It happens maybe once or twice a day when i am loading into games or downloading stuff. I installed manjaro with gnome and had this issue, after reinstalling it with kde it sadly did not disappear.
inxi -Fazy:
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b251fe3f-d88d-4680-99aa-6d60d0b5248c rw quiet
cryptdevice=UUID=55638b23-9718-4100-9f89-8519893000fa:luks-55638b23-9718-4100-9f89-8519893000fa
root=/dev/mapper/luks-55638b23-9718-4100-9f89-8519893000fa apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Desktop Mobo: ASRock model: A320M-DGS serial: <filter>
UEFI-[Legacy]: American Megatrends v: P5.10 date: 10/04/2018
Info: Quad Core model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64
type: MCP arch: Zen family: 17 (23) model-id: 11 (17) stepping: 0
microcode: 810100B cache: L2: 2 MiB
bogomips: 27959
Speed: 2662 MHz min/max: 1600/3500 MHz boost: enabled Core speeds (MHz):
1: 2662 2: 1583 3: 1978 4: 1409
disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Micro-Star MSI
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 10:00.0
chip-ID: 10de:1c03 class-ID: 0300
Screen-1: 0 s-res: 3600x1225 s-dpi: 98 s-size: 933x317mm (36.7x12.5")
s-diag: 985mm (38.8")
Monitor-1: DVI-D-0 res: 1680x1050 hz: 60 dpi: 99
size: 433x271mm (17.0x10.7") diag: 511mm (20.1")
Monitor-2: HDMI-0 res: 1920x1080 hz: 75 dpi: 102
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 10:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 38:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: C-Media USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6:3 chip-ID: 0d8c:0012
class-ID: 0300
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
vendor: ASRock driver: r8169 v: kernel port: e000 bus-ID: 25:00.0
IF: enp37s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 912.89 GiB used: 112.53 GiB (12.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500DM002-1BD142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: KC44 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: HyperX Fury 3D 480GB
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 5A scheme: MBR
ID-1: / raw-size: 447.13 GiB size: 439.02 GiB (98.19%)
used: 112.53 GiB (25.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-55638b23-9718-4100-9f89-8519893000fa
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 40 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 49%
Processes: 218 Uptime: 9m wakeups: 0 Memory: 7.7 GiB used: 2.28 GiB (29.6%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages:
pacman: 1443 lib: 465 flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.06
Apparently your system cannot handle the heavy load you are putting on it and is crashing. The looping sound before the kernel dies is quite typical. However, it does indicate a hardware problem, possibly triggered by the higher thermal load associated with whatever you’re doing. So try monitoring your various temperature sensors and see whether they are reaching critical levels just before the crash.
Another thing I notice from your inxi
output is that you’ve got an Nvidia GPU and that you’re using the proprietary driver. That makes it very hard to debug these things, because that driver is closed-source, and there are loads and loads of problems with Nvidia in GNU/Linux nowadays.
You could of course always try the GPL’d nouveau
driver instead, but unfortunately, if you’re a gamer then that’s out of the question. The nouveau
driver is good enough for some casual day-to-day use, but it sucks badly at doing fancy things like 3D acceleration.
On windows i did not have such issue, but after trying linux i absolutely don’t want to come back.
Guess i’ll just wait for a miracle for now.
If it’s due to thermal overloading, then maybe you can check whether the fans are still working properly ─ no dust or cat hair in the fans, etc. ─ and possibly, if the system allows for it, install an extra case fan.
Another possibility could be that your power supply is dying. Check if it’s still supplying enough current on each of its channels ─ have a professional test that for you, so that you don’t get electrocuted. And if you’re uncertain about the wall power, buy a cheap UPS; it will catch brownouts and will make sure your computer is always receiving the correct voltage.
Mea culpa ─ I forgot to actually mention the obvious, which is to try a different kernel . The 5.4 and 5.10 kernels are both LTS (“long-term support”) and are pretty stable.
You may need to rebuild the Nvidia driver for that, but if you have dkms
installed, then it should do that for you automatically at boot time ─ it’ll add a few seconds to your boot time, but only once.
Goxore:
bogomips: 27959
class-ID: 0403
class-ID: 0300
there many points that can explain
you have installed in fact in Legacy ( so only disks MBR ) , also version UEFI may be not up to date
you have mixed disks GPT & MBR
you have version Kernel 5.13.x EOL , you shold have installed 5.10 LTS & 5.14
Changing kernel didn’t work for me (but i will stick to 5.10 LTS anyway), cleaned my pc just in case, but after making swap file problem seems to have gone.
system
Closed
12 October 2021 03:24
9
