.0
chip ID: 10de:0fd1
Display: x11 server: X.Org 1.20.5 driver: intel compositor: compton
resolution: 1680x1050~60Hz
OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile v: 4.2 Mesa 19.2.6
compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Device-2: NVIDIA GK107 HDMI Audio driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:0e1b
Sound Server: ALSA v: k5.3.12-1-MANJARO
Network: Device-1: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: Dell
driver: atl1c v: 1.0.1.1-NAPI port: 2000 bus ID: 07:00.0 chip ID: 1969:1083
IF: enp7s0 state: down mac:
Device-2: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel port: 2000
bus ID: 08:00.0 chip ID: 8086:0887
IF: wlp8s0 state: up mac:
Drives: Local Storage: total: 931.51 GiB used: 232.52 GiB (25.0%)
ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-11Z10T0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: rev: 1A01 scheme: GPT
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus ID: 00:1f.2 chip ID: 8086.282a rev: 04
Partition: ID-1: / raw size: 687.08 GiB size: 675.29 GiB (98.28%)
used: 232.52 GiB (34.4%) fs: ext4 dev: /dev/sda2
Sensors: System Temperatures: cpu: 37.0 C mobo: N/A
Info: Processes: 229 Uptime: 3m Memory: 11.58 GiB used: 826.0 MiB (7.0%)
Init: systemd v: 242 Compilers: gcc: 9.2.0 clang: 9.0.0 Shell: bash v: 5.0.11
running in: urxvtd inxi: 3.0.36
here's the output, just some general info on my machine i suppose.
