Dump your inxi -Fxzc0 here and bookmark it
hardware
#384
System:    Host: martin-pc Kernel: 4.9.44-1-MANJARO x86_64 (64 bit gcc: 7.1.1)
           Desktop: KDE Plasma 5.10.4 (Qt 5.9.1) Distro: Manjaro Linux
Machine:   Device: desktop Mobo: ASUSTeK model: M5A97 EVO R2.0 v: Rev 1.xx BIOS: American Megatrends v: 2501 date: 04/09/2014
CPU:       Octa core AMD FX-8320 Eight-Core (Piledriver rev.0) (-MCP-) cache: 16384 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 60707
           clock speeds: max: 3792 MHz 1: 3792 MHz 2: 3792 MHz 3: 3792 MHz 4: 3792 MHz 5: 3792 MHz 6: 3792 MHz
           7: 3792 MHz 8: 3792 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Pitcairn PRO [Radeon HD 7850 / R7 265 / R9 270 1024SP]
           bus-ID: 01:00.0
           Display Server: x11 (X.Org 1.19.3) driver: radeon Resolution: 1920x1080@60.00hz
           OpenGL: renderer: Gallium 0.4 on AMD PITCAIRN (DRM 2.49.0 / 4.9.44-1-MANJARO, LLVM 4.0.1)
           version: 4.5 Mesa 17.1.6 Direct Render: Yes
Audio:     Card-1 Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA)
           driver: snd_hda_intel bus-ID: 00:14.2
           Card-2 Advanced Micro Devices [AMD/ATI] Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series]
           driver: snd_hda_intel bus-ID: 01:00.1
           Sound: Advanced Linux Sound Architecture v: k4.9.44-1-MANJARO
Network:   Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8168 v: 8.044.02-NAPI port: d000 bus-ID: 02:00.0
           IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 1120.2GB (4.4% used)
           ID-1: /dev/sdb model: TOSHIBA_DT01ACA1 size: 1000.2GB
           ID-2: /dev/sda model: Samsung_SSD_840 size: 120.0GB
Partition: ID-1: / size: 101G used: 38G (39%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 9.45GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 34.0C mobo: N/A gpu: 39.0
           Fan Speeds (in rpm): cpu: 0
Info:      Processes: 192 Uptime: 14 min Memory: 1450.2/7888.0MB Init: systemd Gcc sys: 7.1.1
           Client: Shell (bash 4.4.121) inxi: 2.3.27
#385
My first Manjaro machine
System:    Host: manjaro Kernel: 4.13.0-1-MANJARO x86_64 (64 bit gcc: 7.1.1) Desktop: N/A Distro: Manjaro Linux
Machine:   Device: laptop System: ASUSTeK product: GL752VW v: 1.0
           Mobo: ASUSTeK model: GL752VW v: 1.0 UEFI: American Megatrends v: GL752VW.213 date: 03/16/2016
Battery    BAT0: charge: 21.1 Wh 55.2% condition: 38.2/48.0 Wh (80%) model: ASUSTeK ASUS status: Discharging
CPU:       Quad core Intel Core i7-6700HQ (-HT-MCP-) cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 20744
           clock speeds: max: 3500 MHz 1: 2600 MHz 2: 2600 MHz 3: 2600 MHz 4: 2600 MHz 5: 2600 MHz 6: 2600 MHz
           7: 2600 MHz 8: 2600 MHz
Graphics:  Card-1: Intel HD Graphics 530 bus-ID: 00:02.0
           Card-2: NVIDIA GM107M [GeForce GTX 960M] bus-ID: 01:00.0
           Display Server: N/A drivers: nouveau,intel (unloaded: modesetting,fbdev,vesa) tty size: 151x25
Audio:     Card Intel Sunrise Point-H HD Audio driver: snd_hda_intel bus-ID: 00:1f.3
           Sound: Advanced Linux Sound Architecture v: k4.13.0-1-MANJARO
Network:   Card-1: Intel Wireless 8260 driver: iwlwifi bus-ID: 02:00.0
           Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 03:00.1
           IF: enp3s0f1 state: down mac: <filter>
Drives:    HDD Total Size: 1128.2GB (84.9% used)
           ID-1: /dev/sda model: SanDisk_SD8SNAT1 size: 128.0GB
           ID-2: /dev/sdb model: TOSHIBA_MQ01ABD1 size: 1000.2GB
Partition: ID-1: / size: 44G used: 6.7G (17%) fs: ext4 dev: /dev/sdb3
           ID-2: swap-1 size: 4.29GB used: 0.00GB (0%) fs: swap dev: /dev/sdb2
Sensors:   System Temperatures: cpu: 54.0C mobo: N/A gpu: 53.0
           Fan Speeds (in rpm): cpu: 1800
Info:      Processes: 210 Uptime: 1:04 Memory: 1816.7/7885.7MB Init: systemd Gcc sys: 7.1.1
           Client: Shell (zsh 5.4.1) inxi: 2.3.27
How to add kernel parameters
Shutdown -P now freezes the desktop
#386
           Desktop: KDE Plasma 5.10.5 (Qt 5.9.1) Distro: Manjaro Linux
Machine:   Device: desktop System: Gigabyte product: N/A
           Mobo: Gigabyte model: 970A-DS3P v: x.x UEFI: American Megatrends v: F1 date: 04/08/2013
Battery    hidpp__0: charge: 30% condition: NA/NA Wh model: Logitech M705 status: Discharging
CPU:       Quad core AMD Phenom II X4 955 (K10 rev.3) (-MCP-) cache: 2048 KB
           flags: (lm nx sse sse2 sse3 sse4a svm) bmips: 25730
           clock speeds: max: 3200 MHz 1: 3214 MHz 2: 3214 MHz 3: 3214 MHz 4: 3214 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Curacao XT / Trinidad XT [Radeon R7 370 / R9 270X/370X]
           bus-ID: 01:00.0
           Display Server: x11 (X.Org 1.19.3) drivers: ati,radeon (unloaded: modesetting)
           Resolution: 1600x900@60.00hz, 1920x1080@60.00hz, 1600x900@60.00hz
           OpenGL: renderer: Gallium 0.4 on AMD PITCAIRN (DRM 2.50.0 / 4.13.0-1-MANJARO, LLVM 4.0.1)
           driver: r8168 v: 8.044.02-NAPI port: d000 bus-ID: 03:00.0
Drives:    HDD Total Size: 3454.8GB (65.4% used)
           ID-1: /dev/sda model: WDC_WD10EZEX size: 1000.2GB
           ID-2: /dev/sdb model: ST9320325AS size: 320.1GB
           ID-3: /dev/sdc model: SanDisk_SDSSDP12 size: 126.0GB
           ID-4: /dev/sdd model: Hitachi_HUA72202 size: 2000.4GB
           ID-5: USB /dev/sde model: ProductCode size: 8.1GB
Partition: ID-1: / size: 24G used: 17G (76%) fs: ext4 dev: /dev/sdc6
           ID-2: /home size: 27G used: 19G (76%) fs: ext4 dev: /dev/sdc7
           ID-3: swap-1 size: 2.15GB used: 0.00GB (0%) fs: swap dev: /dev/sdc5
Sensors:   System Temperatures: cpu: 39.1C mobo: N/A gpu: 52.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 228 Uptime: 59 min Memory: 3782.7/7968.3MB Init: systemd Gcc sys: 7.1.1
#387
System: Host: alpha Kernel: 4.13.0-1-MANJARO x86_64 (64 bit gcc: 7.1.1)
Desktop: Xfce 4.12.4 (Gtk 2.24.31) Distro: Manjaro Linux
Machine: Device: desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x
UEFI: American Megatrends v: 0806 date: 07/12/2017
Battery hidpp__0: charge: N/A condition: NA/NA Wh
model: Logitech Wireless Touch Keyboard K400 Plus status: Discharging
hidpp__1: charge: N/A condition: NA/NA Wh
model: Logitech Wireless Mouse M325 status: Discharging
CPU: Octa core AMD Ryzen 7 1700 Eight-Core (Zen rev.1) (-HT-MCP-) cache: 4096 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 55916
clock speeds: max: 3500 MHz 1: 3493 MHz 2: 3493 MHz 3: 3493 MHz
4: 3493 MHz 5: 3493 MHz 6: 3493 MHz 7: 3493 MHz 8: 3493 MHz
9: 3493 MHz 10: 3493 MHz 11: 3493 MHz 12: 3493 MHz 13: 3493 MHz
14: 3493 MHz 15: 3493 MHz 16: 3493 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/580]
bus-ID: 22:00.0
Display Server: x11 (X.Org 1.19.3) driver: amdgpu
OpenGL: renderer: Gallium 0.4 on AMD POLARIS10 (DRM 3.18.0 / 4.13.0-1-MANJARO, LLVM 4.0.1)
Audio: Card-1 Advanced Micro Devices [AMD] Device 1457
driver: snd_hda_intel bus-ID: 24:00.3
Card-2 Advanced Micro Devices [AMD/ATI] Device aaf0
driver: snd_hda_intel bus-ID: 22:00.1
driver: r8168 v: 8.044.02-NAPI port: f000 bus-ID: 1e:00.0
IF: enp30s0 state: up speed: 1000 Mbps duplex: full mac:
Drives: HDD Total Size: 3017.2GB (35.5% used)
ID-1: /dev/nvme0n1 model: N/A size: 250.1GB
ID-2: /dev/sda model: ST3000DM008 size: 3000.6GB
ID-3: USB /dev/sdb model: Ultra size: 15.6GB
ID-4: USB /dev/sdc model: DataTraveler_2.0 size: 1.0GB
Partition: ID-1: / size: 211G used: 44G (22%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: swap-1 size: 18.51GB used: 0.00GB (0%) fs: swap dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 35.0C mobo: 34.0C gpu: 28.0
Fan Speeds (in rpm): cpu: 0 fan-1: 1136 fan-2: 0 fan-3: 870
Info: Processes: 280 Uptime: 1 day Memory: 1802.4/15985.2MB
#388
System:    Host: bigzbox Kernel: 4.9.48-1-MANJARO x86_64 (64 bit gcc: 7.1.1) Desktop: N/A
Machine:   Device: desktop System: Hewlett-Packard product: HP Z800 Workstation
           Mobo: Hewlett-Packard model: 0AECh v: D
           BIOS: Hewlett-Packard v: 786G5 v03.60 date: 02/24/2016
CPU(s):    2 Hexa core Intel Xeon X5650s (Westmere rev.2) (-HT-MCP-SMP-) cache: 24576 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 63960
           clock speeds: max: 2661 MHz 1: 1596 MHz 2: 1596 MHz 3: 1596 MHz 4: 1596 MHz 5: 1596 MHz
           6: 1596 MHz 7: 1596 MHz 8: 1596 MHz 9: 1596 MHz 10: 1596 MHz 11: 1596 MHz 12: 1596 MHz
           13: 1596 MHz 14: 1596 MHz 15: 1596 MHz 16: 1596 MHz 17: 1596 MHz 18: 1596 MHz 19: 1596 MHz
           20: 2661 MHz 21: 1596 MHz 22: 1596 MHz 23: 1596 MHz 24: 1596 MHz
Graphics:  Card: NVIDIA GP107 [GeForce GTX 1050 Ti] bus-ID: 0f:00.0
           Display Server: X.Org 1.19.3 driver: nvidia Resolution: 3440x1440@59.97hz
           OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2
           version: 4.5.0 NVIDIA 375.82 Direct Render: Yes
Audio:     Card-1 NVIDIA GP107GL High Definition Audio Controller driver: snd_hda_intel bus-ID: 0f:00.1
           Card-2 Intel 82801JI (ICH10 Family) HD Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture v: k4.9.48-1-MANJARO
Network:   Card-1: Broadcom Limited NetXtreme BCM5764M Gigabit Ethernet PCIe
           driver: tg3 v: 3.137 bus-ID: 01:00.0
           IF: enp1s0 state: down mac: <filter>
           Card-2: Broadcom Limited NetXtreme BCM5764M Gigabit Ethernet PCIe
           driver: tg3 v: 3.137 bus-ID: 02:00.0
Drives:    HDD Total Size: 4262.9GB (4.5% used)
           ID-1: /dev/sda model: Samsung_SSD_850 size: 250.1GB
           ID-2: /dev/sdb model: Samsung_SSD_850 size: 512.1GB
           ID-3: /dev/sdd model: WDC_WD1001FALS size: 1000.2GB
           ID-4: /dev/sdc model: WDC_WD2003FZEX size: 2000.4GB
           ID-5: /dev/sde model: Samsung_SSD_850 size: 500.1GB
Partition: ID-1: / size: 228G used: 5.6G (3%) fs: ext4 dev: /dev/sda3
           ID-2: /home size: 469G used: 8.6G (2%) fs: ext4 dev: /dev/sdb1
           ID-3: swap-1 size: 1.07GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 34.0C mobo: N/A gpu: 0.0:34C
Info:      Processes: 339 Uptime: 8:31 Memory: 2103.3/96672.0MB Init: systemd Gcc sys: 7.1.1
#389
System:    Host: <filter> Kernel: 4.19.6-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1 Desktop: Cinnamon 4.0.3
           dm: LightDM Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 20FN003LMH v: ThinkPad T460 serial: <filter> Chassis: type: 10
           serial: <filter>
           Mobo: LENOVO model: 20FN003LMH v: 0B98417 WIN serial: <filter> UEFI [Legacy]: LENOVO
           v: R06ET64W (1.38 ) date: 09/21/2018
Battery:   ID-1: BAT0 charge: 21.7 Wh condition: 21.7/23.5 Wh (92%) volts: 12.6/11.4 model: LGC 45N1113
           serial: <filter> status: Full
           ID-2: BAT1 charge: 43.0 Wh condition: 43.0/47.5 Wh (90%) volts: 12.4/10.8 model: SANYO 45N1767
           serial: <filter> status: Unknown
           Device-1: hid-f0:65:dd:98:aa:2a-battery model: ThinkPad Bluetooth Laser Mouse serial: N/A charge: N/A
           status: Discharging
CPU:       Topology: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake rev: 3
           L2 cache: 3072 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19204
           Speed: 800 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 722 2: 729 3: 721 4: 740
Graphics:  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
           chip ID: 8086:1916
           Display: x11 server: X.Org 1.20.3 driver: modesetting alternate: fbdev,intel,vesa tty: N/A
           OpenGL: renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2) v: 4.5 Mesa 18.2.6 compat-v: 3.0
           direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus ID: 00:1f.3 chip ID: 8086:9d70
           Sound Server: ALSA v: k4.19.6-1-MANJARO
Network:   Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: 3.2.6-k port: efa0 bus ID: 00:1f.6
           chip ID: 8086:1570
           IF: enp0s31f6 state: down mac: <filter>
           Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel port: efa0 bus ID: 04:00.0 chip ID: 8086:24f3
           IF: wlp4s0 state: up mac: <filter>
Drives:    Local Storage: total: 238.47 GiB used: 54.61 GiB (22.9%)
           ID-1: /dev/sda vendor: LITE-ON model: LCH-256V2S size: 238.47 GiB speed: 6.0 Gb/s serial: <filter>
Partition: ID-1: / size: 233.24 GiB used: 54.51 GiB (23.4%) fs: ext4 dev: /dev/dm-0
           ID-2: /boot size: 511.0 MiB used: 99.6 MiB (19.5%) fs: vfat dev: /dev/sda1
Sensors:   System Temperatures: cpu: 38.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 238 Uptime: 4h 43m Memory: 15.10 GiB used: 5.75 GiB (38.1%) Init: systemd v: 239 Compilers:
           gcc: 8.2.1 Shell: bash v: 4.4.23 running in: gnome-terminal inxi: 3.0.27
[Stable Update] 2017-09-02 - Kernels, Calamares, Mesa, Firefox, Python
Bluetooth crashes since updated to kernel 4.13.2
Trouble getting displays to work in presentation rooms
Pamac asking for password twice when installing some AUR packages
Flicking Screen on Intel Graphics
Cinnamon taking up 10% of CPU resources
Video playback choppy on 4K monitor but not on FHD monitor
#390
I began having disk errors, so I took the opportunity to upgrade to a 1T SSD and install a fresh Manjaro deepin ISO.
System:    Host: Asus Kernel: 4.9.47-1-MANJARO x86_64 (64 bit gcc: 7.1.1) Desktop: Gnome  (Gtk 3.22.19)
Machine:   Device: laptop System: ASUSTeK product: Q501LA v: 1.0
           Mobo: ASUSTeK model: Q501LA v: 1.0 UEFI: American Megatrends v: Q501LA.209 date: 07/31/2013
Battery    BAT0: charge: 48.6 Wh 86.7% condition: 56.0/66.9 Wh (84%) model: ASUSTeK N541-45 status: Discharging
CPU:       Dual core Intel Core i5-4200U (Haswell rev.1) (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9180
           clock speeds: max: 2600 MHz 1: 1599 MHz 2: 1664 MHz 3: 1760 MHz 4: 2055 MHz
Graphics:  Card: Intel Haswell-ULT Integrated Graphics Controller bus-ID: 00:02.0
           Display Server: x11 (X.Org 1.19.3) drivers: intel (unloaded: modesetting)
           Resolution: 1920x1080@59.97hz
           OpenGL: renderer: Mesa DRI Intel Haswell Mobile version: 4.5 Mesa 17.1.8 Direct Render: Yes
Audio:     Card-1 Intel 8 Series HD Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Card-2 Intel Haswell-ULT HD Audio Controller driver: snd_hda_intel bus-ID: 00:03.0
           Sound: Advanced Linux Sound Architecture v: k4.9.47-1-MANJARO
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8168 v: 8.044.02-NAPI port: e000 bus-ID: 02:00.0
           Card-2: Intel Wireless 7260 driver: iwlwifi bus-ID: 03:00.0
Drives:    HDD Total Size: 1000.2GB (17.3% used)
           ID-1: /dev/sda model: Samsung_SSD_850 size: 1000.2GB
Partition: ID-1: / size: 48G used: 7.8G (18%) fs: ext4 dev: /dev/sda4
           ID-2: /boot size: 93M used: 80M (93%) fs: ext4 dev: /dev/sda3
           ID-3: /home size: 854G used: 141G (18%) fs: ext4 dev: /dev/sda5
           ID-4: swap-1 size: 14.68GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 42.0C mobo: N/A
           Fan Speeds (in rpm): cpu: 2900
Info:      Processes: 187 Uptime: 9:22 Memory: 2025.6/11904.1MB Init: systemd Gcc sys: 7.1.1
#391
System:    Host: manjaro Kernel: 4.12.10-1-MANJARO x86_64 (64 bit gcc: 7.1.1) Desktop: Xfce 4.12.4 (Gtk 2.24.31)
Battery    BAT0: charge: 28.7 Wh 74.4% condition: 38.6/48.0 Wh (80%) model: ASUSTeK ASUS status: Charging
           clock speeds: max: 3500 MHz 1: 803 MHz 2: 873 MHz 3: 804 MHz 4: 885 MHz 5: 2764 MHz 6: 800 MHz
           7: 815 MHz 8: 3098 MHz
           Display Server: x11 (X.Org 1.19.3) drivers: nouveau,intel (unloaded: modesetting,fbdev,vesa)
           OpenGL: renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2)
           Sound: Advanced Linux Sound Architecture v: k4.12.10-1-MANJARO
Drives:    HDD Total Size: 1128.2GB (1.5% used)
Partition: ID-1: / size: 44G used: 13G (30%) fs: ext4 dev: /dev/sdb3
Sensors:   System Temperatures: cpu: 47.0C mobo: N/A gpu: N/A
           Fan Speeds (in rpm): cpu: 1900
Info:      Processes: 209 Uptime: 4 min Memory: 1265.6/7885.8MB Init: systemd Gcc sys: 7.1.1
           Client: Shell (zsh 5.4.2) inxi: 2.3.27
#392
System:    Host: laptop Kernel: 4.13.0-1-MANJARO x86_64 (64 bit gcc: 7.1.1)
Machine:   Device: laptop System: LENOVO product: 80M5 v: Lenovo U31-70
           Mobo: LENOVO model: Lenovo U31-70 v: SDK0J40709 WIN UEFI: LENOVO v: AFCN30WW(V2.02) date: 10/01/2015
Battery    BAT1: charge: 34.4 Wh 99.9% condition: 34.4/35.0 Wh (98%)
           model: 53 4D 50 00 31 31 00 00 6C 003250324D34314C status: Full
CPU:       Dual core Intel Core i3-5010U (Broadwell rev.4) (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 8384
           clock speeds: max: 2000 MHz 1: 2095 MHz 2: 2095 MHz 3: 2095 MHz 4: 2095 MHz
Graphics:  Card: Intel HD Graphics 5500 bus-ID: 00:02.0
           Display Server: N/A drivers: intel (unloaded: modesetting,fbdev) tty size: 188x27
Audio:     Card-1 Intel Wildcat Point-LP High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Card-2 Intel Broadwell-U Audio Controller driver: snd_hda_intel bus-ID: 00:03.0
           driver: r8168 v: 8.044.02-NAPI port: 3000 bus-ID: 02:00.0
           Card-2: Qualcomm Atheros QCA6164 802.11ac Wireless Network Adapter driver: ath10k_pci bus-ID: 03:00.0
           Card-3: Qualcomm Atheros usb-ID: 002-004
           IF: null-if-id state: N/A speed: N/A duplex: N/A mac: N/A
Drives:    HDD Total Size: 128.0GB (13.4% used)
           ID-1: /dev/sda model: SAMSUNG_MZYLF128 size: 128.0GB
Partition: ID-1: / size: 108G used: 7.6G (8%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 9.45GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 48.0C mobo: 48.0C
Info:      Processes: 168 Uptime: 6 min Memory: 1033.9/7901.0MB Init: systemd Gcc sys: 7.1.1
[Testing Update] 2017-09-05 - Linux v4.13, Mesa, Perl, LibreOffice
#393
$ inxi -Fxxxz
System:    Host: manjaro Kernel: 4.19.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1 Desktop: Xfce 4.12.4 tk: Gtk 2.24.32
           info: xfce4-panel wm: xfwm4 dm: LightDM 1.28.0 Distro: Manjaro Linux
Machine:   Type: Desktop System: Dell product: Precision WorkStation T3500 v: N/A serial: <filter> Chassis: type: 7
           serial: <filter>
           Mobo: Dell model: 09KPNV v: A00 serial: <filter> BIOS: Dell v: A17 date: 05/28/2013
CPU:       Topology: 6-Core model: Intel Xeon W3680 bits: 64 type: MT MCP arch: Nehalem rev: 2 L2 cache: 12.0 MiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 80037
           Speed: 1600 MHz min/max: 1596/3326 MHz boost: enabled Core speeds (MHz): 1: 1600 2: 1600 3: 1601 4: 1600 5: 1601
           6: 1600 7: 1600 8: 1600 9: 1600 10: 1600 11: 1600 12: 1600
Graphics:  Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: ASUSTeK driver: nvidia v: 415.25 bus ID: 02:00.0
           chip ID: 10de:1401
           Display: x11 server: X.Org 1.20.3 driver: nvidia resolution: 2560x1440~60Hz
           OpenGL: renderer: GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 415.25 direct render: Yes
Audio:     Device-1: Intel 82801JI HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:3a3e
           Device-2: NVIDIA GM206 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 02:00.1
           chip ID: 10de:0fba
           Sound Server: ALSA v: k4.19.13-1-MANJARO
Network:   Device-1: Broadcom and subsidiaries NetXtreme BCM5761 Gigabit Ethernet PCIe vendor: Dell driver: tg3 v: 3.137
           port: dc80 bus ID: 05:00.0 chip ID: 14e4:1681
           IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 6.43 TiB used: 4.82 TiB (75.0%)
           ID-1: /dev/sda vendor: A-Data model: SP900 size: 59.63 GiB speed: 3.0 Gb/s serial: <filter> rev: 2a scheme: MBR
           ID-2: /dev/sdb vendor: Seagate model: ST3000VX000-1ES166 size: 2.73 TiB speed: 3.0 Gb/s rotation: 7200 rpm
           serial: <filter> rev: CV26 scheme: GPT
           ID-3: /dev/sdc vendor: Western Digital model: WD2003FYPS-27W9B0 size: 1.82 TiB speed: 3.0 Gb/s rotation: 5400 rpm
           serial: <filter> rev: 5G09 scheme: MBR
           ID-4: /dev/sdd vendor: Western Digital model: WD2003FYPS-27W9B0 size: 1.82 TiB speed: 3.0 Gb/s rotation: 5400 rpm
Partition: ID-1: / size: 48.00 GiB used: 21.16 GiB (44.1%) fs: btrfs dev: /dev/sda1
           ID-2: /boot size: 487.9 MiB used: 166.9 MiB (34.2%) fs: ext3 dev: /dev/sda3
           ID-3: /home size: 2.69 TiB used: 1.78 TiB (66.2%) fs: ext4 dev: /dev/sdb1
           ID-4: swap-1 size: 6.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 26.0 C mobo: 24.0 C gpu: nvidia temp: 46 C
           Fan Speeds (RPM): cpu: 916 mobo: 971 gpu: nvidia fan: 31%
Info:      Processes: 282 Uptime: 21m Memory: 11.72 GiB used: 2.35 GiB (20.0%) Init: systemd v: 239 Compilers: gcc: 8.2.1
           Shell: bash v: 4.4.23 running in: xfce4-terminal inxi: 3.0.28
$ sudo sensors-detect
# sensors-detect revision $Revision$
# System: Dell Inc. Precision WorkStation T3500
# Board: Dell Inc. 09KPNV
# Kernel: 4.17.6-1-MANJARO x86_64
# Processor: Intel(R) Xeon(R) CPU W3680 @ 3.33GHz (6/44/2)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no):
Module cpuid loaded successfully.
Silicon Integrated Systems SIS5595...                       No
VIA VT82C686 Integrated Sensors...                          No
VIA VT8231 Integrated Sensors...                            No
AMD K8 thermal sensors...                                   No
AMD Family 10h thermal sensors...                           No
AMD Family 11h thermal sensors...                           No
AMD Family 12h and 14h thermal sensors...                   No
AMD Family 15h thermal sensors...                           No
AMD Family 16h thermal sensors...                           No
AMD Family 15h power sensors...                             No
AMD Family 16h power sensors...                             No
Intel digital thermal sensor...                             Success!
    (driver `coretemp')
Intel AMB FB-DIMM thermal sensor...                         No
Intel 5500/5520/X58 thermal sensor...                       No
VIA C7 thermal sensor...                                    No
VIA Nano thermal sensor...                                  No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no):
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor/ITE'...               No
Trying family `SMSC'...                                     Yes
Found `SMSC SCH5504-NS Super IO'
    (no hardware monitoring capabilities)
Probing for Super-I/O at 0x4e/0x4f
Trying family `SMSC'...                                     No
Trying family `VIA/Winbond/Nuvoton/Fintek'...               No
Trying family `ITE'...                                      No
Some systems (mainly servers) implement IPMI, a set of common interfaces
through which system health data may be retrieved, amongst other things.
We first try to get the information from SMBIOS. If we don't find it
there, we have to read from arbitrary I/O ports to probe for such
interfaces. This is normally safe. Do you want to scan for IPMI
interfaces? (YES/no):
Probing for `IPMI BMC KCS' at 0xca0...                      No
Probing for `IPMI BMC SMIC' at 0xca8...                     No
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (YES/no):
Probing for `National Semiconductor LM78' at 0x290...       No
Probing for `National Semiconductor LM79' at 0x290...       No
Probing for `Winbond W83781D' at 0x290...                   No
Probing for `Winbond W83782D' at 0x290...                   No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no):
Using driver `i2c-i801' for device 0000:00:1f.3: Intel ICH10
Module i2c-dev loaded successfully.
Next adapter: SMBus I801 adapter at ece0 (i2c-0)
Do you want to scan it? (YES/no/selectively):
Client found at address 0x18
Probing for `Analog Devices ADM1021'...                     No
Probing for `Analog Devices ADM1021A/ADM1023'...            No
Probing for `Maxim MAX1617'...                              No
Probing for `Maxim MAX1617A'...                             No
Probing for `Maxim MAX1668'...                              No
Probing for `Maxim MAX1805'...                              No
Probing for `Maxim MAX1989'...                              No
Probing for `Maxim MAX6655/MAX6656'...                      No
Probing for `TI THMC10'...                                  No
Probing for `National Semiconductor LM84'...                No
Probing for `Genesys Logic GL523SM'...                      No
Probing for `Onsemi MC1066'...                              No
Probing for `Maxim MAX1618'...                              No
Probing for `Maxim MAX1619'...                              No
Probing for `National Semiconductor LM82/LM83'...           No
Probing for `Maxim MAX6654'...                              No
Probing for `Maxim MAX6690'...                              No
Probing for `Maxim MAX6680/MAX6681'...                      No
Probing for `Maxim MAX6695/MAX6696'...                      No
Probing for `Texas Instruments TMP400'...                   No
Probing for `Texas Instruments AMC6821'...                  No
Probing for `National Semiconductor LM95233'...             No
Probing for `National Semiconductor LM95234'...             No
Probing for `National Semiconductor LM95235'...             No
Probing for `National Semiconductor LM95245'...             No
Probing for `National Semiconductor LM64'...                No
Probing for `SMSC EMC1047'...                               No
Probing for `SMSC EMC1402'...                               No
Probing for `SMSC EMC1403'...                               No
Probing for `SMSC EMC1404'...                               No
Probing for `ST STTS424'...                                 No
Probing for `ST STTS424E'...                                No
Probing for `ST STTS2002'...                                No
Probing for `ST STTS3000'...                                No
Probing for `NXP SE97/SE97B'...                             No
Probing for `NXP SE98'...                                   No
Probing for `Analog Devices ADT7408'...                     No
Probing for `IDT TS3000/TSE2002'...                         No
Probing for `IDT TSE2004'...                                No
Probing for `IDT TS3001'...                                 No
Probing for `Maxim MAX6604'...                              No
Probing for `Microchip MCP9804'...                          No
Probing for `Microchip MCP98242'...                         No
Probing for `Microchip MCP98243'...                         Success!
    (confidence 5, driver `jc42')
Probing for `Microchip MCP98244'...                         No
Probing for `Microchip MCP9843'...                          No
Probing for `ON CAT6095/CAT34TS02'...                       No
Probing for `Atmel AT30TS00'...                             No
Client found at address 0x19
Probing for `National Semiconductor LM95231'...             No
Probing for `National Semiconductor LM95241'...             No
Client found at address 0x1a
Client found at address 0x1b
Client found at address 0x1c
Probing for `Texas Instruments TMP421'...                   No
Probing for `Texas Instruments TMP441'...                   No
Probing for `SMSC EMC1072'...                               No
Probing for `SMSC EMC1073'...                               No
Probing for `SMSC EMC1074'...                               No
Client found at address 0x1d
Probing for `TI / National Semiconductor ADC128D818'...     No
Client found at address 0x50
Probing for `Analog Devices ADM1033'...                     No
Probing for `Analog Devices ADM1034'...                     No
Probing for `SPD EEPROM'...                                 Yes
    (confidence 8, not a hardware monitoring chip)
Probing for `EDID EEPROM'...                                No
Client found at address 0x51
Client found at address 0x52
Client found at address 0x53
Next adapter: NVIDIA i2c adapter 0 at 2:00.0 (i2c-1)
Do you want to scan it? (yes/NO/selectively): y
Next adapter: NVIDIA i2c adapter 2 at 2:00.0 (i2c-2)
Next adapter: NVIDIA i2c adapter 6 at 2:00.0 (i2c-3)
Next adapter: NVIDIA i2c adapter 7 at 2:00.0 (i2c-4)
Next adapter: NVIDIA i2c adapter 8 at 2:00.0 (i2c-5)
Next adapter: NVIDIA i2c adapter 9 at 2:00.0 (i2c-6)
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `jc42':
  * Bus `SMBus I801 adapter at ece0'
    Busdriver `i2c_i801', I2C address 0x18
    Chip `Microchip MCP98243' (confidence: 5)
    Busdriver `i2c_i801', I2C address 0x19
    Busdriver `i2c_i801', I2C address 0x1a
    Busdriver `i2c_i801', I2C address 0x1b
    Busdriver `i2c_i801', I2C address 0x1c
    Busdriver `i2c_i801', I2C address 0x1d
Driver `coretemp':
  * Chip `Intel digital thermal sensor' (confidence: 9)
Do you want to generate /etc/conf.d/lm_sensors? (YES/no): y
Created symlink /etc/systemd/system/multi-user.target.wants/lm_sensors.service → /usr/lib/systemd/system/lm_sensors.service.
Unloading i2c-dev... OK
Unloading cpuid... OK
[Testing Update] 2017-09-11 - Kernels, KDE Framework, Mesa, GCC, Removal of OpenRC
Unknown freezes since two(?) weeks
External drives gone while mv
Dez 16 19:31:56 manjaro kernel: nvidia-modeset: WARNING: GPU:0: Lost display notification (0:0x00000000); continuing
Grub2 text overlay over default Manjaro Grub menu
(temp unstable) update crashed Manjaro
[Testing Update] 2018-07-14 - Kernels, KDE (Plasma, Apps), Firefox, Thunderbird, Mesa, Haskell
#394
Resuming in non X mode: xrandr not found. For package install advice run: inxi --recommends
System: Host: eribert-TP460P Kernel: 4.9.48-1-MANJARO x86_64 (64 bit gcc: 7.1.1)
Machine: Device: laptop System: LENOVO product: 20FW0018AD v: ThinkPad T460p
Mobo: LENOVO model: 20FW0018AD v: SDK0J40705 WIN UEFI: LENOVO v: R07ET78W (2.18 ) date: 06/30/2017
Battery BAT0: charge: 33.0 Wh 69.9% condition: 47.2/47.5 Wh (99%) model: SANYO 45N1767 status: Discharging
CPU: Quad core Intel Core i5-6300HQ (-MCP-) cache: 6144 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 18436
clock speeds: max: 3200 MHz 1: 899 MHz 2: 899 MHz 3: 899 MHz 4: 899 MHz
Graphics: Card: Intel HD Graphics 530 bus-ID: 00:02.0
Display Server: N/A drivers: intel (unloaded: modesetting) tty size: 156x37
Network: Card-1: Intel Ethernet Connection (2) I219-LM driver: e1000e v: 3.2.6-k bus-ID: 00:1f.6
Card-2: Intel Wireless 8260 driver: iwlwifi bus-ID: 03:00.0
IF: wlp3s0 state: up mac:
Drives: HDD Total Size: 256.1GB (13.6% used)
ID-1: /dev/sda model: SAMSUNG_MZ7TY256 size: 256.1GB
Partition: ID-1: / size: 79G used: 33G (44%) fs: ext4 dev: /dev/sda5
Info: Processes: 203 Uptime: 1:18 Memory: 2413.3/7842.5MB Init: systemd Gcc sys: 7.1.1
#395
System:    Host: ceyhun-pc Kernel: 4.13.10-1-MANJARO x86_64 bits: 64 gcc: 7.2.0
           Desktop: Gnome 3.26.1 (Gtk 3.22.24) Distro: Manjaro Linux
Machine:   Device: laptop System: TOSHIBA product: Satellite L50-A667 v: PSKK8V-008005A3 serial: N/A
           Mobo: TOSHIBA model: VG10S serial: N/A UEFI: TOSHIBA v: 1.60 date: 01/08/2014
Battery    BAT0: charge: 17.9 Wh 40.5% condition: 44.2/45.1 Wh (98%)
           model: PEGA G71C000FM110 status: Discharging
CPU:       Quad core Intel Core i7-4700MQ (-HT-MCP-) arch: Haswell rev.3 cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 19167
           clock speeds: max: 3400 MHz 1: 2394 MHz 2: 2394 MHz 3: 2394 MHz 4: 2394 MHz 5: 2394 MHz 6: 2394 MHz
           7: 2394 MHz 8: 2394 MHz
Graphics:  Card-1: Intel 4th Gen Core Processor Integrated Graphics Controller bus-ID: 00:02.0
           Card-2: NVIDIA GK208M [GeForce GT 740M] bus-ID: 01:00.0
           Display Server: wayland (X.Org 1.19.5 ) driver: intel Resolution: 1366x768@59.80hz
           OpenGL: renderer: Mesa DRI Intel Haswell Mobile version: 4.5 Mesa 17.2.3 Direct Render: Yes
Audio:     Card-1 Intel 8 Series/C220 Series High Definition Audio Controller
           Card-2 Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.13.10-1-MANJARO
Network:   Card: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter driver: ath9k bus-ID: 03:00.0
Drives:    HDD Total Size: 1000.2GB (15.2% used)
           ID-1: /dev/sda model: TOSHIBA_MQ01ABD1 size: 1000.2GB
Partition: ID-1: / size: 181G used: 21G (12%) fs: ext4 dev: /dev/sda2
           ID-2: /home size: 205G used: 112G (58%) fs: ext4 dev: /dev/sda4
           ID-3: swap-1 size: 11.22GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Info:      Processes: 241 Uptime: 8:50 Memory: 2601.8/7899.3MB Init: systemd Gcc sys: 7.2.0
           Client: Shell (fish) inxi: 2.3.40
Slow GPU performance with Intel on Bumblebee
"Error writing selection data: Error writing to file descriptor: Broken pipe" in Gedit
#396
System:    Host: bebugz-pc Kernel: 4.9.50-1-MANJARO x86_64 bits: 64 gcc: 7.2.0 Desktop: i3 4.14-non-git
Machine:   Device: laptop System: Apple product: MacBookPro12 1 v: 1.0 serial: N/A
           Mobo: Apple model: Mac-E43C1C25D4880AD6 v: MacBookPro12 1 serial: N/A
           UEFI: Apple v: MBP121.88Z.0167.B24.1702161608 date: 02/16/2017
Battery    BAT0: charge: 29.7 Wh 44.8% condition: 66.3/74.8 Wh (89%) model: SMP bq20z451 status: Charging
CPU:       Dual core Intel Core i5-5287U (-HT-MCP-) arch: Broadwell rev.4 cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 11605
           clock speeds: max: 3300 MHz 1: 910 MHz 2: 2135 MHz 3: 2104 MHz 4: 1989 MHz
Graphics:  Card: Intel Iris Graphics 6100 bus-ID: 00:02.0
           Display Server: x11 (X.Org 1.19.3 ) drivers: intel (unloaded: modesetting)
           Resolution: 2560x1600@59.97hz
           OpenGL: renderer: Mesa DRI Intel Iris 6100 (Broadwell GT3) version: 4.5 Mesa 17.2.0 Direct Render: Yes
           Sound: Advanced Linux Sound Architecture v: k4.9.50-1-MANJARO
Network:   Card: Broadcom Limited BCM43602 802.11ac Wireless LAN SoC driver: brcmfmac bus-ID: 03:00.0
Drives:    HDD Total Size: 500.3GB (1.2% used)
           ID-1: /dev/sda model: APPLE_SSD_SM0512 size: 500.3GB
Partition: ID-1: / size: 85G used: 5.7G (8%) fs: ext4 dev: /dev/sda5
Sensors:   System Temperatures: cpu: 64.0C mobo: N/A
Info:      Processes: 191 Uptime: 25 min Memory: 1570.4/7891.1MB Init: systemd Gcc sys: 7.2.0
           Client: Shell (bash 4.4.121) inxi: 2.3.38
YouTube goes black both in full screen and windowed mode in Vivaldi and Palemoon
#399
System:    Host: hagrids-hut Kernel: 4.9.50-1-MANJARO x86_64 bits: 64 gcc: 7.2.0 Desktop: Gnome  (Gtk 3.22.21)
Machine:   Device: desktop Mobo: MSI model: Z270 GAMING PRO CARBON (MS-7A63) v: 1.0 serial: N/A
           UEFI: American Megatrends v: 1.50 date: 06/27/2017
CPU:       Quad core Intel Core i7-7700K (-HT-MCP-) arch: Skylake rev.9 cache: 8192 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 33612
           clock speeds: max: 4500 MHz 1: 799 MHz 2: 799 MHz 3: 799 MHz 4: 799 MHz 5: 799 MHz 6: 799 MHz
           7: 799 MHz 8: 799 MHz
Graphics:  Card: Intel HD Graphics 630 bus-ID: 00:02.0
           OpenGL: renderer: Mesa DRI Intel HD Graphics 630 (Kaby Lake GT2)
Audio:     Card Intel 200 Series PCH HD Audio driver: snd_hda_intel bus-ID: 00:1f.3
Network:   Card: Intel Ethernet Connection (2) I219-V driver: e1000e v: 3.2.6-k bus-ID: 00:1f.6
           IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 3370.7GB (27.4% used)
           ID-2: /dev/sdb model: KINGSTON_SV300S3 size: 120.0GB
           ID-3: USB /dev/sdc model: Backup+_Desk size: 3000.6GB
Partition: ID-1: / size: 20G used: 6.8G (38%) fs: ext4 dev: /dev/sdb2
           ID-2: /home size: 74G used: 613M (1%) fs: ext4 dev: /dev/sdb4
           ID-3: swap-1 size: 18.35GB used: 0.00GB (0%) fs: swap dev: /dev/sdb3
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C
Info:      Processes: 220 Uptime: 16:06 Memory: 2743.1/15937.1MB Init: systemd Gcc sys: 7.2.0
#400
System: Host: RyzenPC-Ubuntu Kernel: 4.10.0-35-generic x86_64 (64 bit gcc: 6.3.0)
Desktop: Gnome 3.24.2 (Gtk 3.22.11-0ubuntu3) Distro: Ubuntu 17.04
Machine: Device: desktop Mobo: MSI model: X370 SLI PLUS (MS-7A33) v: 2.0
UEFI: American Megatrends v: 3.50 date: 07/31/2017
CPU: Octa core AMD Ryzen 7 1700 Eight-Core (-HT-MCP-) cache: 4096 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 47993
clock speeds: max: 3000 MHz 1: 1550 MHz 2: 1550 MHz 3: 1550 MHz
4: 1550 MHz 5: 1550 MHz 6: 1550 MHz 7: 1550 MHz 8: 1550 MHz
9: 1550 MHz 10: 1550 MHz 11: 1550 MHz 12: 1550 MHz 13: 1550 MHz
14: 1550 MHz 15: 1550 MHz 16: 1550 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Polaris12 bus-ID: 23:00.0
Display Server: X.Org 1.19.3 driver: N/A
Resolution: 1680x1050@59.88hz
GLX Renderer: Gallium 0.4 on AMD POLARIS12 (DRM 3.9.0 / 4.10.0-35-generic, LLVM 4.0.0)
GLX Version: 3.0 Mesa 17.0.7 Direct Rendering: Yes
driver: snd_hda_intel bus-ID: 25:00.3
Card-2 Advanced Micro Devices [AMD/ATI] Device aae0
driver: snd_hda_intel bus-ID: 23:00.1
Sound: Advanced Linux Sound Architecture v: k4.10.0-35-generic
driver: r8169 v: 2.3LK-NAPI port: f000 bus-ID: 1e:00.0
Drives: HDD Total Size: 4525.9GB (3.2% used)
ID-1: /dev/sda model: Crucial_CT525MX3 size: 525.1GB
ID-2: /dev/sdb model: WDC_WD40EFRX size: 4000.8GB
Partition: ID-1: / size: 35G used: 5.8G (18%) fs: ext4 dev: /dev/sda7
ID-2: /boot size: 9.6G used: 220M (3%) fs: ext4 dev: /dev/sda5
ID-3: /home size: 45G used: 15G (34%) fs: ext4 dev: /dev/sda8
ID-4: swap-1 size: 19.40GB used: 0.00GB (0%) fs: swap dev: /dev/sda6
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: No active sensors found. Have you configured your sensors yet? mobo: N/A gpu: 36.0
Info: Processes: 402 Uptime: 43 min Memory: 2691.9/16058.2MB
Init: systemd runlevel: 5 Gcc sys: 6.3.0
Client: Shell (bash 4.4.71) inxi: 2.3.8
Failed to start Live-System on Ryzen/RX550
#401
System: Host: CT86NET-DESKTOP Kernel: 4.13.2-1-MANJARO x86_64 bits: 64 gcc: 7.2.0
Machine: Device: desktop Mobo: ASUSTeK model: P6X58D PREMIUM v: Rev 1.xx serial: N/A
BIOS: American Megatrends v: 1501 date: 05/10/2011
CPU: Quad core Intel Core i7 930 (-HT-MCP-) arch: Nehalem rev.5 cache: 8192 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 22463
clock speeds: max: 2801 MHz 1: 2806 MHz 2: 2806 MHz 3: 2806 MHz 4: 2806 MHz
5: 2806 MHz 6: 2806 MHz 7: 2806 MHz 8: 2806 MHz
Graphics: Card: NVIDIA GP107 [GeForce GTX 1050 Ti] bus-ID: 03:00.0
Display Server: N/A driver: nvidia tty size: 90x30
Audio: Card-1 NVIDIA GP107GL High Def. Audio Controller
driver: snd_hda_intel bus-ID: 03:00.1
Card-3 Logitech QuickCam Communicate STX driver: USB Audio usb-ID: 006-002
Sound: Advanced Linux Sound Architecture v: k4.13.2-1-MANJARO
Network: Card-1: Marvell 88E8056 PCI-E Gigabit Ethernet Controller
driver: sky2 v: 1.30 port: c800 bus-ID: 05:00.0
Card-2: Marvell 88E8056 PCI-E Gigabit Ethernet Controller
driver: sky2 v: 1.30 port: d800 bus-ID: 06:00.0
IF: enp6s0 state: down mac:
Card-3: Microsoft Xbox 360 Wireless Adapter usb-ID: 007-002
IF: null-if-id state: N/A mac: N/A
Drives: HDD Total Size: 678.2GB (48.7% used)
ID-1: /dev/sdb model: Samsung_SSD_840 size: 250.1GB
ID-2: /dev/sdc model: WDC_WD3000HLFS size: 300.1GB
ID-3: /dev/sda model: Samsung_SSD_840 size: 128.0GB
Partition: ID-1: / size: 117G used: 14G (12%) fs: ext4 dev: /dev/dm-0
Sensors: System Temperatures: cpu: 35.0C mobo: 34.0C gpu: 0.0:54C
Fan Speeds (in rpm): cpu: 948 psu: 0 sys-1: 0 sys-2: 0 sys-3: 0
Info: Processes: 227 Uptime: 5 min Memory: 1513.2/16106.0MB
Init: systemd Gcc sys: 7.2.0 Client: Shell (bash 4.4.121) inxi: 2.3.38
#402
System:    Host: manjaro Kernel: 4.9.50-1-MANJARO x86_64 bits: 64 gcc: 7.2.0 Console: tty 1
Machine:   Device: desktop Mobo: MSI model: X370 SLI PLUS (MS-7A33) v: 2.0 serial: N/A
CPU:       Octa core AMD Ryzen 7 1700 Eight-Core (-HT-MCP-) arch: Zen rev.1 cache: 4096 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 48012
           clock speeds: max: 3000 MHz 1: 1550 MHz 2: 1550 MHz 3: 1550 MHz 4: 1550 MHz 5: 1550 MHz 6: 1550 MHz
           7: 1550 MHz 8: 1550 MHz 9: 1550 MHz 10: 1550 MHz 11: 1550 MHz 12: 1550 MHz 13: 1550 MHz 14: 1550 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Lexa PRO [Radeon RX 550] bus-ID: 23:00.0
           Display Server: X.org 1.19.3 driver: N/A tty size: 210x65 Advanced Data: N/A out of X
Audio:     Card-1 Advanced Micro Devices [AMD] Device 1457 driver: snd_hda_intel bus-ID: 25:00.3
           Card-2 Advanced Micro Devices [AMD/ATI] Device aae0 driver: snd_hda_intel bus-ID: 23:00.1
           IF: enp30s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 4541.5GB (0.0% used)
           ID-3: USB /dev/sdc model: Ultra size: 15.6GB
Partition: ID-1: / size: 12G used: 65M (1%) fs: overlay dev: N/A
Sensors:   System Temperatures: cpu: 36.9C mobo: N/A
Info:      Processes: 224 Uptime: 7 min Memory: 270.2/16064.8MB Init: systemd Gcc sys: 7.2.0
#403
[bob@Manjaro ~]$ inxi -Fxzc0
System: Host: Manjaro Kernel: 4.14.0-1-MANJARO x86_64 bits: 64 gcc: 7.2.0
Machine: Device: desktop System: LENOVO product: 10181 v: Lenovo K450e serial: N/A
Mobo: LENOVO model: N/A v: 31900058 STD serial: N/A
BIOS: LENOVO v: I1KT38AUS date: 06/10/2014
Battery hidpp__0: charge: 50% condition: NA/NA Wh
model: Logitech M570 status: Discharging
CPU: Quad core Intel Core i5-4460 (-MCP-)
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 25555
clock speeds: max: 3400 MHz 1: 3192 MHz 2: 3192 MHz 3: 3192 MHz
4: 3192 MHz
Graphics: Card: NVIDIA GK208 [GeForce GT 720] bus-ID: 01:00.0
Display Server: x11 (X.Org 1.19.3 ) driver: nvidia
Resolution: 1920x1080@59.93hz
OpenGL: renderer: GeForce GT 720/PCIe/SSE2
Audio: Card-1 Intel 8 Series/C220 Series High Def. Audio Controller
Card-2 NVIDIA GK208 HDMI/DP Audio Controller
Sound: Advanced Linux Sound Architecture v: k4.14.0-1-MANJARO
Network: Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
Card-2: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter
driver: rtl8821ae port: c000 bus-ID: 04:00.0
IF: wlp4s0 state: down mac:
Drives: HDD Total Size: 1500.3GB (2.3% used)
ID-2: USB /dev/sdb model: OneTouch size: 500.1GB
Partition: ID-1: / size: 908G used: 25G (3%) fs: ext4 dev: /dev/sda1
Sensors: System Temperatures: cpu: 29.8C mobo: 27.8C gpu: 0.0:50C
Info: Processes: 171 Uptime: 40 min Memory: 875.6/7920.4MB
Client: Shell (bash 4.4.121) inxi: 2.3.39
#404
[master-andreas@master-pc ~]$ inxi -Fxzc0
System:    Host: master-pc Kernel: 4.13.3-2-MANJARO x86_64 bits: 64 gcc: 7.2.0 Desktop: i3 4.14
Machine:   Device: laptop System: LENOVO product: 80TL v: Lenovo V110-15ISK serial: N/A
           Mobo: LENOVO model: Lenovo V110-15ISK v: NO DPK serial: N/A UEFI: LENOVO v: 1KCN28WW date: 11/15/2016
Battery    BAT0: charge: 30.7 Wh 96.9% condition: 31.7/32.0 Wh (99%) model: LGC L15L4A02 status: N/A
CPU:       Dual core Intel Core i3-6006U (-HT-MCP-) arch: Skylake rev.3 cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 7970
           clock speeds: max: 2000 MHz 1: 2000 MHz 2: 2000 MHz 3: 2000 MHz 4: 2000 MHz
Graphics:  Card-1: Intel HD Graphics 520 bus-ID: 00:02.0
           Card-2: Advanced Micro Devices [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430]
           bus-ID: 01:00.0
           Display Server: x11 (X.Org 1.19.3 ) drivers: ati,radeon,intel (unloaded: modesetting)
           Resolution: 1366x768@60.02hz
           version: 4.5 Mesa 17.2.1 Direct Render: Yes
Audio:     Card Intel Sunrise Point-LP HD Audio driver: snd_hda_intel bus-ID: 00:1f.3
           Sound: Advanced Linux Sound Architecture v: k4.13.3-2-MANJARO
Network:   Card-1: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi bus-ID: 02:00.0
           driver: r8168 v: 8.044.02-NAPI port: c000 bus-ID: 03:00.0
Drives:    HDD Total Size: 128.0GB (60.6% used)
           ID-1: /dev/sda model: ADATA_SP900 size: 128.0GB
Partition: ID-1: / size: 30G used: 15G (54%) fs: ext4 dev: /dev/sda2
           ID-2: /home size: 80G used: 50G (67%) fs: ext4 dev: /dev/sda4
           ID-3: swap-1 size: 8.66GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 42.0C mobo: 39.0C gpu: 37.0
Info:      Processes: 137 Uptime: 2:53 Memory: 1620.6/3752.8MB Init: systemd Gcc sys: 7.2.0
#405
[username@username-pc ~]$ inxi -Fxzc0
System:    Host: username-pc Kernel: 4.19.24-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1 Desktop: KDE Plasma 5.15.1
Machine:   Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
           Mobo: ASUSTeK model: SABERTOOTH Z97 MARK 1 v: Rev 1.xx serial: <filter> UEFI: American Megatrends v: 1008
           date: 05/29/2014
CPU:       Topology: Quad Core model: Intel Core i7-4790 bits: 64 type: MT MCP arch: Haswell rev: 3 L2 cache: 8192 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57588
           Speed: 1000 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 975 2: 959 3: 942 4: 979 5: 944 6: 919 7: 949 8: 955
Graphics:  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte driver: nvidia v: 390.87 bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.3 driver: nvidia resolution: 1920x1080~60Hz, 1920x1080~60Hz
           OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 390.87 direct render: Yes
Audio:     Device-1: Intel 9 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
           Device-2: NVIDIA GP106 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 01:00.1
           Device-3: Creative Labs EMU20k2 [Sound Blaster X-Fi Titanium Series] driver: snd_ctxfi v: kernel bus ID: 05:00.0
           Sound Server: ALSA v: k4.19.24-1-MANJARO
Network:   Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e v: 3.2.6-k port: f040 bus ID: 00:19.0
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8168 v: 8.045.08-NAPI
           port: d000 bus ID: 06:00.0
           IF: enp6s0 state: down mac: <filter>
           Device-3: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: c000 bus ID: 0a:00.0
           IF: wlp10s0 state: up mac: <filter>
Drives:    Local Storage: total: 1.61 TiB used: 1021.77 GiB (61.9%)
           ID-1: /dev/sda vendor: Kingston model: SV300S37A240G size: 223.57 GiB
           ID-2: /dev/sdb vendor: Seagate model: ST31000524AS size: 931.51 GiB
           ID-3: /dev/sdc vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
           ID-4: /dev/sdd type: USB vendor: Kingston model: DataTraveler 3.0 size: 28.88 GiB
Partition: ID-1: / size: 440.25 GiB used: 169.05 GiB (38.4%) fs: ext4 dev: /dev/dm-0
           ID-2: swap-1 size: 17.17 GiB used: 5.2 MiB (0.0%) fs: swap dev: /dev/dm-1
Sensors:   System Temperatures: cpu: 32.0 C mobo: 29.8 C gpu: nvidia temp: 55 C
           Fan Speeds (RPM): cpu: 0 gpu: nvidia fan: 0%
Info:      Processes: 280 Uptime: 5h 00m Memory: 15.61 GiB used: 4.86 GiB (31.2%) Init: systemd Compilers: gcc: 8.2.1
           clang: 7.0.1 Shell: bash v: 5.0.0 inxi: 3.0.30
Nvidia 390 breaks dependency linux418-nvidia-390xx
Keys remapped after update
VMware kernel headers for 4.9.51-1-MANJARO not found
Automatically mounting spare internal HDD on startup
Not recognizing USB
Slow and inconsistent wifi with TP-Link Archer T9E AC1900
