i tried to play a video in firefox but it says drm is not enabled .
i am running manjaroo kde plasma with firefox on pi 4.
aarch64
does not have access to widevine, which is needed for DRM content.
What you can do is install chromium-docker
, which installs an armv7h Chromium in a docker container and install the widevine plugin into that.
actually i am new to this platform so kindly provide me instructions to install chromium-docker and further…
Open pamac aka Add/Remove software.
Search chromium-docker
Install it and wait for it to get installed.
Run chromium-docker
once installed.
If it fails to run then remove it and install it again.
the widevine’s library seems not to be updated. (amazon).
Votre navigateur web n'a pas de composant de gestion des droits numériques. Accédez à **chrome://components** et, sous **WidevineCdm** , cliquez sur **Rechercher des mises à jour** . Pour obtenir de l'aide, veuillez contacter le service client Amazon sur [www.primevideo.com/help](https: //www.primevideo.com/help) et indiquez le code d'erreur 7235
This is on which browser?
I have tested the new aur package aur/chromium-docker 78.0.3904.97-4.
Version 78.0.3904.97 (Official Build) Built on Ubuntu, running on Ubuntu 18.04 (32-bit). The problem with outdated widewine is since a few months. (I have just amazon to test)
Same issue with the community package, but at last I have sound with the aur package (pipewire). With the community package, I had no sound with pulseaudio or pipewire and the same widewine error .
Thanks for the update. I will look into it soon.
