DTV as monitor user got stuck at shutdown if DTV turned off before shutdown process completed
Hello everyone I encountered a bug where manjaro stuck at shut down process and PC not turned off. I use DTV as PC monitor here. Everytime i turned off my DTV before PC shut down completely, my PC got stuck and won’t shut down. Is there a way to check for error log or something to know which error make my PC won’t shut down? If i didn’t turned off my DTV before PC shut down completely my PC can shut down without any problem.
journalctl -b -r
Will be the log from the last boot in reverse order. You can scroll down with pgdown key.
An obvious workaround is to not shut down your DTV before shutting down.
As @Teo suggests, logs might be useful.
Please also provide your system information as described (below) to help others identify any contributors.
Waiting for others to blindly ask questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
Thank you so much. I’ll try it if i encountered the problem again. It seems random but i have encountered 3 times before. I’ll try to reproduce the problem again and check it’s log. Thanks for your help
Thanks for the How to link. It helps noobs like me a lot. I’ll try to post the error if i can reproduce it again. It seems randomly happened because when i try it again just now my PC can shut down completely
Finally i can reproduce the problem
Here’s the output of journalctl
    ~  journalctl -b -r --boot=-1         INT ✘  2m 5s 
Oct 19 23:35:22 BonBonPC systemd[1]: Deactivating swap /swap/swapfile...
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped target Swaps.
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounted /tmp.
Oct 19 23:35:22 BonBonPC systemd[1]: tmp.mount: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Failed unmounting /var/cache.
Oct 19 23:35:22 BonBonPC systemd[1]: var-cache.mount: Mount process exited, code=exited, status=32/n/a
Oct 19 23:35:22 BonBonPC umount[8982]: umount: /var/cache: target is busy.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopping Flush Journal to Persistent Storage...
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounting /var/cache...
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounting /tmp...
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounting /mnt/SSD2TB...
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounting /mnt/HDD1TB...
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounting /home...
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounting /boot/efi...
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped target Local File Systems.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped Create System Files and Directories.
Oct 19 23:35:22 BonBonPC systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Oct 19 23:35:22 BonBonPC systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped Network Time Synchronization.
Oct 19 23:35:22 BonBonPC systemd[1]: systemd-timesyncd.service: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: proc-sys-fs-binfmt_misc.mount: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Starting Virtual Console Setup...
Oct 19 23:35:22 BonBonPC systemd[1]: Stopping Virtual Console Setup...
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped Virtual Console Setup.
Oct 19 23:35:22 BonBonPC systemd[1]: systemd-vconsole-setup.service: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Oct 19 23:35:22 BonBonPC systemd[1]: Stopping Network Time Synchronization...
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped Load Kernel Modules.
Oct 19 23:35:22 BonBonPC systemd[1]: systemd-modules-load.service: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Closed Process Core Dump Socket.
Oct 19 23:35:22 BonBonPC systemd[1]: systemd-coredump.socket: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped Apply Kernel Variables.
Oct 19 23:35:22 BonBonPC systemd[1]: systemd-sysctl.service: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped target Local Verity Protected Volumes.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped target Local Integrity Protected Volumes.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Oct 19 23:35:22 BonBonPC systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped target Local Encrypted Volumes.
Oct 19 23:35:22 BonBonPC systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Oct 19 23:35:22 BonBonPC systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped target System Initialization.
Oct 19 23:35:22 BonBonPC systemd[1]: Closed D-Bus System Message Bus Socket.
Oct 19 23:35:22 BonBonPC systemd[1]: dbus.socket: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped D-Bus System Message Bus.
Oct 19 23:35:22 BonBonPC systemd[1]: dbus-broker.service: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopping D-Bus System Message Bus...
Oct 19 23:35:22 BonBonPC dbus-broker[760]: Dispatched 22114 messages @ 3(±3)μs / message.
Oct 19 23:35:22 BonBonPC systemd[1]: Closed Disk Image Download Service Socket.
Oct 19 23:35:22 BonBonPC systemd[1]: systemd-importd.socket: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Closed Hostname Service Socket.
Oct 19 23:35:22 BonBonPC systemd[1]: systemd-hostnamed.socket: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Closed OpenSSH Server Socket (systemd-ssh-generator, AF_UNIX Local).
Oct 19 23:35:22 BonBonPC systemd[1]: sshd-unix-local.socket: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Removed slice Slice /system/keyboxd.
Oct 19 23:35:22 BonBonPC systemd[1]: Closed GnuPG public key management service for /etc/pacman.d/gnupg.
Oct 19 23:35:22 BonBonPC systemd[1]: keyboxd@etc-pacman.d-gnupg.socket: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Removed slice Slice /system/gpg-agent.
Oct 19 23:35:22 BonBonPC systemd[1]: Closed GnuPG cryptographic agent and passphrase cache for /etc/pacman.d/gnupg.
Oct 19 23:35:22 BonBonPC systemd[1]: gpg-agent@etc-pacman.d-gnupg.socket: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Removed slice Slice /system/gpg-agent-ssh.
Oct 19 23:35:22 BonBonPC systemd[1]: Closed GnuPG cryptographic agent (ssh-agent emulation) for /etc/pacman.d/gnupg.
Oct 19 23:35:22 BonBonPC systemd[1]: gpg-agent-ssh@etc-pacman.d-gnupg.socket: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Removed slice Slice /system/gpg-agent-extra.
Oct 19 23:35:22 BonBonPC systemd[1]: Closed GnuPG cryptographic agent and passphrase cache (restricted) for /etc/pacman.d/gnupg.
Oct 19 23:35:22 BonBonPC systemd[1]: gpg-agent-extra@etc-pacman.d-gnupg.socket: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Removed slice Slice /system/gpg-agent-browser.
Oct 19 23:35:22 BonBonPC systemd[1]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers) for /etc/pacman.d/gnupg.
Oct 19 23:35:22 BonBonPC systemd[1]: gpg-agent-browser@etc-pacman.d-gnupg.socket: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Removed slice Slice /system/dirmngr.
Oct 19 23:35:22 BonBonPC systemd[1]: Closed GnuPG network certificate management daemon for /etc/pacman.d/gnupg.
Oct 19 23:35:22 BonBonPC systemd[1]: dirmngr@etc-pacman.d-gnupg.socket: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Closed CUPS Scheduler.
Oct 19 23:35:22 BonBonPC systemd[1]: cups.socket: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped target Socket Units.
Oct 19 23:35:22 BonBonPC systemd[1]: user.slice: Consumed 2h 9min 54.399s CPU time, 12.6G memory peak.
Oct 19 23:35:22 BonBonPC systemd[1]: Removed slice User and Session Slice.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped target Slice Units.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped CUPS Scheduler.
Oct 19 23:35:22 BonBonPC systemd[1]: cups.path: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped target Path Units.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped Forward Password Requests to Plymouth Directory Watch.
Oct 19 23:35:22 BonBonPC systemd[1]: systemd-ask-password-plymouth.path: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped target Basic System.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped Network Manager.
Oct 19 23:35:22 BonBonPC systemd[1]: NetworkManager.service: Deactivated successfully.
Oct 19 23:35:22 BonBonPC NetworkManager[761]: <info>  [1760891722.8642] exiting (success)
Oct 19 23:35:22 BonBonPC dbus-broker-launch[759]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped WPA supplicant.
Oct 19 23:35:22 BonBonPC systemd[1]: wpa_supplicant.service: Deactivated successfully.
Oct 19 23:35:22 BonBonPC NetworkManager[761]: <info>  [1760891722.8545] device (p2p-dev-wlp7s0): state change: disconnected -> unmanaged (reason 'unmanaged>
Oct 19 23:35:22 BonBonPC NetworkManager[761]: <info>  [1760891722.8539] manager: NetworkManager state is now DISCONNECTED
Oct 19 23:35:22 BonBonPC wpa_supplicant[874]: wlp7s0: CTRL-EVENT-TERMINATING
Oct 19 23:35:22 BonBonPC wpa_supplicant[874]: nl80211: deinit ifname=wlp7s0 disabled_11b_rates=0
Oct 19 23:35:22 BonBonPC wpa_supplicant[874]: wlp7s0: CTRL-EVENT-DSCP-POLICY clear_all
Oct 19 23:35:22 BonBonPC NetworkManager[761]: <info>  [1760891722.7595] dhcp6 (wlp7s0): state changed no lease
Oct 19 23:35:22 BonBonPC NetworkManager[761]: <info>  [1760891722.7595] dhcp6 (wlp7s0): activation: beginning transaction (timeout in 45 seconds)
Oct 19 23:35:22 BonBonPC NetworkManager[761]: <info>  [1760891722.7594] dhcp6 (wlp7s0): canceled DHCP transaction
Oct 19 23:35:22 BonBonPC NetworkManager[761]: <info>  [1760891722.7594] device (wlp7s0): state change: deactivating -> unmanaged (reason 'unmanaged-quittin>
Oct 19 23:35:22 BonBonPC NetworkManager[761]: <warn>  [1760891722.7594] dispatcher: (10) failed (after 0.001 sec): Could not activate remote peer 'org.free>
Oct 19 23:35:22 BonBonPC NetworkManager[761]: <info>  [1760891722.7575] manager: NetworkManager state is now DISCONNECTING
Oct 19 23:35:22 BonBonPC wpa_supplicant[874]: wlp7s0: CTRL-EVENT-DISCONNECTED bssid=50:d2:f5:09:3e:cf reason=3 locally_generated=1
Oct 19 23:35:22 BonBonPC NetworkManager[761]: <info>  [1760891722.7574] device (wlp7s0): state change: activated -> deactivating (reason 'unmanaged', manag>
Oct 19 23:35:22 BonBonPC wpa_supplicant[874]: nl80211: send_event_marker failed: Source based routing not supported
Oct 19 23:35:22 BonBonPC kernel: wlp7s0: deauthenticating from 50:d2:f5:09:3e:cf by local choice (Reason: 3=DEAUTH_LEAVING)
Oct 19 23:35:22 BonBonPC wpa_supplicant[874]: p2p-dev-wlp7s0: CTRL-EVENT-TERMINATING
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped target User and Group Name Lookups.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped User Login Management.
Oct 19 23:35:22 BonBonPC systemd[1]: systemd-logind.service: Deactivated successfully.
Oct 19 23:35:22 BonBonPC wpa_supplicant[874]: nl80211: deinit ifname=p2p-dev-wlp7s0 disabled_11b_rates=0
Oct 19 23:35:22 BonBonPC wpa_supplicant[874]: p2p-dev-wlp7s0: CTRL-EVENT-DSCP-POLICY clear_all
Oct 19 23:35:22 BonBonPC systemd[1]: Stopping WPA supplicant...
Oct 19 23:35:22 BonBonPC NetworkManager[761]: <info>  [1760891722.6596] caught SIGTERM, shutting down normally.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopping Network Manager...
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped Network Manager Wait Online.
Oct 19 23:35:22 BonBonPC systemd[1]: NetworkManager-wait-online.service: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped target Network.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped target Network is Online.
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounted /mnt/BonBonCloud/User.
Oct 19 23:35:22 BonBonPC systemd[1]: mnt-BonBonCloud-User.mount: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounted /mnt/BonBonCloud/Public.
Oct 19 23:35:22 BonBonPC systemd[1]: mnt-BonBonCloud-Public.mount: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounted /mnt/BonBonCloud/Liana.
Oct 19 23:35:22 BonBonPC systemd[1]: mnt-BonBonCloud-Liana.mount: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounted /mnt/BonBonCloud/BonBonCat.
Oct 19 23:35:22 BonBonPC systemd[1]: mnt-BonBonCloud-BonBonCat.mount: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopping User Login Management...
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounting /mnt/BonBonCloud/User...
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounting /mnt/BonBonCloud/Public...
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounting /mnt/BonBonCloud/Liana...
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounting /mnt/BonBonCloud/BonBonCat...
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped target Remote File Systems.
Oct 19 23:35:22 BonBonPC systemd[1]: user-1000.slice: Consumed 2h 9min 54.399s CPU time, 12.6G memory peak.
Oct 19 23:35:22 BonBonPC systemd[1]: Removed slice User Slice of UID 1000.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped User Runtime Directory /run/user/1000.
Oct 19 23:35:22 BonBonPC systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped Permit User Sessions.
Oct 19 23:35:22 BonBonPC systemd[1]: systemd-user-sessions.service: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Unmounted /run/user/1000.
Oct 19 23:35:22 BonBonPC systemd[1]: run-user-1000.mount: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopping User Runtime Directory /run/user/1000...
Oct 19 23:35:22 BonBonPC systemd[1]: Stopping Permit User Sessions...
Oct 19 23:35:22 BonBonPC systemd[1]: user@1000.service: Consumed 2h 9min 54.288s CPU time, 12.5G memory peak.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped User Manager for UID 1000.
Oct 19 23:35:22 BonBonPC systemd[1]: user@1000.service: Deactivated successfully.
Oct 19 23:35:22 BonBonPC systemd-logind[767]: Removed session 2.
Oct 19 23:35:22 BonBonPC (sd-pam)[983]: pam_unix(systemd-user:session): session closed for user bonboncat
Oct 19 23:35:22 BonBonPC systemd[981]: Reached target Exit the Session.
Oct 19 23:35:22 BonBonPC systemd[981]: Finished Exit the Session.
Oct 19 23:35:22 BonBonPC systemd[981]: Reached target Shutdown.
Oct 19 23:35:22 BonBonPC systemd[981]: app.slice: Consumed 1h 17min 48.769s CPU time, 11.5G memory peak.
Oct 19 23:35:22 BonBonPC systemd[981]: Removed slice User Application Slice.
Oct 19 23:35:22 BonBonPC systemd[981]: Closed D-Bus User Message Bus Socket.
Oct 19 23:35:22 BonBonPC systemd[981]: session.slice: Consumed 52min 797ms CPU time, 796.9M memory peak.
Oct 19 23:35:22 BonBonPC systemd[981]: Removed slice User Core Session Slice.
Oct 19 23:35:22 BonBonPC systemd[981]: Stopped D-Bus User Message Bus.
Oct 19 23:35:22 BonBonPC systemd[981]: Stopping D-Bus User Message Bus...
Oct 19 23:35:22 BonBonPC dbus-broker[1013]: Dispatched 20547 messages @ 3(±3)μs / message.
Oct 19 23:35:22 BonBonPC systemd[981]: Closed PipeWire Multimedia System Sockets.
Oct 19 23:35:22 BonBonPC systemd[981]: Closed PipeWire PulseAudio.
Oct 19 23:35:22 BonBonPC systemd[981]: Closed p11-kit server.
Oct 19 23:35:22 BonBonPC systemd[981]: Closed GnuPG public key management service.
Oct 19 23:35:22 BonBonPC systemd[981]: Closed GnuPG cryptographic agent and passphrase cache.
Oct 19 23:35:22 BonBonPC systemd[981]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Oct 19 23:35:22 BonBonPC systemd[981]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Oct 19 23:35:22 BonBonPC systemd[981]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Oct 19 23:35:22 BonBonPC systemd[981]: Closed GnuPG network certificate management daemon.
Oct 19 23:35:22 BonBonPC systemd[981]: Stopped target Timers.
Oct 19 23:35:22 BonBonPC systemd[981]: Stopped target Sockets.
Oct 19 23:35:22 BonBonPC systemd[981]: Stopped target Paths.
Oct 19 23:35:22 BonBonPC systemd[981]: Stopped target Basic System.
Oct 19 23:35:22 BonBonPC systemd[981]: plasma-kwin_wayland.service: Consumed 50min 13.620s CPU time, 299.7M memory peak.
Oct 19 23:35:22 BonBonPC systemd[981]: Stopped KDE Window Manager.
Oct 19 23:35:22 BonBonPC systemd[981]: Stopping KDE Window Manager...
Oct 19 23:35:22 BonBonPC systemd[981]: Stopped KDE Session Management Server.
Oct 19 23:35:22 BonBonPC systemd[981]: Stopping KDE Session Management Server...
Oct 19 23:35:22 BonBonPC systemd[981]: plasma-plasmashell.service: Consumed 16.309s CPU time, 302.3M memory peak.
Oct 19 23:35:22 BonBonPC systemd[981]: Stopped KDE Plasma Workspace.
Oct 19 23:35:22 BonBonPC systemd[1]: Finished Tell Plymouth To Jump To initramfs.
Oct 19 23:35:22 BonBonPC plasmashell[1257]:   wl_callback#252 still attached
Oct 19 23:35:22 BonBonPC plasmashell[1257]: warning: queue 0x561ed7b6c8e0 destroyed while proxies still attached:
Oct 19 23:35:22 BonBonPC plasmashell[1257]: org.kde.plasma.printmanager.libkcups: Failed to reconnect Invalid argument
Oct 19 23:35:22 BonBonPC plasmashell[1257]: org.kde.plasma.printmanager.libkcups: IPP_INTERNAL_ERROR: clearing cookies and reconnecting
Oct 19 23:35:22 BonBonPC plasmashell[1257]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:260: TypeError: >
Oct 19 23:35:22 BonBonPC systemd[1]: Starting Tell Plymouth To Jump To initramfs...
Oct 19 23:35:22 BonBonPC systemd[1]: Finished Generate shutdown-ramfs.
Oct 19 23:35:22 BonBonPC systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
Oct 19 23:35:22 BonBonPC mkinitcpio[8502]: ==> Build complete.
Oct 19 23:35:22 BonBonPC plasmashell[1257]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:130: TypeError: >
Oct 19 23:35:22 BonBonPC plasmashell[1257]: kpipewire_logging: PipeWire remote error:  -32 connection error
Oct 19 23:35:22 BonBonPC plasmashell[1257]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: Typ>
Oct 19 23:35:22 BonBonPC systemd[1]: Started Show Plymouth Power Off Screen.
Oct 19 23:35:22 BonBonPC mkinitcpio[8502]:   -> Running build hook: [plymouth-shutdown]
Oct 19 23:35:22 BonBonPC systemd[981]: Stopped KDE Daemon 6.
Oct 19 23:35:22 BonBonPC systemd[981]: app-steam\x2dnative@65bbc4d5592b40eeb793d0b965325df2.service: Consumed 59min 49.438s CPU time, 9G memory peak.
Oct 19 23:35:22 BonBonPC systemd[981]: Stopped Steam (Native).
Oct 19 23:35:22 BonBonPC systemd[981]: pipewire.service: Consumed 34.132s CPU time, 11.4M memory peak.
Oct 19 23:35:22 BonBonPC systemd[981]: Stopped PipeWire Multimedia Service.
Oct 19 23:35:22 BonBonPC systemd[981]: app-discord@93f681450788406b949b90aa867e551a.service: Consumed 1min 27.392s CPU time, 1.2G memory peak.
Oct 19 23:35:22 BonBonPC systemd[981]: Stopped Discord - Internet Messenger.
Oct 19 23:35:22 BonBonPC systemd[981]: app-discord@93f681450788406b949b90aa867e551a.service: Failed with result 'core-dump'.
Oct 19 23:35:22 BonBonPC systemd[981]: app-discord@93f681450788406b949b90aa867e551a.service: Main process exited, code=dumped, status=5/TRAP
Oct 19 23:35:22 BonBonPC systemd[981]: Stopping PipeWire Multimedia Service...
Oct 19 23:35:22 BonBonPC kwin_wayland[1026]: kwin_screencast: PipeWire remote error:  connection error
Oct 19 23:35:22 BonBonPC systemd[981]: wireplumber.service: Consumed 1.128s CPU time, 83.3M memory peak.
Oct 19 23:35:22 BonBonPC systemd[981]: Stopped Multimedia Service Session Manager.
Oct 19 23:35:22 BonBonPC systemd[1]: Stopped Bluetooth service.
Oct 19 23:35:22 BonBonPC systemd[1]: bluetooth.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Exit
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Stopping SDP server
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Battery Provider Manager destroyed
Oct 19 23:35:21 BonBonPC systemd[981]: Removed slice Slice /app/dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet.
Oct 19 23:35:21 BonBonPC systemd-coredump[8631]: Failed to send coredump datagram: Connection reset by peer
Oct 19 23:35:21 BonBonPC systemd-coredump[8631]: Process 2630 (steamwebhelper) of user 1000 terminated abnormally with signal 5/TRAP, processing...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service.
Oct 19 23:35:21 BonBonPC systemd-coredump[8632]: Process 6083 (Discord) of user 1000 terminated abnormally with signal 5/TRAP, processing...
Oct 19 23:35:21 BonBonPC discord[6083]: [6083:1019/233521.972109:FATAL:gpu_data_manager_impl_private.cc(420)] GPU process isn't usable. Goodbye.
Oct 19 23:35:21 BonBonPC discord[6083]: [6083:1019/233521.972098:ERROR:gpu_process_host.cc(947)] GPU process launch failed: error_code=1002
Oct 19 23:35:21 BonBonPC discord[6083]: [6083:1019/233521.971841:ERROR:gpu_process_host.cc(947)] GPU process launch failed: error_code=1002
Oct 19 23:35:21 BonBonPC discord[6083]: [6083:1019/233521.971152:ERROR:gpu_process_host.cc(947)] GPU process launch failed: error_code=1002
Oct 19 23:35:21 BonBonPC discord[6083]: [6083:1019/233521.970813:ERROR:gpu_process_host.cc(947)] GPU process launch failed: error_code=1002
Oct 19 23:35:21 BonBonPC discord[6083]: [6083:1019/233521.970559:ERROR:gpu_process_host.cc(947)] GPU process launch failed: error_code=1002
Oct 19 23:35:21 BonBonPC discord[6083]: [6083:1019/233521.970276:ERROR:gpu_process_host.cc(947)] GPU process launch failed: error_code=1002
Oct 19 23:35:21 BonBonPC discord[6083]: [6083:1019/233521.969945:ERROR:gpu_process_host.cc(947)] GPU process launch failed: error_code=1002
Oct 19 23:35:21 BonBonPC discord[6083]: [6083:1019/233521.969674:ERROR:gpu_process_host.cc(947)] GPU process launch failed: error_code=1002
Oct 19 23:35:21 BonBonPC discord[6083]: [6083:1019/233521.969350:ERROR:gpu_process_host.cc(947)] GPU process launch failed: error_code=1002
Oct 19 23:35:21 BonBonPC discord[6083]: [6083:1019/233521.968418:ERROR:zygote_communication_linux.cc(296)] Failed to send GetTerminationStatus message to z>
Oct 19 23:35:21 BonBonPC systemd[981]: Removed slice Slice /app/dbus-:1.2-org.kde.kdeconnect.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped dbus-:1.2-org.kde.kdeconnect@0.service.
Oct 19 23:35:21 BonBonPC discord[6083]: }
Oct 19 23:35:21 BonBonPC discord[6083]:   name: 'Audio Service'
Oct 19 23:35:21 BonBonPC discord[6083]:   serviceName: 'audio.mojom.AudioService',
Oct 19 23:35:21 BonBonPC discord[6083]:   exitCode: 15,
Oct 19 23:35:21 BonBonPC discord[6083]:   reason: 'killed',
Oct 19 23:35:21 BonBonPC discord[6083]:   type: 'Utility',
Oct 19 23:35:21 BonBonPC discord[6083]: blackbox: 10/19/2025, 11:35:21 PM GMT+7 15 ❌ child-process-gone {
Oct 19 23:35:21 BonBonPC discord[6083]: mainScreen.webContentsSend: mainWindow is null or destroyed
Oct 19 23:35:21 BonBonPC discord[6083]: child-process-gone! child: Utility (Audio Service) exitCode: 15
Oct 19 23:35:21 BonBonPC systemd[981]: Removed slice Slice /app/dbus-:1.2-org.kde.kwalletd6.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped dbus-:1.2-org.kde.kwalletd6@0.service.
Oct 19 23:35:21 BonBonPC systemd[981]: background.slice: Consumed 4.085s CPU time, 319.6M memory peak.
Oct 19 23:35:21 BonBonPC systemd[981]: Removed slice User Background Tasks Slice.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped KActivityManager Activity manager Service.
Oct 19 23:35:21 BonBonPC systemd[981]: Removed slice Slice /app/dbus-:1.19-org.a11y.atspi.Registry.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped dbus-:1.19-org.a11y.atspi.Registry@0.service.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping Multimedia Service Session Manager...
Oct 19 23:35:21 BonBonPC systemd[981]: Removed slice Slice /app/dbus-:1.2-org.kde.Shutdown.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped dbus-:1.2-org.kde.Shutdown@0.service.
Oct 19 23:35:21 BonBonPC systemd[981]: pipewire-pulse.service: Consumed 53.714s CPU time, 26.9M memory peak.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped PipeWire PulseAudio.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped User preferences database.
Oct 19 23:35:21 BonBonPC discord[6083]: blackbox: 10/19/2025, 11:35:21 PM GMT+7 14 window.close win2
Oct 19 23:35:21 BonBonPC mkinitcpio[8502]:   -> Running build hook: [sd-shutdown]
Oct 19 23:35:21 BonBonPC systemd[981]: app-firefox@9522708666ac451eb89b507c39b4e127.service: Consumed 16min 21.949s CPU time, 2G memory peak.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped Firefox - Web Browser.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping KDE Plasma Workspace...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping KDE Daemon 6...
Oct 19 23:35:21 BonBonPC kded6[1215]: org.kde.pulseaudio: No object for name "auto_null.monitor"
Oct 19 23:35:21 BonBonPC kded6[1215]: org.kde.pulseaudio: No object for name "auto_null"
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping KActivityManager Activity manager Service...
Oct 19 23:35:21 BonBonPC mkinitcpio[8502]: ==> Starting build: 'none'
Oct 19 23:35:21 BonBonPC kded6[1215]: org.kde.pulseaudio: context kaput
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping PipeWire PulseAudio...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping User preferences database...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping dbus-:1.2-org.kde.kwalletd6@0.service...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping dbus-:1.2-org.kde.kdeconnect@0.service...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping dbus-:1.2-org.kde.Shutdown@0.service...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping dbus-:1.19-org.a11y.atspi.Registry@0.service...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping Steam (Native)...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping Firefox - Web Browser...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping Discord - Internet Messenger...
Oct 19 23:35:21 BonBonPC discord[6083]: blackbox: 10/19/2025, 11:35:21 PM GMT+7 13 before-quit
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped target Session services which should run early before the graphical session is brought up.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped target KDE Plasma Workspace Core.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped target Current graphical user session.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped target Main User Target.
Oct 19 23:35:21 BonBonPC systemd[981]: Removed slice Slice /app/dbus-:1.2-org.kde.KSplash.
Oct 19 23:35:21 BonBonPC systemd[981]: Removed slice Slice /app/dbus-:1.2-org.freedesktop.Notifications.
Oct 19 23:35:21 BonBonPC systemd[1]: Received SIGRTMIN+20 from PID 8556 (plymouthd).
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Authorization Manager.
Oct 19 23:35:21 BonBonPC systemd[1]: polkit.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping Authorization Manager...
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Modem Manager.
Oct 19 23:35:21 BonBonPC systemd[1]: ModemManager.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC kernel: Console: switching to colour frame buffer device 160x45
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Terminate Plymouth Boot Screen.
Oct 19 23:35:21 BonBonPC systemd[1]: plymouth-quit.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Starting Show Plymouth Power Off Screen...
Oct 19 23:35:21 BonBonPC plasmashell[1257]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17:>
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped target System Time Set.
Oct 19 23:35:21 BonBonPC systemd[981]: plasma-powerdevil.service: Consumed 1.664s CPU time, 11.7M memory peak.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped Powerdevil.
Oct 19 23:35:21 BonBonPC systemd[1]: Removed slice CUPS Slice.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped Portal service.
Oct 19 23:35:21 BonBonPC systemd[981]: kde-baloo.service: Consumed 1.599s CPU time, 233.9M memory peak.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped Baloo File Indexer Daemon.
Oct 19 23:35:21 BonBonPC systemd[1]: udisks2.service: Consumed 2.211s CPU time, 9.4M memory peak.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Disk Manager.
Oct 19 23:35:21 BonBonPC systemd[1]: udisks2.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[981]: Activating special unit Exit the Session...
Oct 19 23:35:21 BonBonPC udisksd[1046]: udisks daemon version 2.10.2 exiting
Oct 19 23:35:21 BonBonPC kded6[1215]: org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Oct 19 23:35:21 BonBonPC kded6[1215]: org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Oct 19 23:35:21 BonBonPC kded6[1215]: org.kde.pulseaudio: No object for name "alsa_input.pci-0000_09_00.6.analog-stereo"
Oct 19 23:35:21 BonBonPC kded6[1215]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_01_00.1.hdmi-stereo-extra3"
Oct 19 23:35:21 BonBonPC systemd[1]: upower.service: Consumed 1.035s CPU time, 5.7M memory peak.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Daemon for power management.
Oct 19 23:35:21 BonBonPC systemd[1]: upower.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Command Scheduler.
Oct 19 23:35:21 BonBonPC systemd[1]: cronie.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped GnuPG network certificate management daemon for /etc/pacman.d/gnupg.
Oct 19 23:35:21 BonBonPC crond[953]: (CRON) INFO (Shutting down)
Oct 19 23:35:21 BonBonPC kernel: fbcon: Taking over console
Oct 19 23:35:21 BonBonPC systemd[1]: dirmngr@etc-pacman.d-gnupg.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped CUPS Scheduler.
Oct 19 23:35:21 BonBonPC systemd[1]: cups.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped DNSCrypt-proxy client.
Oct 19 23:35:21 BonBonPC systemd[1]: dnscrypt-proxy.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/faststream_duplex
Oct 19 23:35:21 BonBonPC kwin_wayland[1026]: kwin_wayland_drm: atomic commit failed: Permission denied
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Oct 19 23:35:21 BonBonPC systemd-logind[767]: Removed session 1.
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Oct 19 23:35:21 BonBonPC systemd[1]: sddm.service: Consumed 294ms CPU time, 262.9M memory peak.
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Simple Desktop Display Manager.
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Oct 19 23:35:21 BonBonPC systemd[1]: sddm.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/sbc
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Load/Save OS Random Seed.
Oct 19 23:35:21 BonBonPC dirmngr[7119]: dirmngr (GnuPG) 2.4.8 stopped
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSink/sbc
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/opus_g
Oct 19 23:35:21 BonBonPC systemd[1]: systemd-random-seed.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSink/opus_g
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Accounts Service.
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aac
Oct 19 23:35:21 BonBonPC systemd[1]: accounts-daemon.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSink/aac
Oct 19 23:35:21 BonBonPC NetworkManager[761]: <info>  [1760891721.8692] modem-manager: ModemManager no longer available
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping User Manager for UID 1000...
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSink/aptx
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Hold until boot process finishes up.
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/aptx_hd
Oct 19 23:35:21 BonBonPC systemd[1]: plymouth-quit-wait.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC dnscrypt-proxy[764]: [2025-10-19 23:35:21] [NOTICE] Stopped.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping DNSCrypt-proxy client...
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSink/aptx_hd
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping CUPS Scheduler...
Oct 19 23:35:21 BonBonPC ModemManager[858]: <msg> ModemManager is shut down
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Endpoint unregistered: sender=:1.35 path=/MediaEndpoint/A2DPSource/ldac
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping Command Scheduler...
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping Modem Manager...
Oct 19 23:35:21 BonBonPC ModemManager[858]: <msg> caught signal, shutting down...
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped target Login Prompts.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped target Multi-User System.
Oct 19 23:35:21 BonBonPC sddm[959]: Running display stop script  QList("/usr/share/sddm/scripts/Xstop")
Oct 19 23:35:21 BonBonPC sddm[959]: Display server stopped.
Oct 19 23:35:21 BonBonPC systemd-logind[767]: Session 1 logged out. Waiting for processes to exit.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Session 1 of User bonboncat.
Oct 19 23:35:21 BonBonPC systemd[1]: session-1.scope: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Save/Restore Sound Card State.
Oct 19 23:35:21 BonBonPC systemd[1]: alsa-restore.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Power Profiles daemon.
Oct 19 23:35:21 BonBonPC systemd[1]: power-profiles-daemon.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Oct 19 23:35:21 BonBonPC systemd[1]: rtkit-daemon.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping Daemon for power management...
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping Disk Manager...
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Load udev Rules from Credentials.
Oct 19 23:35:21 BonBonPC systemd[1]: systemd-udev-load-credentials.service: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping Load/Save OS Random Seed...
Oct 19 23:35:21 BonBonPC sddm[959]: Display server stopping...
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping Simple Desktop Display Manager...
Oct 19 23:35:21 BonBonPC sddm[959]: Signal received: SIGTERM
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping Power Profiles daemon...
Oct 19 23:35:21 BonBonPC systemd[1]: Starting Generate shutdown-ramfs...
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping GnuPG network certificate management daemon for /etc/pacman.d/gnupg...
Oct 19 23:35:21 BonBonPC bluetoothd[763]: Terminating
Oct 19 23:35:21 BonBonPC dirmngr[7119]: SIGTERM received - shutting down ...
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping Bluetooth service...
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping Save/Restore Sound Card State...
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping Accounts Service...
Oct 19 23:35:21 BonBonPC systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Oct 19 23:35:21 BonBonPC systemd[1]: systemd-rfkill.socket: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Closed LVM2 poll daemon socket.
Oct 19 23:35:21 BonBonPC systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped target Trusted Platform Module.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Oct 19 23:35:21 BonBonPC systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Daily verification of password and group files.
Oct 19 23:35:21 BonBonPC systemd[1]: shadow.timer: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Generate mirrorlist weekly.
Oct 19 23:35:21 BonBonPC systemd[1]: pamac-mirrorlist.timer: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Monthly clean packages cache.
Oct 19 23:35:21 BonBonPC systemd[1]: pamac-cleancache.timer: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Daily man-db regeneration.
Oct 19 23:35:21 BonBonPC systemd[1]: man-db.timer: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Daily rotation of log files.
Oct 19 23:35:21 BonBonPC systemd[1]: logrotate.timer: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Discard unused filesystem blocks once a week.
Oct 19 23:35:21 BonBonPC systemd[1]: fstrim.timer: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped Refresh existing PGP keys of archlinux-keyring regularly.
Oct 19 23:35:21 BonBonPC systemd[1]: archlinux-keyring-wkd-sync.timer: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped target Timer Units.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped target Sound Card.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped target Host and Network Name Lookups.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped target Graphical Interface.
Oct 19 23:35:21 BonBonPC sddm[959]: Auth: sddm-helper exited with 1
Oct 19 23:35:21 BonBonPC systemd[1]: Stopped target Bluetooth Support.
Oct 19 23:35:21 BonBonPC sddm[959]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Oct 19 23:35:21 BonBonPC sddm[959]: Auth: sddm-helper (--socket /tmp/sddm-auth-c9d0d523-23b4-47c6-bd35-cce746d89381 --id 1 --start /usr/lib/plasma-dbus-run>
Oct 19 23:35:21 BonBonPC systemd[1]: Removed slice Slice /system/modprobe.
Oct 19 23:35:21 BonBonPC systemd[1]: Removed slice Slice /system/getty.
Oct 19 23:35:21 BonBonPC systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 19 23:35:21 BonBonPC systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 19 23:35:21 BonBonPC systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 19 23:35:21 BonBonPC systemd[1]: Stopping Session 1 of User bonboncat...
Oct 19 23:35:21 BonBonPC sddm-helper[976]: Signal received: SIGTERM
Oct 19 23:35:21 BonBonPC systemd-logind[767]: System is powering down.
Oct 19 23:35:21 BonBonPC systemd-logind[767]: The system will power off now!
Oct 19 23:35:21 BonBonPC plasmashell[1257]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: Typ>
Oct 19 23:35:21 BonBonPC systemd[981]: app-org.kde.konsole@60612a9b0bdd49a9b6ad3ca59b839a66.service: Consumed 966ms CPU time, 230.7M memory peak.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped Virtual filesystem service.
Oct 19 23:35:21 BonBonPC systemd[981]: app-pamac\x2dtray\x2dplasma@autostart.service: Consumed 6.332s CPU time, 805.4M memory peak.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped Update Notifier Tray Icon.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped Geoclue Demo agent.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped Xdg Desktop Portal For KDE.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped KDE PolicyKit Authentication Agent.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped MSM Notifier.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped flatpak document portal service.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped sandboxed app permission store.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped KAccess.
Oct 19 23:35:21 BonBonPC polkitd[765]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.43, object path /org/kde/PolicyKit1/Authent>
Oct 19 23:35:21 BonBonPC kded6[1215]: Service  ":1.56" unregistered
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped Accessibility services bus.
Oct 19 23:35:21 BonBonPC systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping Baloo File Indexer Daemon...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping sandboxed app permission store...
Oct 19 23:35:21 BonBonPC systemd[1]: run-user-1000-gvfs.mount: Deactivated successfully.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping flatpak document portal service...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping Portal service...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping Xdg Desktop Portal For KDE...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping Powerdevil...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping KDE PolicyKit Authentication Agent...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping KAccess...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping Virtual filesystem service...
Oct 19 23:35:21 BonBonPC kded6[1215]: Service  ":1.58" unregistered
Oct 19 23:35:21 BonBonPC dbus-broker[1194]: Dispatched 384 messages @ 3(±3)μs / message.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping Accessibility services bus...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping Update Notifier Tray Icon...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping MSM Notifier...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopping Geoclue Demo agent...
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped target Startup of XDG autostart applications.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped target KDE Plasma Workspace.
Oct 19 23:35:21 BonBonPC systemd[981]: Stopped target plasma-workspace-wayland.target.
Oct 19 23:35:21 BonBonPC kded6[1215]: Service  ":1.66" unregistered
Oct 19 23:35:21 BonBonPC steam[1929]: [2025-10-19 23:35:21] Shutdown
Oct 19 23:35:18 BonBonPC systemd[981]: Started dbus-:1.2-org.kde.Shutdown@0.service.
Oct 19 23:35:18 BonBonPC systemd[981]: Created slice Slice /app/dbus-:1.2-org.kde.Shutdown.
Still confused which cause the problem
Here’s the list of yellow and red one
Oct 19 23:35:22 BonBonPC NetworkManager[761]: <warn>  [1760891722.7594] dispatcher: (10) failed (after 0.001 sec): Could not activate remo>
For now the quick fix is not to turn of my DTV before PC completely shut down
