Hello
I have this kind of line in my /etc/fstab:
//xxx.xxx.xxx.xxx/Folder /mnt/Folder cifs vers=1.0,credentials=/home/myname/.smbcredentials,uid=xxxx,gid=xxx,iocharset=utf8 0 0
While attempting mount -a, becomes an error:
mount error(20): Not a directory
and dmesg gives:
CIFS: Attempting to mount \\xxx.xxx.xxx.xxx\Folder
CIFS: VFS: bogus file nlink value 0
What could be wrong, what to check, and what to try next?
hmm
does /mnt/Folder
exist?
where is that directory, named “Folder
”, under that xxx.xxx.xxx.xxx
IP?
is it at the top level?
and why is there two slashes in front?
check what you have
file /mnt/Folder
Is it yours or copied from a random guide?
This
Do you actually own this - then everything is wrong - it actually lloks like a copy paste from a random guide on the interweb
Mount manually using mount command if you are unsure of the options needed
mkdir ~/temp
sudo mount -t cifs //ip.x.y.z/share temp
A very thorough troubleshooting guide
A from scratch
winnie
4
Is “Folder” the share name that points to the absolute path on the server?
SMB/CIFS is not like NFS. You don’t reference the absolute path on the server: only the share name
Each share is its own isolated “root directory” if it helps to think of it that way.
For example, the absolute path might be,
//192.168.0.100/mytank/media/Videos
On the server you configured an SMB share with the share name “Videos” that points to /mytank/media/Videos
on the server.
Your mount should reflect //192.168.0.100/Videos
Not //192.168.0.100/mytank/media/Videos
Also like @Nachlese and @linux-aarhus asked, does the directory /mnt/Folder
even exist on your Manjaro client?
Don’t use fstab
use systemd-mount units instead…
There is a tutorial by @linux-aarhus in the #contributions:tutorials section of the forum
It will make your life a lot easier and be able to fiddle around while booted up…
Sorry about delay, I had hurries, but better later than nothing…
Yes, there was “copy-paste-works”-type lines from year x. I’m not a specialist about this kind of topics.
Thanks about links! Mounting by using gvfs was the solution to my problem.
Thanks about help for you, also!
