I have a mounted hard drive that I keep the majority of my files on for programming.
I noticed that some files suddenly couldn’t be deleted. Unsure why. After a restart, I noticed that my hard drive was no longer mounted in its location.
Instead of being mounted at /run/media/nick/HDD - it was now /run/media/nick/HDD1.
The old folder still exists, and all that is in it are those files that I couldn’t delete. It appears to be mounted as a tmpfs drive and is owned by root instead of my user. I’ve tried deleting those files as well as unmounting that drive, but after I restart, it comes back.
Is there anything I can do here short of re-creating the partition? The drive is NTFS as it’s shared by my Windows dual boot. However, I haven’t booted in to windows since the problem started happening.
It’s not a tmpfs. However /run is a tmpfs. Your drive is simply mounted to a directory that itself resides on the tmpfs.
I strongly suspect that you’ve got Windows Fast Boot on. This does not fully shut down the Windows filesystems, and as a result, it is possible that udisks2 now mounts the volume to another mountpoint, and with a different ownership and permissions, given that it may still remember the previous mount.
Either way, here’s my advice…
Turn off Windows Fast Boot.
Add the NTFS volume to /etc/fstab with a fixed mountpoint ─ e.g. to a directory that itself resides under your $HOME, given that they are personal files anyway.
Look into the pertinent man pages for the correct mount options…
Ah, I didn’t realize you could give it a permanent mount point. (Manjaro is my first linux distro!)
I’ve just been accessing it from the other default mount.
I suspect it is a corrupt file as well, so I’m running a chkdsk in windows to try and see if that’ll fix anything.
Afterwards, I’ll pursue the fstab (and I’ve also turned off fast boot!)
