Downgrading ZFS from 2.0.3 to 2.0.0
I have problems with my ZFS crashing my system on a daily basis.
Someone suggested me to downgrade to 2.0.0 version of ZFS as supposedly there were a lot of write behaviour changes afterwards.
However I am not capabil of doing so.
if I try downgrading zfs-utils usign the “downgrade” tool I get this.
downgrade zfs-utils
Downgrading from A.L.A. is disabled on the stable branch. To override this behavior, set DOWNGRADE_FROM_ALA to 1 .
See https://archived-wiki.manjaro.org/index.php?title=Using_Downgrade  for more details.
Available packages:
-  1)  zfs-utils    0.8.5  2  x86_64  (local)
-  2)  zfs-utils    2.0.0  2  x86_64  (local)
-  3)  zfs-utils    2.0.1  1  x86_64  (local)
-  4)  zfs-utils    2.0.2  1  x86_64  (local)
+  5)  zfs-utils    2.0.3  1  x86_64  (local)
select a package by number: 2
loading packages...
warning: downgrading package zfs-utils (2.0.3-1 => 2.0.0-2)
resolving dependencies...
:: installing zfs-utils (2.0.0-2) breaks dependency 'zfs-utils=2.0.3' required by linux510-zfs
:: installing zfs-utils (2.0.0-2) breaks dependency 'zfs-utils=2.0.3' required by linux54-zfs
If I try to downgrade linux510-zfs I get the oposite.
Available packages:
-  1)  linux510-zfs    2.0.0  8  x86_64  (local)
-  2)  linux510-zfs    2.0.1  6  x86_64  (local)
   3)  linux510-zfs    2.0.2  3  x86_64  (local)
-  4)  linux510-zfs    2.0.2  5  x86_64  (local)
+  5)  linux510-zfs    2.0.3  4  x86_64  (local)
select a package by number: 1
loading packages...
warning: downgrading package linux510-zfs (2.0.3-4 => 2.0.0-8)
warning: cannot resolve "zfs-utils=2.0.0", a dependency of "linux510-zfs"
:: The following package cannot be upgraded due to unresolvable dependencies:
      linux510-zfs
:: Do you want to skip the above package for this upgrade? [y/N] ^C
Interrupt signal received
Can someone please help me with this?
You simply can’t as we upgrade constantly. Most likely if you want to use 2.0 of ZFS you may need to compile it yourself from the PKGBUILDs and use the dkms versions for the extramodules.
