I installed the dropbox client from AUR and it hangs when I try to run it. Output from the command line is below. I haven’t been running dropbox for about a year, but never had any problem with it before. I’ve tried installing/uninstalling several times and even tried installing using Flatpak. Get same results every time. Appreciate your help
> dropbox: locating interpreter
dropbox: logging to /tmp/dropbox-antifreeze-iYeQVC dropbox: initializing dropbox: initializing python 3.8.8 dropbox: setting program path '/opt/dropbox/dropbox' dropbox: setting python path '/opt/dropbox:/opt/dropbox/python-packages.zip' dropbox: python initialized dropbox: setting args dropbox: running dropbox dropbox: applying overrides dropbox: enabling allocator metrics dropbox: running command dropbox: load fq extension '/opt/dropbox/cryptography.hazmat.bindings._openssl.cpython-38-x86_64-linux-gnu.so' dropbox: load fq extension '/opt/dropbox/cryptography.hazmat.bindings._padding.cpython-38-x86_64-linux-gnu.so' dropbox: load fq extension '/opt/dropbox/psutil._psutil_linux.cpython-38-x86_64-linux-gnu.so' dropbox: load fq extension '/opt/dropbox/psutil._psutil_posix.cpython-38-x86_64-linux-gnu.so' dropbox: load fq extension '/opt/dropbox/apex._apex.cpython-38-x86_64-linux-gnu.so' dropbox: load fq extension '/opt/dropbox/tornado.speedups.cpython-38-x86_64-linux-gnu.so' dropbox: load fq extension '/opt/dropbox/wrapt._wrappers.cpython-38-x86_64-linux-gnu.so' dropbox: load fq extension '/opt/dropbox/PyQt5.QtWidgets.cpython-38-x86_64-linux-gnu.so' dropbox: load fq extension '/opt/dropbox/PyQt5.QtCore.cpython-38-x86_64-linux-gnu.so' dropbox: load fq extension '/opt/dropbox/PyQt5.QtGui.cpython-38-x86_64-linux-gnu.so' dropbox: load fq extension '/opt/dropbox/PyQt5.QtDBus.cpython-38-x86_64-linux-gnu.so'
