❯ inxi -G
Graphics: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics driver: i915 v: kernel
Device-2: NVIDIA GM206 [GeForce GTX 960] driver: nvidia v: 455.38
Display: x11 server: X.Org 1.20.9 driver: nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 455.38
❯ inxi -Fxz
System: Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.20.2 Distro: Manjaro Linux
Machine: Type: Desktop System: MSI product: MS-7922 v: 2.0 serial: <filter>
Mobo: MSI model: Z97S SLI Krait Edition (MS-7922) v: 2.0 serial: <filter> UEFI: American Megatrends v: 10.7
date: 02/16/2016
Battery: Device-1: hid-b8:f6:b1:2e:9a:d7-battery model: Nate Doyle’s Trackpad charge: N/A status: Discharging
CPU: Info: Quad Core model: Intel Core i5-4690K bits: 64 type: MCP arch: Haswell rev: 3 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28010
Speed: 800 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 934 2: 1288 3: 1000 4: 1142
Graphics: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: Micro-Star MSI driver: i915
v: kernel bus ID: 00:02.0
Device-2: NVIDIA GM206 [GeForce GTX 960] vendor: ASUSTeK driver: nvidia v: 455.38 bus ID: 01:00.0
OpenGL: renderer: GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 455.38 direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 00:03.0
Device-2: Intel 9 Series Family HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Device-3: NVIDIA GM206 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 01:00.1
Device-4: Logitech QuickCam Communicate STX type: USB driver: gspca_zc3xx,snd-usb-audio bus ID: 2-3:3
Sound Server: ALSA v: k5.8.18-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
port: d000 bus ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL88x2bu [AC1200 Techkey] type: USB driver: rtl88x2bu bus ID: 2-5:5
IF: wlp0s20u5 state: up mac: <filter>
IF-ID-1: br-423b1b769d7b state: down mac: <filter>
IF-ID-2: br-71e10443bc56 state: down mac: <filter>
IF-ID-3: br-7273d7b7eac3 state: down mac: <filter>
IF-ID-4: br-841c380a2a0c state: down mac: <filter>
IF-ID-5: br-a288ba8f1eea state: down mac: <filter>
IF-ID-6: br-c94f5c7b4ae9 state: down mac: <filter>
IF-ID-7: br-f810b38beeab state: down mac: <filter>
IF-ID-8: docker0 state: down mac: <filter>
IF-ID-9: virbr0 state: down mac: <filter>
IF-ID-10: virbr0-nic state: down mac: <filter>
Drives: Local Storage: total: 1.93 TiB used: 1.26 TiB (65.4%)
ID-1: /dev/sda vendor: Western Digital model: WD5000BEKT-00KA9T0 size: 465.76 GiB
ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
ID-3: /dev/sdc vendor: Kingston model: SA400S37240G size: 223.57 GiB
ID-4: /dev/sdd type: USB vendor: Western Digital model: WD My Passport 0820 size: 931.48 GiB
ID-5: /dev/sde type: USB vendor: Samsung model: Flash Drive size: 119.51 GiB
Partition: ID-1: / size: 58.81 GiB used: 53.38 GiB (90.8%) fs: ext4 dev: /dev/sdb3
ID-2: /home size: 158.60 GiB used: 135.31 GiB (85.3%) fs: ext4 dev: /dev/sdb4
Swap: ID-1: swap-1 type: partition size: 8.79 GiB used: 0 KiB (0.0%) dev: /dev/sdb2
Sensors: System Temperatures: cpu: 31.5 C mobo: 29.0 C gpu: nvidia temp: 39 C
Fan Speeds (RPM): cpu: 826 fan-1: 0 fan-3: 813 fan-4: 694 fan-5: 738 gpu: nvidia fan: 0%
Info: Processes: 233 Uptime: 40m Memory: 15.52 GiB used: 7.86 GiB (50.7%) Init: systemd Compilers: gcc: 10.2.0
clang: 10.0.1 Packages: 1875 Shell: Zsh v: 5.8 inxi: 3.1.08
❯ lsmod | grep i915
i915 2641920 1
i2c_algo_bit 16384 1 i915
intel_gtt 24576 1 i915
drm_kms_helper 262144 2 nvidia_drm,i915
cec 73728 2 drm_kms_helper,i915
drm 589824 14 drm_kms_helper,nvidia_drm,i915
❯ mhwd
> 0000:01:00.0 (0300:10de:1401) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia-455xx 2020.10.04 false PCI
video-nvidia-450xx 2020.10.04 false PCI
video-nvidia-440xx 2020.10.04 false PCI
video-nvidia-435xx 2020.10.04 false PCI
video-nvidia-430xx 2020.10.04 false PCI
video-nvidia-418xx 2020.10.04 false PCI
video-nvidia-390xx 2020.10.04 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:05:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> 0000:00:02.0 (0380:8086:0412) Display controller Intel Corporation:
❯ glxinfo | grep OpenGL
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce GTX 960/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 455.38
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6.0 NVIDIA 455.38
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 455.38
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
❯ xrandr -q
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
DVI-I-1 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 521mm x 293mm
1920x1080 60.00*+ 59.94 50.00 60.00 50.04
1680x1050 59.95
1440x900 59.89
1440x576 50.00
1440x480 59.94
1280x1024 75.02 60.02
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.93 59.94
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
My mother board: Overview Z97S SLI Krait Edition | MSI USA
My GPU: STRIX-GTX960-DC2OC-2GD5 | Graphics Cards | ASUS USA
I’m having some trouble getting a second monitor working on my iGPU over HDMI (using HDMI 2, not HDMI/DVI on a TV.) The screen seems to register but, it’s just black (with a touch of back light, if you will.)
In the MSI Bios settings I have Itegrated Graphis set to PEG (vs IGD), 64mb memory (I tried 128 and 512mb too) and dual monitor support enabled for both dGPU and iGPU (I forget this setting’s name.)
ETA: I set it to IGD in the bios and it does the same thing (the third setting for dual monitor support disappears), I get output from dGPU and black screen on iGPU.
I don’t currently have Hybrid Prime drivers showing up in the settings, although I recently tried upgrading to Kernal 5.9 and they showed up. Of course, I was running into some issues getting nvidia drivers working under 5.9 so, I removed it and reverted back to 5.8 (I saw a recent thread talking about the issue with nivdia and 5.9; The end of Nvidia proprietary Drivers on Linux !?!)
I’ve tried several things, including adding some i915 settings in /etc/default/grub
, as well as creating a /etc/X11/xorg.conf.d/20-intel.conf
file with variations of the following (changing Driver to video-linux etc.)
Section "Device"
Identifier "Intel Graphics"
Driver "intel"
BusID "PCI:0:2:0"
Option "AccelMethod" "uxa"
EndSection
I’m not sure how to address this and everything I’ve tried from forums here and arch don’t seem to be working. Also, I’m not sure why hybrid-prime drivers aren’t showing up on my system, unless on 5.9 but, either way, that seems like a setup for laptops, no?
Anyway, I’d appriciate any help on this.
Note: the TV works, aside from it always messing up my compositor when I enable it in the Display Settings, if I connect it to the DPI port (with HDMI adapter) on my dGPU (GTX 960.) It’s just not working with the integrated graphics.
