Kernel: 5.10.84-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=40809886-d17c-433b-876f-89a03d053b64 rw quiet splash apparmor=1
Desktop: GNOME 41.2 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
Type: Desktop System: Gigabyte product: AB350-Gaming v: N/A
serial: <superuser required>
Mobo: Gigabyte model: AB350-Gaming-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F21 date: 02/08/2018
RAM: total: 15.64 GiB used: 3.54 GiB (22.7%)
RAM Report:
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
family: 0x17 (23) model-id: 1 stepping: 1 microcode: 0x8001129
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1848 high: 3346 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2177 2: 2798
3: 2869 4: 3346 5: 1402 6: 1353 7: 1374 8: 1374 9: 1374 10: 1368 11: 1375
12: 1373 bogomips: 76671
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate irperf lahf_lm lbrv lm mca mce
nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep
ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 08:00.0
chip-ID: 10de:1c02 class-ID: 0300
Display: x11 server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
v: 4.6.0 NVIDIA 495.44 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Sony Wireless Controller type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:2 chip-ID: 054c:0ce6
class-ID: 0300
Sound Server-1: ALSA v: k5.10.84-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 03:00.0
Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl
v: kernel modules: bcma bus-ID: 07:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
class-ID: 0300
Local Storage: total: 698.65 GiB used: 151.43 GiB (21.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500312CS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5900 serial: <filter> rev: CA12 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH30N rev: A201
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 151.43 GiB (66.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 40809886-d17c-433b-876f-89a03d053b64
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: E832-7B45
ID-3: /run/media/nicholas/second disk raw-size: 434.51 GiB
size: 426.62 GiB (98.18%) used: 60 KiB (0.0%) fs: ext4 dev: /dev/sdb2
maj-min: 8:18 label: second disk
uuid: 1ec047b4-ec64-4d28-8893-f16ad7899256
ID-1: /dev/sdb1 maj-min: 8:17 size: 31.25 GiB fs: swap label: N/A
uuid: 14863704-322a-453c-b7a5-87bba34bb094
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-4:2 info: Sony Wireless Controller type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 054c:0ce6 class-ID: 0300
Device-2: 1-5:3 info: Corsair Gaming K70 LUX RGB Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b33 class-ID: 0300
serial: <filter>
Device-3: 1-6:4 info: Logitech G502 Proteus Spectrum Optical Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 32.5 C mobo: N/A gpu: nvidia temp: 51 C
Processes: 341 Uptime: 29m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1596 pacman: 1589 lib: 450
flatpak: 0 snap: 7 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.11
I bought a new Dualsense controller today to use with Hollow Knight but it doesn’t work properly. It worked right in Borderlands 2 and I tried Hollow Knight with Proton instead of the native version and it seemed to work alright there (my save from Linux didn’t show up in the game so I didn’t try anything beyond menus but will try tomorrow and update).
What happens is spontaneous and bizarre remappings of the controls whenever the game starts up. Sometimes all of the buttons map to the same button. Most frequently it’s the circle button (Xbox equivalent of B) and in the game itself the triggers map to the start and select buttons and the right thumbstick maps to the right trigger. I’m not sure what is going on.
Is there any way I can log the responses from the controller or see how they’re mapped locally? I saw some other workarounds online but nothing about this specific issue yet.
I tried it with Borderlands 2 which is native and it worked great. I tried it with DUSK in Lutris from GOG and that also had bizarre mappings.
