Dual display with usb3 Asus Dock to hdmi
I am trying to connect a secondary monitor on my Manjaro using ASUS dock with usb-3 connector.
It works perfectly well for network cable, and other usb device such as Keyboard/mouse. But I can’t find a way to use the hdmi port from the dock to extend my display. I tried many things regarding xrand / xorg / displayLink (which I installed with no change anywhere)
Outputs:
marcc@marcc-latitude7480 ~[108-54]$ sudo xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x45 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 4 associated providers: 0 name:modesetting
Hello @marcoooo and welcome :wink:
Not enough information… You could start with this:
inxi -Fazy
lsusb -vt
xrandr --listmonitors --verbose
Disconnect the hdmi cable and run:
journalctl --boot 0 --grep "\([A-Z][A-Z]\)" --no-hostname --follow
Then connect again and look what is happening there.
Be sure that the hdmi cable is compatible and also that your Laptop is capable to use video over usb-c.
Here is a very detailed answer to this: https://unix.stackexchange.com/a/625312
Sorry I’ve been so long to come back to this issue:
output from inxi
  Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=7f162c39-d6eb-494a-b45a-edca6587cfd6 rw quiet splash apparmor=1
  Desktop: GNOME v: 43.1 tk: GTK v: 3.24.35 wm: gnome-shell dm: GDM v: 43.0
  Type: Laptop System: Dell product: Latitude 7480 v: N/A
  Mobo: Dell model: 00F6D3 v: A00 serial: <superuser required> UEFI: Dell
    v: 1.15.1 date: 07/04/2019
  ID-1: BAT0 charge: 48.1 Wh (100.0%) condition: 48.1/60.0 Wh (80.2%)
    volts: 8.7 min: 7.6 model: SMP DELL DM3WC64 type: Li-poly serial: <filter>
    status: full
  Device-1: hidpp_battery_0 model: Logitech K800 serial: <filter>
    charge: 70% (should be ignored) rechargeable: yes status: discharging
  Info: model: Intel Core i5-7300U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
    family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF0
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2145 high: 2600 min/max: 400/3500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1179 2: 2365 3: 2439
    4: 2600 bogomips: 21607
    vulnerable
    prctl and seccomp
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
    PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5916
    class-ID: 0300
  Device-2: Sunplus Innovation Integrated_Webcam_HD type: USB
    driver: uvcvideo bus-ID: 1-5:6 chip-ID: 1bcf:2b96 class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: LG Display 0x0557 built: 2016 res: 1920x1080 hz: 60
    dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.2.4 renderer: Mesa Intel HD Graphics 620 (KBL
    GT2) direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
    bus-ID: 2-3.2.1:5 v: kernel alternate: snd_soc_skl chip-ID: 0711:5812
    class-ID: 0102 bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
  Device-2: Magic Control USB3.0 External Graphics Device type: USB
    driver: snd-usb-audio
  Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.61 running: yes
  Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
  Device-3: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
    bus-ID: 2-3.2.2:6 chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
  IF: enp0s20f0u3u2u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: br-389fcf4c2c37 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-2: docker0 state: down mac: <filter>
  IF-ID-3: veth704455f state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-4: vpn0 state: up speed: 10 Mbps duplex: full mac: N/A
    bus-ID: 1-7:8 chip-ID: 8087:0a2b class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 476.94 GiB used: 221.4 GiB (46.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: KSG60ZMV512G M.2 2280
    512GB size: 476.94 GiB block-size: physical: 4096 B logical: 512 B
    speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4102 scheme: GPT
  ID-1: / raw-size: 170.9 GiB size: 167.16 GiB (97.81%) used: 81.02 GiB (48.5%)
    fs: ext4 dev: /dev/sda4 maj-min: 8:4
  ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 296.96 GiB size: 291.24 GiB (98.07%)
    used: 135.35 GiB (46.5%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
  ID-1: swap-1 type: partition size: 8.79 GiB used: 5.03 GiB (57.2%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2
  System Temperatures: cpu: 64.0 C pch: 53.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  Processes: 414 Uptime: 5h 35m wakeups: 24 Memory: 15.49 GiB
  used: 13.67 GiB (88.2%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1718
  pm: pacman pkgs: 1708 libs: 336 tools: gnome-software,pamac pm: flatpak
  pkgs: 0 pm: snap pkgs: 10 Shell: Bash v: 5.1.16 running-in: gnome-terminal
  inxi: 3.3.23
Output from second command:
    ID 1d6b:0003 Linux Foundation 3.0 root hub
    |__ Port 3: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
        ID 05e3:0617 Genesys Logic, Inc.
        |__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=, 5000M
            ID 0711:5809 Magic Control Technology Corp.
        |__ Port 2: Dev 4, If 0, Class=Hub, Driver=hub/4p, 5000M
            |__ Port 1: Dev 5, If 0, Class=Vendor Specific Class, Driver=, 5000M
                ID 0711:5812 Magic Control Technology Corp.
            |__ Port 1: Dev 5, If 1, Class=Audio, Driver=snd-usb-audio, 5000M
            |__ Port 1: Dev 5, If 2, Class=Audio, Driver=snd-usb-audio, 5000M
            |__ Port 1: Dev 5, If 3, Class=Audio, Driver=snd-usb-audio, 5000M
            |__ Port 2: Dev 6, If 0, Class=Vendor Specific Class, Driver=ax88179_178a, 5000M
                ID 0b95:1790 ASIX Electronics Corp. AX88179 Gigabit Ethernet
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/12p, 480M
    ID 1d6b:0002 Linux Foundation 2.0 root hub
    |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
        ID 046d:c52b Logitech, Inc. Unifying Receiver
    |__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 1: Dev 2, If 2, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 2: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
        ID 05e3:0610 Genesys Logic, Inc. Hub
        |__ Port 2: Dev 5, If 0, Class=Hub, Driver=hub/4p, 480M
            |__ Port 4: Dev 17, If 0, Class=Human Interface Device, Driver=usbhid, 12M
                ID 046d:c08b Logitech, Inc. G502 SE HERO Gaming Mouse
            |__ Port 4: Dev 17, If 1, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 3: Dev 18, If 0, Class=Vendor Specific Class, Driver=usbfs, 480M
            ID 0b05:7772 ASUSTek Computer, Inc. Zenfone GO (ZB500KL) (MTP mode)
    |__ Port 5: Dev 6, If 0, Class=Video, Driver=uvcvideo, 480M
        ID 1bcf:2b96 Sunplus Innovation Technology Inc.
    |__ Port 5: Dev 6, If 1, Class=Video, Driver=uvcvideo, 480M
    |__ Port 7: Dev 8, If 0, Class=Wireless, Driver=btusb, 12M
        ID 8087:0a2b Intel Corp. Bluetooth wireless interface
    |__ Port 7: Dev 8, If 1, Class=Wireless, Driver=btusb, 12M
    |__ Port 10: Dev 9, If 0, Class=Application Specific Interface, Driver=, 12M
        ID 0a5c:5834 Broadcom Corp.
    |__ Port 10: Dev 9, If 1, Class=Chip/SmartCard, Driver=, 12M
    |__ Port 10: Dev 9, If 2, Class=Chip/SmartCard, Driver=, 12M
    |__ Port 10: Dev 9, If 3, Class=Vendor Specific Class, Driver=, 12M
type or paste code here
And thrid:
	Identifier: 0x41
	Timestamp:  20087661
	Subpixel:   unknown
	Gamma:      1.0:1.0:1.0
	Brightness: 1.0
	Clones:
	CRTC:       0
	CRTCs:      0 1 2
	Transform:  1.000000 0.000000 0.000000
	            0.000000 1.000000 0.000000
	            0.000000 0.000000 1.000000
	           filter:
	_MUTTER_PRESENTATION_OUTPUT: 0
	EDID:
		00ffffffffffff0030e4570500000000
		001a0104951f1178e2ba05a250469d27
		0e505400000001010101010101010101
		0101010101012e3680a070381f403020
		350035ae1000001a522b80a070381f40
		3020350035ae1000001a000000fe0052
		36443847803134305746370a00000000
		000041319e001000000a010a202000d7
	scaling mode: Full aspect
		supported: Full, Center, Full aspect
	Colorspace: Default
		supported: Default, RGB_Wide_Gamut_Fixed_Point, RGB_Wide_Gamut_Floating_Point, opRGB, DCI-P3_RGB_D65, BT2020_RGB, BT601_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, BT2020_CYCC, BT2020_YCC
	max bpc: 12
		range: (6, 12)
	Broadcast RGB: Automatic
		supported: Automatic, Full, Limited 16:235
	panel orientation: Normal
		supported: Normal, Upside Down, Left Side Up, Right Side Up
	link-status: Good
		supported: Good, Bad
	CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
		0 1
	CONNECTOR_ID: 95
		supported: 95
	non-desktop: 0
		range: (0, 1)
  1920x1080 (0x46) 138.700MHz +HSync -VSync *current +preferred
        h: width  1920 start 1968 end 2000 total 2080 skew    0 clock  66.68KHz
        v: height 1080 start 1083 end 1088 total 1111           clock  60.02Hz
  1920x1080 (0x47) 356.375MHz -HSync +VSync DoubleScan
        h: width  1920 start 2080 end 2288 total 2656 skew    0 clock 134.18KHz
        v: height 1080 start 1081 end 1084 total 1118           clock  60.01Hz
  1920x1080 (0x48) 266.500MHz +HSync -VSync DoubleScan
        h: width  1920 start 1944 end 1960 total 2000 skew    0 clock 133.25KHz
        v: height 1080 start 1081 end 1084 total 1111           clock  59.97Hz
  1920x1080 (0x49) 173.000MHz -HSync +VSync
        h: width  1920 start 2048 end 2248 total 2576 skew    0 clock  67.16KHz
        v: height 1080 start 1083 end 1088 total 1120           clock  59.96Hz
  1920x1080 (0x4a) 138.500MHz +HSync -VSync
        h: width  1920 start 1968 end 2000 total 2080 skew    0 clock  66.59KHz
        v: height 1080 start 1083 end 1088 total 1111           clock  59.93Hz
  1920x1080 (0x4b) 110.900MHz +HSync -VSync
        h: width  1920 start 1968 end 2000 total 2080 skew    0 clock  53.32KHz
        v: height 1080 start 1083 end 1088 total 1111           clock  47.99Hz
  1680x1050 (0x4c) 146.250MHz -HSync +VSync
        h: width  1680 start 1784 end 1960 total 2240 skew    0 clock  65.29KHz
        v: height 1050 start 1053 end 1059 total 1089           clock  59.95Hz
  1680x1050 (0x4d) 119.000MHz +HSync -VSync
        h: width  1680 start 1728 end 1760 total 1840 skew    0 clock  64.67KHz
        v: height 1050 start 1053 end 1059 total 1080           clock  59.88Hz
  1400x1050 (0x4e) 122.000MHz +HSync +VSync
        h: width  1400 start 1488 end 1640 total 1880 skew    0 clock  64.89KHz
        v: height 1050 start 1052 end 1064 total 1082           clock  59.98Hz
  1600x900 (0x4f) 246.000MHz -HSync +VSync DoubleScan
        h: width  1600 start 1728 end 1900 total 2200 skew    0 clock 111.82KHz
        v: height  900 start  901 end  904 total  932           clock  59.99Hz
  1600x900 (0x50) 186.500MHz +HSync -VSync DoubleScan
        h: width  1600 start 1624 end 1640 total 1680 skew    0 clock 111.01KHz
        v: height  900 start  901 end  904 total  926           clock  59.94Hz
  1600x900 (0x51) 118.250MHz -HSync +VSync
        h: width  1600 start 1696 end 1856 total 2112 skew    0 clock  55.99KHz
        v: height  900 start  903 end  908 total  934           clock  59.95Hz
  1600x900 (0x52) 97.500MHz +HSync -VSync
        h: width  1600 start 1648 end 1680 total 1760 skew    0 clock  55.40KHz
        v: height  900 start  903 end  908 total  926           clock  59.82Hz
  1280x1024 (0x53) 108.000MHz +HSync +VSync
        h: width  1280 start 1328 end 1440 total 1688 skew    0 clock  63.98KHz
        v: height 1024 start 1025 end 1028 total 1066           clock  60.02Hz
  1400x900 (0x54) 103.500MHz -HSync +VSync
        h: width  1400 start 1480 end 1624 total 1848 skew    0 clock  56.01KHz
        v: height  900 start  903 end  913 total  934           clock  59.96Hz
  1400x900 (0x55) 86.500MHz +HSync -VSync
        h: width  1400 start 1448 end 1480 total 1560 skew    0 clock  55.45KHz
        v: height  900 start  903 end  913 total  926           clock  59.88Hz
  1280x960 (0x56) 108.000MHz +HSync +VSync
        h: width  1280 start 1376 end 1488 total 1800 skew    0 clock  60.00KHz
        v: height  960 start  961 end  964 total 1000           clock  60.00Hz
  1440x810 (0x57) 198.125MHz -HSync +VSync DoubleScan
        h: width  1440 start 1548 end 1704 total 1968 skew    0 clock 100.67KHz
        v: height  810 start  811 end  814 total  839           clock  60.00Hz
  1440x810 (0x58) 151.875MHz +HSync -VSync DoubleScan
        h: width  1440 start 1464 end 1480 total 1520 skew    0 clock  99.92KHz
        v: height  810 start  811 end  814 total  833           clock  59.97Hz
  1368x768 (0x59) 85.250MHz -HSync +VSync
        h: width  1368 start 1440 end 1576 total 1784 skew    0 clock  47.79KHz
        v: height  768 start  771 end  781 total  798           clock  59.88Hz
  1368x768 (0x5a) 72.250MHz +HSync -VSync
        h: width  1368 start 1416 end 1448 total 1528 skew    0 clock  47.28KHz
        v: height  768 start  771 end  781 total  790           clock  59.85Hz
  1280x800 (0x5b) 174.250MHz -HSync +VSync DoubleScan
        h: width  1280 start 1380 end 1516 total 1752 skew    0 clock  99.46KHz
        v: height  800 start  801 end  804 total  829           clock  59.99Hz
  1280x800 (0x5c) 134.250MHz +HSync -VSync DoubleScan
        h: width  1280 start 1304 end 1320 total 1360 skew    0 clock  98.71KHz
        v: height  800 start  801 end  804 total  823           clock  59.97Hz
  1280x800 (0x5d) 83.500MHz -HSync +VSync
        h: width  1280 start 1352 end 1480 total 1680 skew    0 clock  49.70KHz
        v: height  800 start  803 end  809 total  831           clock  59.81Hz
  1280x800 (0x5e) 71.000MHz +HSync -VSync
        h: width  1280 start 1328 end 1360 total 1440 skew    0 clock  49.31KHz
        v: height  800 start  803 end  809 total  823           clock  59.91Hz
  1280x720 (0x5f) 156.125MHz -HSync +VSync DoubleScan
        h: width  1280 start 1376 end 1512 total 1744 skew    0 clock  89.52KHz
        v: height  720 start  721 end  724 total  746           clock  60.00Hz
  1280x720 (0x60) 120.750MHz +HSync -VSync DoubleScan
        h: width  1280 start 1304 end 1320 total 1360 skew    0 clock  88.79KHz
        v: height  720 start  721 end  724 total  740           clock  59.99Hz
  1280x720 (0x61) 74.500MHz -HSync +VSync
        h: width  1280 start 1344 end 1472 total 1664 skew    0 clock  44.77KHz
        v: height  720 start  723 end  728 total  748           clock  59.86Hz
  1280x720 (0x62) 63.750MHz +HSync -VSync
        h: width  1280 start 1328 end 1360 total 1440 skew    0 clock  44.27KHz
        v: height  720 start  723 end  728 total  741           clock  59.74Hz
  1024x768 (0x63) 133.475MHz -HSync +VSync DoubleScan
        h: width  1024 start 1100 end 1212 total 1400 skew    0 clock  95.34KHz
        v: height  768 start  768 end  770 total  794           clock  60.04Hz
  1024x768 (0x64) 65.000MHz -HSync -VSync
        h: width  1024 start 1048 end 1184 total 1344 skew    0 clock  48.36KHz
        v: height  768 start  771 end  777 total  806           clock  60.00Hz
  960x720 (0x65) 117.000MHz -HSync +VSync DoubleScan
        h: width   960 start 1024 end 1128 total 1300 skew    0 clock  90.00KHz
        v: height  720 start  720 end  722 total  750           clock  60.00Hz
  928x696 (0x66) 109.150MHz -HSync +VSync DoubleScan
        h: width   928 start  976 end 1088 total 1264 skew    0 clock  86.35KHz
        v: height  696 start  696 end  698 total  719           clock  60.05Hz
  896x672 (0x67) 102.400MHz -HSync +VSync DoubleScan
        h: width   896 start  960 end 1060 total 1224 skew    0 clock  83.66KHz
        v: height  672 start  672 end  674 total  697           clock  60.01Hz
  1024x576 (0x68) 98.500MHz -HSync +VSync DoubleScan
        h: width  1024 start 1092 end 1200 total 1376 skew    0 clock  71.58KHz
        v: height  576 start  577 end  580 total  597           clock  59.95Hz
  1024x576 (0x69) 78.375MHz +HSync -VSync DoubleScan
        h: width  1024 start 1048 end 1064 total 1104 skew    0 clock  70.99KHz
        v: height  576 start  577 end  580 total  592           clock  59.96Hz
  1024x576 (0x6a) 46.500MHz -HSync +VSync
        h: width  1024 start 1064 end 1160 total 1296 skew    0 clock  35.88KHz
        v: height  576 start  579 end  584 total  599           clock  59.90Hz
  1024x576 (0x6b) 42.000MHz +HSync -VSync
        h: width  1024 start 1072 end 1104 total 1184 skew    0 clock  35.47KHz
        v: height  576 start  579 end  584 total  593           clock  59.82Hz
  960x600 (0x6c) 96.625MHz -HSync +VSync DoubleScan
        h: width   960 start 1028 end 1128 total 1296 skew    0 clock  74.56KHz
        v: height  600 start  601 end  604 total  622           clock  59.93Hz
  960x600 (0x6d) 77.000MHz +HSync -VSync DoubleScan
        h: width   960 start  984 end 1000 total 1040 skew    0 clock  74.04KHz
        v: height  600 start  601 end  604 total  617           clock  60.00Hz
  960x540 (0x6e) 86.500MHz -HSync +VSync DoubleScan
        h: width   960 start 1024 end 1124 total 1288 skew    0 clock  67.16KHz
        v: height  540 start  541 end  544 total  560           clock  59.96Hz
  960x540 (0x6f) 69.250MHz +HSync -VSync DoubleScan
        h: width   960 start  984 end 1000 total 1040 skew    0 clock  66.59KHz
        v: height  540 start  541 end  544 total  555           clock  59.99Hz
  960x540 (0x70) 40.750MHz -HSync +VSync
        h: width   960 start  992 end 1088 total 1216 skew    0 clock  33.51KHz
        v: height  540 start  543 end  548 total  562           clock  59.63Hz
  960x540 (0x71) 37.250MHz +HSync -VSync
        h: width   960 start 1008 end 1040 total 1120 skew    0 clock  33.26KHz
        v: height  540 start  543 end  548 total  556           clock  59.82Hz
  800x600 (0x72) 81.000MHz +HSync +VSync DoubleScan
        h: width   800 start  832 end  928 total 1080 skew    0 clock  75.00KHz
        v: height  600 start  600 end  602 total  625           clock  60.00Hz
  800x600 (0x73) 40.000MHz +HSync +VSync
        h: width   800 start  840 end  968 total 1056 skew    0 clock  37.88KHz
        v: height  600 start  601 end  605 total  628           clock  60.32Hz
  800x600 (0x74) 36.000MHz +HSync +VSync
        h: width   800 start  824 end  896 total 1024 skew    0 clock  35.16KHz
        v: height  600 start  601 end  603 total  625           clock  56.25Hz
  840x525 (0x75) 73.125MHz -HSync +VSync DoubleScan
        h: width   840 start  892 end  980 total 1120 skew    0 clock  65.29KHz
        v: height  525 start  526 end  529 total  544           clock  60.01Hz
  840x525 (0x76) 59.500MHz +HSync -VSync DoubleScan
        h: width   840 start  864 end  880 total  920 skew    0 clock  64.67KHz
        v: height  525 start  526 end  529 total  540           clock  59.88Hz
  864x486 (0x77) 32.500MHz -HSync +VSync
        h: width   864 start  888 end  968 total 1072 skew    0 clock  30.32KHz
        v: height  486 start  489 end  494 total  506           clock  59.92Hz
  864x486 (0x78) 30.500MHz +HSync -VSync
        h: width   864 start  912 end  944 total 1024 skew    0 clock  29.79KHz
        v: height  486 start  489 end  494 total  500           clock  59.57Hz
  700x525 (0x79) 61.000MHz +HSync +VSync DoubleScan
        h: width   700 start  744 end  820 total  940 skew    0 clock  64.89KHz
        v: height  525 start  526 end  532 total  541           clock  59.98Hz
  800x450 (0x7a) 59.125MHz -HSync +VSync DoubleScan
        h: width   800 start  848 end  928 total 1056 skew    0 clock  55.99KHz
        v: height  450 start  451 end  454 total  467           clock  59.95Hz
  800x450 (0x7b) 48.750MHz +HSync -VSync DoubleScan
        h: width   800 start  824 end  840 total  880 skew    0 clock  55.40KHz
        v: height  450 start  451 end  454 total  463           clock  59.82Hz
  640x512 (0x7c) 54.000MHz +HSync +VSync DoubleScan
        h: width   640 start  664 end  720 total  844 skew    0 clock  63.98KHz
        v: height  512 start  512 end  514 total  533           clock  60.02Hz
  700x450 (0x7d) 51.750MHz -HSync +VSync DoubleScan
        h: width   700 start  740 end  812 total  924 skew    0 clock  56.01KHz
        v: height  450 start  451 end  456 total  467           clock  59.96Hz
  700x450 (0x7e) 43.250MHz +HSync -VSync DoubleScan
        h: width   700 start  724 end  740 total  780 skew    0 clock  55.45KHz
        v: height  450 start  451 end  456 total  463           clock  59.88Hz
  640x480 (0x7f) 54.000MHz +HSync +VSync DoubleScan
        h: width   640 start  688 end  744 total  900 skew    0 clock  60.00KHz
        v: height  480 start  480 end  482 total  500           clock  60.00Hz
  640x480 (0x80) 25.175MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.47KHz
        v: height  480 start  490 end  492 total  525           clock  59.94Hz
  720x405 (0x81) 22.500MHz -HSync +VSync
        h: width   720 start  744 end  808 total  896 skew    0 clock  25.11KHz
        v: height  405 start  408 end  413 total  422           clock  59.51Hz
  720x405 (0x82) 21.750MHz +HSync -VSync
        h: width   720 start  768 end  800 total  880 skew    0 clock  24.72KHz
        v: height  405 start  408 end  413 total  419           clock  58.99Hz
  684x384 (0x83) 42.625MHz -HSync +VSync DoubleScan
        h: width   684 start  720 end  788 total  892 skew    0 clock  47.79KHz
        v: height  384 start  385 end  390 total  399           clock  59.88Hz
  684x384 (0x84) 36.125MHz +HSync -VSync DoubleScan
        h: width   684 start  708 end  724 total  764 skew    0 clock  47.28KHz
        v: height  384 start  385 end  390 total  395           clock  59.85Hz
  640x400 (0x85) 41.750MHz -HSync +VSync DoubleScan
        h: width   640 start  676 end  740 total  840 skew    0 clock  49.70KHz
        v: height  400 start  401 end  404 total  415           clock  59.88Hz
  640x400 (0x86) 35.500MHz +HSync -VSync DoubleScan
        h: width   640 start  664 end  680 total  720 skew    0 clock  49.31KHz
        v: height  400 start  401 end  404 total  411           clock  59.98Hz
  640x360 (0x87) 37.250MHz -HSync +VSync DoubleScan
        h: width   640 start  672 end  736 total  832 skew    0 clock  44.77KHz
        v: height  360 start  361 end  364 total  374           clock  59.86Hz
  640x360 (0x88) 31.875MHz +HSync -VSync DoubleScan
        h: width   640 start  664 end  680 total  720 skew    0 clock  44.27KHz
        v: height  360 start  361 end  364 total  370           clock  59.83Hz
  640x360 (0x89) 18.000MHz -HSync +VSync
        h: width   640 start  664 end  720 total  800 skew    0 clock  22.50KHz
        v: height  360 start  363 end  368 total  376           clock  59.84Hz
  640x360 (0x8a) 17.750MHz +HSync -VSync
        h: width   640 start  688 end  720 total  800 skew    0 clock  22.19KHz
        v: height  360 start  363 end  368 total  374           clock  59.32Hz
  512x384 (0x8b) 32.500MHz -HSync -VSync DoubleScan
        h: width   512 start  524 end  592 total  672 skew    0 clock  48.36KHz
        v: height  384 start  385 end  388 total  403           clock  60.00Hz
  512x288 (0x8c) 23.250MHz -HSync +VSync DoubleScan
        h: width   512 start  532 end  580 total  648 skew    0 clock  35.88KHz
        v: height  288 start  289 end  292 total  299           clock  60.00Hz
  512x288 (0x8d) 21.000MHz +HSync -VSync DoubleScan
        h: width   512 start  536 end  552 total  592 skew    0 clock  35.47KHz
        v: height  288 start  289 end  292 total  296           clock  59.92Hz
  480x270 (0x8e) 20.375MHz -HSync +VSync DoubleScan
        h: width   480 start  496 end  544 total  608 skew    0 clock  33.51KHz
        v: height  270 start  271 end  274 total  281           clock  59.63Hz
  480x270 (0x8f) 18.625MHz +HSync -VSync DoubleScan
        h: width   480 start  504 end  520 total  560 skew    0 clock  33.26KHz
        v: height  270 start  271 end  274 total  278           clock  59.82Hz
  400x300 (0x90) 20.000MHz +HSync +VSync DoubleScan
        h: width   400 start  420 end  484 total  528 skew    0 clock  37.88KHz
        v: height  300 start  300 end  302 total  314           clock  60.32Hz
  400x300 (0x91) 18.000MHz +HSync +VSync DoubleScan
        h: width   400 start  412 end  448 total  512 skew    0 clock  35.16KHz
        v: height  300 start  300 end  301 total  312           clock  56.34Hz
  432x243 (0x92) 16.250MHz -HSync +VSync DoubleScan
        h: width   432 start  444 end  484 total  536 skew    0 clock  30.32KHz
        v: height  243 start  244 end  247 total  253           clock  59.92Hz
  432x243 (0x93) 15.250MHz +HSync -VSync DoubleScan
        h: width   432 start  456 end  472 total  512 skew    0 clock  29.79KHz
        v: height  243 start  244 end  247 total  250           clock  59.57Hz
  320x240 (0x94) 12.587MHz -HSync -VSync DoubleScan
        h: width   320 start  328 end  376 total  400 skew    0 clock  31.47KHz
        v: height  240 start  245 end  246 total  262           clock  60.05Hz
  360x202 (0x95) 11.250MHz -HSync +VSync DoubleScan
        h: width   360 start  372 end  404 total  448 skew    0 clock  25.11KHz
        v: height  202 start  204 end  206 total  211           clock  59.51Hz
  360x202 (0x96) 10.875MHz +HSync -VSync DoubleScan
        h: width   360 start  384 end  400 total  440 skew    0 clock  24.72KHz
        v: height  202 start  204 end  206 total  209           clock  59.13Hz
  320x180 (0x97)  9.000MHz -HSync +VSync DoubleScan
        h: width   320 start  332 end  360 total  400 skew    0 clock  22.50KHz
        v: height  180 start  181 end  184 total  188           clock  59.84Hz
  320x180 (0x98)  8.875MHz +HSync -VSync DoubleScan
        h: width   320 start  344 end  360 total  400 skew    0 clock  22.19KHz
        v: height  180 start  181 end  184 total  187           clock  59.32Hz
HDMI-1 disconnected (normal left inverted right x axis y axis)
	Identifier: 0x42
	Timestamp:  20087661
	Subpixel:   unknown
	Clones:
	CRTCs:      0 1 2
	           filter:
	HDCP Content Type: HDCP Type0
		supported: HDCP Type0, HDCP Type1
	Content Protection: Undesired
		supported: Undesired, Desired, Enabled
	max bpc: 12
		range: (8, 12)
	content type: No Data
		supported: No Data, Graphics, Photo, Cinema, Game
	Colorspace: Default
		supported: Default, SMPTE_170M_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, DCI-P3_RGB_Theater
	aspect ratio: Automatic
		supported: Automatic, 4:3, 16:9
	audio: auto
		supported: force-dvi, off, auto, on
	link-status: Good
		0 1
	CONNECTOR_ID: 103
		supported: 103
	non-desktop: 0
		range: (0, 1)
DP-1 disconnected (normal left inverted right x axis y axis)
	Identifier: 0x43
	Timestamp:  20087661
	Subpixel:   unknown
	Clones:     HDMI-2
	CRTCs:      0 1 2
	           filter:
	Colorspace: Default
	max bpc: 12
		range: (6, 12)
	audio: auto
	subconnector: Unknown
		supported: Unknown, VGA, DVI-D, HDMI, DP, Wireless, Native
	link-status: Good
		0 1
	CONNECTOR_ID: 112
		supported: 112
	non-desktop: 0
		range: (0, 1)
HDMI-2 disconnected (normal left inverted right x axis y axis)
	Identifier: 0x44
	Timestamp:  20087661
	Subpixel:   unknown
	Clones:     DP-1
	CRTCs:      0 1 2
	           filter:
	max bpc: 12
		range: (8, 12)
	Colorspace: Default
	audio: auto
	link-status: Good
		0 1
	CONNECTOR_ID: 119
		supported: 119
	non-desktop: 0
		range: (0, 1)
Please check your manual of the laptop for specifications of the usb-c / usb-3 port first. a lot of laptops-designs do not support usb-to-hdmi support ! had the same problem with my acer-laptop. these products are cheap crap.
I’ve got a Latitude 7480, Could it be that only usb-c is able to support HDMI? I mean every other component of the dock work fine: network / mouse / sound etc… I installed displayLink, and displaylink-connect, packages , no luck so far… My only soultion is to unplug the hdmi from the dock and directly plug it to laptop. No big deal, you could argue :slight_smile: but I’d love the idea just to have to plug “ONE” single cable (usb-3 or usb-c) to make it work!
Thanks anyway.
