Thanks could give it a try. What does power cycle mean?
Basically power off the display & put it back on again whilst connected to the computer. Shouldn’t need to pull the mains plug but this might also help. In my case once the display comes on again, the extra monitor appears in the Display Configuration GUI once I do this. That is with an HDMI display connected via the Mini DisplayPort.
Note also that sometimes when I connect my VGA monitor, the display lights up and works but it is not immediately shown in the GUI; clicking “Identify” brings it back in the dialog(ue) window.
I’m having a similar issue but not exactly the same so I’m not sure if I should start my own thread or not. I have 2 monitors and they were both functioning fine until today. When I power on, the secondary monitor shows up in xrandr
and the LED indicator indicates that it’s active (i.e. it is not amber indicating a sleeping display or a displaying receiving no signal, but blue indicating that it functions properly).
However, it flickers on for a brief second and then goes black. I’ve seen this before and a simply power cycle of using the on/off switch on the monitor worked, but it doesn’t resolve the issue anymore. Here is my xrandr
Screen 0: minimum 320 x 200, current 4480 x 1440, maximum 16384 x 16384
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 531mm x 299mm
1920x1080 60.00*+ 59.96 50.00 59.94 59.99 59.93
1920x1200 59.95
1920x1080i 60.00 50.00 59.94
1600x1200 65.00 60.00
1680x1050 59.95 59.88
1400x1050 74.76 59.98
1600x900 59.95 59.82
1280x1024 75.02 60.02
1440x900 59.90
1400x900 59.96 59.88
1280x960 60.00
1440x810 59.97
1368x768 59.88 59.85
1366x768 59.79
1280x800 59.99 59.97 59.81 59.91
1152x864 75.00
1280x720 60.00 59.99 59.86 60.00 50.00 59.94 59.74
1024x768 75.05 60.04 75.03 70.07 60.00
960x720 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 75.00 70.00 65.00 60.00 72.19 75.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
720x576 50.00
700x525 74.76 59.98
800x450 59.95 59.82
720x480 60.00 59.94
640x512 75.02 60.02
700x450 59.96 59.88
640x480 60.00 75.00 72.81 75.00 66.67 60.00 59.94
720x405 59.51 58.99
720x400 70.08
684x384 59.88 59.85
640x400 59.88 59.98
576x432 75.00
640x360 59.86 59.83 59.84 59.32
512x384 75.03 70.07 60.00
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 72.81 75.00 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 connected primary 2560x1440+1920+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 59.95 + 74.97*
1920x1440 75.00 60.00
1856x1392 75.00 60.01
1792x1344 75.00 60.01
2048x1152 59.98 59.90 59.91
1920x1200 59.88 59.95
1920x1080 59.97 59.96 60.00 50.00 59.94 49.95 59.93
1600x1200 75.00 70.00 65.00 60.00
1600x900 59.99 59.94 59.95 60.00 59.82
1440x900 59.89
1280x960 60.00
1440x810 60.00 59.97
1152x864 75.00
960x720 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
960x600 59.93 60.00
832x624 74.55
840x525 60.01 59.88
864x486 59.92 59.57
720x576 50.00
700x525 74.76 59.98
800x450 59.95 59.82
720x480 60.00 59.94
640x512 75.02 60.02
700x450 59.96 59.88
640x480 60.00 75.00 72.81 75.00 60.00 59.94
720x405 59.51 58.99
720x400 70.08
684x384 59.88 59.85
640x400 59.88 59.98
576x432 75.00
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
432x243 59.92 59.57
360x202 59.51 59.13
320x180 59.84 59.32
The monitor is an old Asus VW246 connected to HDMI and the monitor that works is a new HPZ27
I should maybe start my own thread because I’m using XFCE not KDE
Thanks
Unfortunately Power Cycle did not work
I get a message that the monitor is “scanning for signal” and then “No HDMI Signal from your device”
In your case it could be a failed backlight. Try shining a bright light on the screen; you might see an unlit image.
Running MHWD I notice I have 2 video modesetting boxes checked side by side… Is that normal?
I solved same problem by editing /etc/X11/mhwd.d/nvidia.conf, maybe can help.
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
Inactive "intel"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
BusID "PCI:1:0:0"
VendorName "NVIDIA Corporation"
Option "NoLogo" "1"
#Option "metamodes" "nvidia-auto-select +0+0 { ForceFullCompositionPipeline = On }"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
Option "AllowEmptyInitialConfiguration" "Yes"
# Change to your resolution
Monitor "1920x1080"
EndSection
Section "Device"
Identifier "intel"
Driver "modesetting"
BusID "PCI:0:2:0"
Option "AccelMethod" "sna"
Option "DRI" "3"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
Thanks my file is blank!
Generated by mhwd - Manjaro Hardware Detection
HI. Have just updated to latest 455 drivers but issue remains
For info I have noticed a couple of things and don’t know if they are relevant:
- I have 2 videomodestting options installed
- I get an error re display link manager not working during the boot cycle
Grateful for your thoughts
R
OK Giving up now after 5 months… Have to assume sadly that Manjaro KDE incapable of meeting my needs.
I had the same problem with Manjaro KDE using extended monitors. In my case, I can get it to work in two ways.
Go to Display Configuration and select the secondary monitor and then adjust the refresh rate (lower the refresh rate) and then the extended monitor starts to work (best option)
In the same place try adjusting the resolution and it will work
Thanks for sharing, but the thread you replied to was opened 10 months ago and the last post was 7 months ago.
Manjaro is a rolling distro - alot has changed since then.
https://wiki.manjaro.org/index.php/Forum_Rules#Old_Threads.2F.22Necro-Bumping.22
