During shutdown of computer, I see the following message:
/sys/oldroot busy
Ignoring. Shutdown
How to solve this ?
/sys/oldroot busy
Ignoring. Shutdown
How to solve this ?
Unless it actually prevents your system from shutting down, you can ignore it.
Notes:
Those with some Nvidia GPU, and depending on the system, might catch that message at shutdown, and in the past we had the /usr/lib/systemd/system-shutdown/nvidia.shutdown
script to “gracefully” rmmod the nvidia modules, hence not have that /sys/oldroot busy happening.
#!/bin/sh
# Remove all Nvidia modules on shutdown
# to avoid errors like
# [35509.312925] sd-umoun[56020]: Failed to unmount /oldroot: Device or resource busy
# [35509.317505] sd-umoun[56021]: Failed to unmount /oldroot/sys: Device or resource busy
# [35509.322349] shutdown[1]: Failed to finalize file systems, ignoring.
for MODULE in nvidia_drm nvidia_modeset nvidia_uvm nvidia
do
rmmod $MODULE
done
Apparently was removed as there was some change to systemd, but not quite sure, because i see that message too without that file, but as pointed out:
