Can someone tell me where I can find all the shortcuts for manjaro xfce, not just the application shortcuts in the keyboard settings?
The user configured keyboard shortcuts are stored in : ~/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-keyboard-shortcuts.xml
And the system default are in : /etc/xdg/xfce4/xfconf/xfce-perchannel-xml/xfce4-keyboard-shortcuts.xml and belongs to the libxfce4ui
package.
Thankyou
I was interested in this topic too.
Both Settings > Window Manager > Keyboard and Settings > Keyboard > Application Shortcuts modified the file $HOME/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-keyboard-shortcuts.xml. If you hit Reset to Defaults I believe the values come from the /etc/xdg/xfce4 location. In addition, there is the new user /etc/skel/.config/xfce4 location.
You can also list shortcuts from the command line:
xfconf-query -c xfce4-keyboard-shortcuts -l -v
Changing the command to:
xfconf-query --channel xfce4-keyboard-shortcuts --list --verbose | sort --key=1.44
will make the output sort by the key description.
