Duplicate user-dirs.dirs in build iso
#1
I am making custom Manjaro distros based on Gnome and one thing I can’t figure out is the fact that I get duplicate user-dirs.dirs. So 2 of downloads folders, 2 of pictures, and so forth. I am using skel to copy customisations from my test build into new builds, so I am guessing it has something to do with the file user-dirs.dirs - but with or without it there is the same result. When I leave it on in the skel it contains the following:
# This file is written by xdg-user-dirs-update
# If you want to change or add directories, just edit the line you're
# interested in. All local changes will be retained on the next run.
# Format is XDG_xxx_DIR="$HOME/yyy", where yyy is a shell-escaped
# homedir-relative path, or XDG_xxx_DIR="/yyy", where /yyy is an
# absolute path. No other format is supported.
XDG_DESKTOP_DIR="$HOME/Desktop"
XDG_DOWNLOAD_DIR="$HOME/Downloads"
XDG_TEMPLATES_DIR="$HOME/Templates"
XDG_PUBLICSHARE_DIR="$HOME/Public"
XDG_DOCUMENTS_DIR="$HOME/Documents"
XDG_MUSIC_DIR="$HOME/Music"
XDG_PICTURES_DIR="$HOME/Pictures"
XDG_VIDEOS_DIR="$HOME/Videos"
Am I doing something wrong? Thanks for the help :wink:
EDIT: to clarify I am not getting a duplicate file “user-dirs.dirs” but duplicate folders like downloads an such and I suppose is because of that file.
#2
do not copy user-dirs.dirs in skel delete it if it exist
and make sure you have xdg-user-dirs package in packages-desktop
#3
Thank you! Your advice seems to have solve the issue but needs more testing. Will mark as solution if I can confirm it properly. Thanks!
#4
After more testing that solution didn’t seem to work…I wonder why
#5
your skel should not contain any home directory like download music video
check the case if they are included.
and add only needed config remove everything redundant.you can check manjaro-gnome-setting package content as example
#6
It is weird because sometimes I get that sometimes I don’t…anyways, thank you very much will keep and eye on it!
#7
Your skel should just contain any files you want to use instead of or on top of the defaults.
It could for example only contain your .config folder.
https://wiki.manjaro.org/index.php?title=Build_Manjaro_ISOs_with_buildiso
#8
Yup my skel only contains a few files/folders: .config .fonts . .local (with a few selected folders) .masterpdfeditor and .mozilla
Actually I will share the entire folder here if anyone wants to have a look at to maybe detect where the issue might be with the duplicate thingy :stuck_out_tongue:
#9
'LLo,
From what I understand of the problem, I would simply look for it (in hidden folder too !) in the buildiso working folder, so in /var/lib/m-tools/blah/blah/desktopfs/etc/skel that reflects ALL what you get in your $HOME (& so, an excess/hidden user-dirs.dirs !).
Once found & deleted, the buildiso -c option could save time for a quick rebuild, the whole problem remaining hidden in your original desktop-overlay ! :wink:
#10
Ok so this is all of the skel folder “insides” that I am using https://www.dropbox.com/s/zevedfon8aqswow/tromjaro.tar.xz?dl=0 - I have tried to remove all of the unnecessary files from there. I do customized a bit certain applications and settings so I need some stuff, but if anyone has the time do you think there’s something suspicious there that should not be kept?
Thanks
#11
remove pulse from .config
