Hello
I have a dual monitor setup and I’ve installed Windows on my HDD. I decided to try linux so manjaro is my first linux (installed on my SSD). However, the dual monitor setup won’t work on manjaro. It works on Windows fine. I’ve installed Manjaro GNOME. I went to hardware config and clicked on Auto-install proprietary drivers and rebooted, still nothing. What should I do? I’m very new to linux.
My primary 1080p monitor is connected via HDMI to my GTX 1050Ti mini and my secondary 720p monitor (very old) is connected via VGA to my Intel HD 630 graphics because my GTX has only one HDMI output.
Thanks for replying @Fabby ! I will follow the posting guidelines henceforth.
One more thing, when I booted manjaro today, it booted using only the secondary monitor (720p) and the primary (1080p) is now blank. I didn’t install/update anything yesterday afaik, so I don’t know what caused this switch.
To answer your question, the VGA is connected directly to the CPU without using any adapter. There’s a VGA slot available on both the monitor and the CPU.
And here’s the command output:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=8e9fba35-b34e-4ccb-a6dd-68ad33d1d3e3 ro quiet splash apparmor=1
Desktop: GNOME 3.38.3 tk: GTK 3.24.26 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: B250M-D3H v: N/A serial: <filter>
Mobo: Gigabyte model: B250M-D3H-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F4 date: 02/21/2017
RAM: total: 15.41 GiB used: 2.59 GiB (16.8%)
Info: Quad Core model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 9E (158) stepping: 9 microcode: DE L2 cache: 6 MiB
bogomips: 24008
Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 630 vendor: Gigabyte driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5912 class ID: 0380
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ZOTAC driver: nvidia
v: 460.56 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1c82
class ID: 0300
Display: wayland server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: nvidia display ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a2f0
class ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
class ID: 0403
Device-3: Microsoft LifeCam Cinema type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-8:4 chip ID: 045e:075d class ID: 0102
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: f040 bus ID: 00:1f.6 chip ID: 8086:15b8 class ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: r8188eu bus ID: 1-10:5 chip ID: 0bda:8179 class ID: 0000
serial: <filter>
IF: wlp0s20f0u10 state: up mac: <filter>
Message: No Bluetooth data was found.
Local Storage: total: 1.13 TiB used: 10.28 GiB (0.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-08WN4A0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT240BX500SSD1
size: 223.57 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: R013 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSD1 rev: LG00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw size: 223.27 GiB size: 218.77 GiB (97.98%)
used: 10.28 GiB (4.7%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 8e9fba35-b34e-4ccb-a6dd-68ad33d1d3e3
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 316 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: DD0B-AA2B
ID-1: /dev/sda1 maj-min: 8:1 size: 529 MiB fs: ntfs label: Recovery
uuid: 426A099D6A098F3B
ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
uuid: 720C-FA70
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 344.94 GiB fs: ntfs label: N/A
uuid: 5E0010D80010B94B
ID-5: /dev/sda5 maj-min: 8:5 size: 585.94 GiB fs: ntfs label: Files
uuid: A09269DA9269B606
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-5:2 info: Microdia USB Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
chip ID: 0c45:7603 class ID: 0301
Device-2: 1-6:3 info: Sunplus Innovation Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 1bcf:0005 class ID: 0301
Device-3: 1-8:4 info: Microsoft LifeCam Cinema type: Video,Audio
Device-4: 1-10:5 info: Realtek RTL8188EUS 802.11n Wireless Network Adapter
type: Network driver: r8188eu interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 0bda:8179 class ID: 0000 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003 class ID: 0900
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 216 Uptime: 1m wakeups: 0 Init: systemd v: 247 Compilers:
gcc: N/A Packages: pacman: 1236 lib: 373 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.3.01
Fabby
15 March 2021 17:01
4
codesadhu:
Display: wayland
Sorry, don’t know anything about Wayland, but I’ve added it as a tag to attract the Wayland experts…
No problem! Thanks for replying
