my download speed is normal when I use my browser but when I use the terminal it slows down all the way to around 10kbps, idk if this will help but I use gnome
Open a terminal and try
sudo pacman-mirrors -f 5 && sudo pacman -Syyu
This updates the mirrors of the update repos.
Are you downloading the exact same file in the browser and terminal? Please give more information.
As others have eluded to above …
What does this mean?
Tools like curl
and ping
and anything you do in the terminal ?
…or do you just mean pacman/pamac/updates/mirrors ?
thanks this worked
Whenever you touch mirrors you must also execute a DB refresh afterwards.
Ex:
sudo pacman -Syyu
Please put the thread on solved.
Not a solve if someone follows your instructions and then pacman -S package
Your solution is incomplete.
Fix it and I will mark it for you
Ok, I have edited it.
