boot menu auto picking manjaro
grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=-1
GRUB_TIMEOUT_STYLE=menu
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
#GRUB_ROOT_FS_RO=true
sudo update-grub
Found linux image: /boot/vmlinuz-5.13-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.13-x86_64.img
Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
Found Manjaro Linux (21.1.0) on /dev/nvme0n1p3
Found Windows 10 on /dev/sda1
Detecting snapshots ...
Root partition isn't a btrfs filesystem.
This script only supports snapshots of the btrfs filesystem.
If you think an error has occurred , please file a bug report at " https://github.com/Antynea/grub-btrfs "
Nothing to do. Abort.
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
