I am trying to enable Hardware Acceleration. My goal is to set VDPAU driver set “nvidia”. I am following the Arch Wiki .
When I run $ grep -iE 'vdpau | dri driver' /var/log/Xorg.0.log
I can see that My VDPAU driver is set to va_gl . Which is for intel.
[ 9.047] (II) intel(0): [DRI2] DRI driver: i965
[ 9.047] (II) intel(0): [DRI2] VDPAU driver: va_gl
How ever I want to set VDPAU driver to nvidia. According to Arch Wiki to do that I have to add VDPAU_DRIVER=nvidia
in Environment variable. But I have no idea How to do that.
Also I have Hybrid system. So, NVIDIA PRIME is set to default. But Arch Wiki says I have to set Environment variable for Hybrid system to DRI_PRIME=1. Which I have no idea.
Can anyone help me?
mbod
21 August 2020 09:54
2
You do not have X11 running on nvidia but intel.
If X11 would run on nvidia it would automatically pick the nvidia vdpau driver.
ok. But My goal is to force it to set to nvidia. Arch wiki says I can do it by changing Environment variable. I have changed environment variable /etc/environment —> VDPAU_DRIVER = nvidia. After restarting it doesn’t work.
mbod
21 August 2020 10:28
4
But why if you do not have nvidia hardware? vdpau is hardware acceleration after all.
The wiki also says:
Although the video driver should automatically enable hardware video acceleration support for both VA-API and VDPAU, it may be needed to configure VA-API/VDPAU manually. Only continue to this section if you went through #Verification .
I would guess it needs the nvidia drivers.
I already have nvidia driver properly installed.
$ mhwd -li
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-440xx-prime 2019.10.25 false PCI
$ vdpauinfo
display: :0 screen: 0
API version: 1
Information string: OpenGL/VAAPI backend for VDPAU
Video surface:
name width height types
420 4096 4096 NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 NV24 YV24 P010 P016 Y_U_V_444_16
422 4096 4096 NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 NV24 YV24 P010 P016 Y_U_V_444_16
444 4096 4096 NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 NV24 YV24 P010 P016 Y_U_V_444_16
420_16 4096 4096 NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 NV24 YV24 P010 P016 Y_U_V_444_16
422_16 4096 4096 NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 NV24 YV24 P010 P016 Y_U_V_444_16
444_16 4096 4096 NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 NV24 YV24 P010 P016 Y_U_V_444_16
Decoder capabilities:
name level macbs width height
MPEG1 --- not supported ---
MPEG2_SIMPLE --- not supported ---
MPEG2_MAIN --- not supported ---
H264_BASELINE 51 16384 2048 2048
H264_MAIN 51 16384 2048 2048
H264_HIGH 51 16384 2048 2048
VC1_SIMPLE --- not supported ---
VC1_MAIN --- not supported ---
VC1_ADVANCED --- not supported ---
MPEG4_PART2_SP --- not supported ---
MPEG4_PART2_ASP --- not supported ---
DIVX4_QMOBILE --- not supported ---
DIVX4_MOBILE --- not supported ---
DIVX4_HOME_THEATER --- not supported ---
DIVX4_HD_1080P --- not supported ---
DIVX5_QMOBILE --- not supported ---
DIVX5_MOBILE --- not supported ---
DIVX5_HOME_THEATER --- not supported ---
DIVX5_HD_1080P --- not supported ---
H264_CONSTRAINED_BASELINE 51 16384 2048 2048
H264_EXTENDED --- not supported ---
H264_PROGRESSIVE_HIGH --- not supported ---
H264_CONSTRAINED_HIGH --- not supported ---
H264_HIGH_444_PREDICTIVE --- not supported ---
VP9_PROFILE_0 --- not supported ---
VP9_PROFILE_1 --- not supported ---
VP9_PROFILE_2 --- not supported ---
VP9_PROFILE_3 --- not supported ---
HEVC_MAIN --- not supported ---
HEVC_MAIN_10 --- not supported ---
HEVC_MAIN_STILL --- not supported ---
HEVC_MAIN_12 --- not supported ---
HEVC_MAIN_444 --- not supported ---
HEVC_MAIN_444_10 --- not supported ---
HEVC_MAIN_444_12 --- not supported ---
Output surface:
name width height nat types
B8G8R8A8 16384 16384 y
R8G8B8A8 16384 16384 y
R10G10B10A2 16384 16384 y
B10G10R10A2 16384 16384 y
A8 16384 16384 y
Bitmap surface:
name width height
A8 16384 16384
Video mixer:
feature name sup
DEINTERLACE_TEMPORAL -
DEINTERLACE_TEMPORAL_SPATIAL -
INVERSE_TELECINE -
NOISE_REDUCTION -
SHARPNESS -
LUMA_KEY -
HIGH QUALITY SCALING - L1 -
HIGH QUALITY SCALING - L2 -
HIGH QUALITY SCALING - L3 -
HIGH QUALITY SCALING - L4 -
HIGH QUALITY SCALING - L5 -
HIGH QUALITY SCALING - L6 -
HIGH QUALITY SCALING - L7 -
HIGH QUALITY SCALING - L8 -
HIGH QUALITY SCALING - L9 -
parameter name sup min max
VIDEO_SURFACE_WIDTH -
VIDEO_SURFACE_HEIGHT -
CHROMA_TYPE -
LAYERS -
attribute name sup min max
BACKGROUND_COLOR -
CSC_MATRIX -
NOISE_REDUCTION_LEVEL -
SHARPNESS_LEVEL -
LUMA_KEY_MIN_LUMA -
LUMA_KEY_MAX_LUMA -
corrupted size vs. prev_size in fastbins
Aborted (core dumped)
$ vainfo
vainfo: VA-API version: 1.8 (libva 2.8.0)
vainfo: Driver version: Intel i965 driver for Intel(R) Haswell Mobile - 2.4.1
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264MultiviewHigh : VAEntrypointVLD
VAProfileH264MultiviewHigh : VAEntrypointEncSlice
VAProfileH264StereoHigh : VAEntrypointVLD
VAProfileH264StereoHigh : VAEntrypointEncSlice
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
VAProfileJPEGBaseline : VAEntrypointVLD
mbod
21 August 2020 12:22
6
This info clearly shows that you only have intel which is only supporting vaapi.
You can not use nvidia vdpau driver because you do not have the hardware.
If you need to use the vdpau command set you could use the wrapper library libvdpau-va-gl which is basically " the VDPAU driver with VA-API/OpenGL backend".
cscs
21 August 2020 17:21
7
While checking something like vainfo, vdpauinfo, etc etc … make sure to preface with prime-run
to see how it works when you are using the nvidia. ex:
glxinfo | grep renderer
prime-run glxinfo | grep renderer
vainfo
prime-run vainfo
