i tried to play NierAutomata with dGPU AMD but in the game it is showing only intel graphics card. I played it on steam
with intel GPU the game lags very much.
system:
Kernel: 5.4.105-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=f380e64d-d9e7-4163-8e41-4ee059ed3ab4 ro quiet apparmor=1
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A
serial: <filter> Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0D53F5 v: A00 serial: <filter> UEFI: Dell v: 2.13.0
date: 08/13/2020
ID-1: BAT0 charge: 12.9 Wh (87.8%) condition: 14.7/41.4 Wh (35.6%)
volts: 16.5 min: 14.8 model: SMP DELL VN3N047 type: Li-ion
serial: <filter> status: Charging
Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142)
stepping: 9 microcode: DE cache: L2: 3 MiB
bogomips: 21607
Speed: 800 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes,
SMT vulnerable
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 /
Radeon 520 Mobile]
vendor: Dell driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0
chip-ID: 1002:6660 class-ID: 0380
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0bda:5769 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: ati,intel,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.4.105-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: yes
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000
bus-ID: 02:00.0 chip-ID: 8086:3165 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8136
class-ID: 0200
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
v: 0.8 bus-ID: 1-8:5 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 931.51 GiB used: 127.8 GiB (13.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: SDM3
scheme: GPT
ID-1: / raw-size: 120 GiB size: 117.62 GiB (98.01%)
used: 10.53 GiB (9.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 811.01 GiB size: 797.28 GiB (98.31%)
used: 117.27 GiB (14.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 45.0 C mobo: 44.0 C gpu: radeon temp: 42.0 C
Fan Speeds (RPM): cpu: 0
Processes: 182 Uptime: 1h 48m wakeups: 1 Memory: 7.65 GiB
used: 2.77 GiB (36.2%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: pacman: 1318 lib: 410 flatpak: 0 Shell: Bash
v: 5.1.0 running-in: konsole inxi: 3.3.03
i have put DRI_PRIME=1 %command % in the steam launch option too.
with : DRI_PRIME=1 glxinfo | grep “OpenGL renderer”
i got :
OpenGL renderer string: AMD HAINAN (DRM 2.50.0, 5.4.105-1-MANJARO, LLVM 11.1.
0)
