So im running dual monitor setup atm refresh rate is set to 144hz on the primary one and on ufo test only getting ~60fps by disconnecting the second monitor which is 60hz fps jump to 144, i googled it seen that few people have the same problem but i cant find the solution.
xrandr
Screen 0: minimum 320 x 200, current 3840 x 1080, maximum 16384 x 16384
DisplayPort-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 531mm x 298mm
1920x1080 60.00 + 144.00* 119.98 99.93 50.00 59.94
1680x1050 60.00
1280x1024 75.02
1440x900 60.00
1280x800 60.00
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 60.00
832x624 74.55
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 60.00 59.94
720x400 70.08
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
HDMI-A-0 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 509mm x 286mm
1920x1080 60.00 + 50.00 59.94* 30.00 29.97
1680x1050 59.88
1280x1024 75.02 60.02
1440x900 74.98 59.90
1280x800 60.00
800x600 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
HDMI-A-1 disconnected (normal left inverted right x axis y axis)
DVI-D-0 disconnected (normal left inverted right x axis y axis)
Kernel: 5.11.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.21.3 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: H97-PRO GAMER v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 2503 date: 02/26/2016
Info: Quad Core model: Intel Core i7-4790 bits: 64 type: MT MCP
arch: Haswell rev: 3 cache: L2: 8 MiB
bogomips: 57623
Speed: 3600 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 3600
2: 1268 3: 3600 4: 3603 5: 3605 6: 800 7: 960 8: 1150
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel
bus-ID: 01:00.0
Display: x11 server: X.Org 1.20.10 driver: loaded: amdgpu,ati
unloaded: modesetting resolution: 1: 1920x1080 2: 1920x1080~60Hz
OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.40.0
5.11.10-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.1 direct render: Yes
Device-1: Intel 9 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire Limited driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Device-3: Yamaha Steinberg UR22mkII type: USB driver: snd-usb-audio
bus-ID: 3-13.1:6
Sound Server-1: ALSA v: k5.11.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.24 running: yes
Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0
bus-ID: 00:1f.2
Device-1: md126 type: mdraid level: raid-0 status: active
Info: report: N/A blocks: 488391680 chunk-size: 128k
Components: Online: 0: sdb 1: sda
Device-2: md127 type: mdraid level: N/A status: inactive size: N/A
Info: report: N/A blocks: 5488 chunk-size: N/A
Components: Online: N/A Spare: 0: sdb 1: sda
Local Storage: total: raw: 1.47 TiB usable: 1.02 TiB
used: 9.78 GiB (0.9%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 250GB
ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB
ID-3: /dev/sdc vendor: Western Digital model: WD10EZEX-08WN4A0
ID-4: /dev/sdd vendor: Kingston model: SA400S37120G size: 111.79 GiB
ID-1: / size: 109.18 GiB used: 9.78 GiB (9.0%) fs: ext4 dev: /dev/sdd2
ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
dev: /dev/sdd1
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 48.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 772
Processes: 250 Uptime: 42m Memory: 23.43 GiB used: 2.5 GiB (10.7%)
Init: systemd Compilers: gcc: 10.2.0 Packages: 1205 Shell: Bash
v: 5.1.0 inxi: 3.3.03
