Tonight's update failing - installing nvidia-utils (515.76-1) breaks dependency 'nvidia-utils=515.65.01' required by lib32-nvidia-utils
I came home to 288 packages to update and when I try to do it I get an error.
sudo pacman -Syyuu         1 ✘  4s 
 core                                                165,6 KiB  2,13 MiB/s 00:00 [##############################################] 100%
 extra                                              1848,4 KiB  10,3 MiB/s 00:00 [##############################################] 100%
 community                                             7,4 MiB  10,8 MiB/s 00:01 [##############################################] 100%
 multilib                                            180,5 KiB  5,88 MiB/s 00:00 [##############################################] 100%
:: Replace at-spi2-atk with extra/at-spi2-core? [Y/n]
:: Replace atk with extra/at-spi2-core? [Y/n]
resolving dependencies...
:: installing nvidia-utils (515.76-1) breaks dependency 'nvidia-utils=515.65.01' required by lib32-nvidia-utils
uname -a         1 ✘
Linux puck 5.15.65-1-MANJARO #1 SMP PREEMPT Mon Sep 5 10:15:47 UTC 2022 x86_64 GNU/Linux
Any idea what can it be? I don’t recall doing anything dodgy with kernel or drivers.
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Try to switch mirror, resync database, and update.
sudo pacman-mirrors -c Global
sudo pacman -Syyu
I don’t know what sorcery was going on but apparently my updates are downloading now, all 366 of them, thanks!
You probably had a mirror not properly synced.
