Fresh installation of Dropbox on fresh installation of Manjaro.
Only one other linked device at my Basic Dropbox account.
Tried dozens of time to sign in, but keep landing at the dropbox page:
“Error Invalid URL. Please check your client for a new one.”
I have searched, can’t find any solutions. Lots out there about recent signature issues, but I don’t know how any of it translates to a solution here.
Kernel: 6.1.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=f68a5cbb-bff5-418d-8c87-c9f71954f1f0 rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Portable System: Dell product: Inspiron 3521 v: A12
serial: <superuser required> Chassis: type: 8 v: A12
Mobo: Dell model: 06RYX8 v: A02 serial: <superuser required>
UEFI-[Legacy]: Dell v: A12 date: 10/25/2013
ID-1: BAT1 charge: 12.9 Wh (88.4%) condition: 14.6/41.4 Wh (35.1%)
volts: 15.8 min: 14.8 model: SANYO DELL 4WY7C42E type: Unknown
serial: <filter> status: not charging
Info: model: Intel Core i3-3217U bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1048 high: 1800 min/max: 800/1800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1800 2: 798 3: 798 4: 798
bogomips: 14373
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: Realtek Integrated Webcam HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.4:5 chip-ID: 0bda:58c2
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31") monitors: <missing: xrandr>
Monitor-1: LVDS-1 model: AU Optronics 0x45ec built: 2011 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell 7
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
API: ALSA v: k6.1.41-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.75 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Dell Wireless 1704 802.11n
+ BT 4.0 driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:4365 class-ID: 0280
Device-1: Broadcom BCM43142 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.1:3 chip-ID: 0a5c:21d7
Local Storage: total: 223.57 GiB used: 13.82 GiB (6.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 041 scheme: MBR
ID-1: / raw-size: 223.57 GiB size: 219 GiB (97.96%) used: 13.82 GiB (6.3%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 200 Uptime: 15m wakeups: 1 Memory: total: 8 GiB
available: 7.65 GiB used: 2.08 GiB (27.2%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: 1140 pm: pacman pkgs: 1128 libs: 365 tools: pamac pm: flatpak
pkgs: 5 pm: snap pkgs: 7 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.28
