Hi there.
I’ve been looking around for solutions and couldn’t quite find someone with the same situation as I have.
I am running KDE Plasma in a dual monitor setup.
Most of the time it works fine, the problem is that my secondary monitor takes all the windows upon waking up from sleep,/hibernation, at boot or even after both displays timeout.
When powering up, my primary display shows the login screen (for a brief moment), and because my secondary screen is slower to power up, as soon as it starts displaying, everything switches to it.
After each login all of my windows that have been on my primary monitor switch to the secondary one.
Output of xrandr -q below
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 32767 x 32767
DVI-D-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 544mm x 303mm
1920x1080 60.00 + 144.00* 119.98 99.93 59.94 50.00
1680x1050 59.88
1440x900 59.90
1280x1024 75.02 60.02
1280x720 59.94 50.00
1024x768 119.99 100.00 75.03 70.07 60.00
800x600 119.97 100.00 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 120.01 99.99 75.00 72.81 59.94 59.93
DP-0 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 521mm x 293mm
1920x1080 60.00 + 165.00* 144.00 119.98 119.88 59.94 50.00
1024x768 119.99 99.97 75.03 70.07 60.00
800x600 119.97 99.66 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 119.52 99.77 75.00 72.81 59.94 59.93
DP-1 disconnected (normal left inverted right x axis y axis)
The HDMI-0 Connection is my secondary display. And KDE successfully retains that my DP-0 Connection is my primary, but on every login it will still open all of my windows on the secondary display.
Any suggestions or help regarding this matter will be greatly appreciated
