Ok! I shall change the file to executable and the two other changes as quick as I can and I should be able to report the results till the end of the week.
Thank you for your kind help!
As I wrote Windows is installed on nvme0n1. And the inxi-command shows, that its scheme is MBR.
If that’s true, then naturally, the mistake is mine – with such a long and meandering thread, I hadn’t noticed that comment.
However, /dev/sda also indicated a Windows installation, with both a microsoft reserved and main ntfs partition present – thus the confusion – I didn’t immediately see in your inxi output that the NVMe had an ntfs filesystem. The NVMe certainly does have an MBR partitioning scheme.
/dev/sda, nonetheless, has a hybrid-MBR.
It seems to work. Windows booted without problems during the last days.
Thank you very much for your help!
