Yes, and it is working when I launch it with -vgui
bedna
11 July 2023 18:59
23
Then, what is the problem? I don’t understand?
Is it that you have to change the shortcut? or type 5 extra characters?
I consider this solved then, or never really an error.
But the reason you probably need that option has to do with hardware acceleration (I think) so if you want to solve that, that is what you probably should look into,
Edit
Maybe these links could contain some info helpful to you
opened 10:03PM - 02 Jul 23 UTC
Distro Family: Fedora
Web Component
Since yesterday (1. July 2023), Steam hangs on start, unable to create a window … for itself ([new GUI problem?](https://github.com/ValveSoftware/steam-for-linux/issues/9780#issuecomment-1616939803)). It appears that `start.sh` is repeatedly trying to create a `steamwebhelper` that just crashes soon after spawning.
Update: Identified as a [CEF](https://en.wikipedia.org/wiki/Chromium_Embedded_Framework) (libcef.so) issue, it’s currently tracked by [NVIDIA](https://forums.developer.nvidia.com/t/535-54-03-driver-regression-with-steams-new-web-gui-530-works/258225/4) and looks like a *[workaround](https://store.steampowered.com/news/group/4397053/view/3666541770799548342)* is out in Steam Beta (see [changelog](https://store.steampowered.com/news/group/4397053/view/3694688633556720508)). *Should* be fixed by disabling "GPU-accelerated web rendering" and wiping GLCache, see [#9780 (comment)](https://github.com/ValveSoftware/steam-for-linux/issues/9780#issuecomment-1623489003).
<h3 id="op-sys">System Information</h3>
- Steam client version: 1.0.0.78 (1687386907)
- Distribution: Fedora 38 (Workstation)
- Opted into Steam client beta?: No
- Have you checked for system updates?: Yes
- Steam Logs: [steam-logs.tar.gz](https://github.com/ValveSoftware/steam-for-linux/files/11931423/steam-logs.tar.gz)
- GPU: NVIDIA GeForce GTX 1050 ([RPMFusion](https://rpmfusion.org/Howto/NVIDIA#Current_GeForce.2FQuadro.2FTesla) driver v535.54.03)
- DE: GNOME 44, X.Org 1.20.14 (no wayland)
<details>
<summary><code>$ dnf list installed "*steam*"</code></summary>
Installed Packages
steam.i686 1.0.0.78-1.fc38 @rpmfusion-nonfree-updates
steam-devices.i686 1.0.0.78-1.fc38 @rpmfusion-nonfree-steam
</details>
<details>
<summary><code>$ dnf list installed "*nvidia*"</code></summary>
Installed Packages
akmod-nvidia.x86_64 3:535.54.03-1.fc38 @rpmfusion-nonfree-nvidia-driver
kmod-nvidia-6.3.8-200.fc38.x86_64.x86_64 3:535.54.03-1.fc38 @@commandline
nvidia-persistenced.x86_64 3:535.54.03-1.fc38 @rpmfusion-nonfree-nvidia-driver
nvidia-settings.x86_64 3:535.54.03-1.fc38 @rpmfusion-nonfree-nvidia-driver
nvidia-vaapi-driver.x86_64 0.0.10-1.fc38 @rpmfusion-nonfree-nvidia-driver
xorg-x11-drv-nvidia.x86_64 3:535.54.03-2.fc38 @rpmfusion-nonfree-nvidia-driver
xorg-x11-drv-nvidia-cuda.x86_64 3:535.54.03-2.fc38 @rpmfusion-nonfree-nvidia-driver
xorg-x11-drv-nvidia-cuda-libs.x86_64 3:535.54.03-2.fc38 @rpmfusion-nonfree-nvidia-driver
xorg-x11-drv-nvidia-cuda-libs.i686 3:535.54.03-2.fc38 @rpmfusion-nonfree-nvidia-driver
xorg-x11-drv-nvidia-kmodsrc.x86_64 3:535.54.03-2.fc38 @rpmfusion-nonfree-nvidia-driver
xorg-x11-drv-nvidia-libs.i686 3:535.54.03-2.fc38 @rpmfusion-nonfree-nvidia-driver
xorg-x11-drv-nvidia-libs.x86_64 3:535.54.03-2.fc38 @rpmfusion-nonfree-nvidia-driver
xorg-x11-drv-nvidia-power.x86_64 3:535.54.03-2.fc38 @rpmfusion-nonfree-nvidia-driver
</details>
<details>
<summary><code>$ inxi -F</code></summary>
Host: ongn-zetaxi270 Kernel: 6.3.8-200.fc38.x86_64 arch: x86_64 bits: 64
Desktop: GNOME v: 44.2 Distro: Fedora release 38 (Thirty Eight)
Type: Desktop System: Gigabyte product: Z270X-Ultra Gaming v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z270X-Ultra Gaming-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F8
date: 10/27/2017
Info: quad core model: Intel Core i7-6700 bits: 64 type: MT MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 3724 min/max: 800/4000 cores: 1: 3870 2: 3400 3: 3400
4: 3885 5: 3820 6: 3801 7: 3737 8: 3884
Device-1: NVIDIA GP107 [GeForce GTX 1050] driver: nvidia v: 535.54.03
Display: x11 server: X.Org v: 1.20.14 with: Xwayland v: 22.1.9 driver: X:
loaded: nvidia unloaded: fbdev,modesetting,nouveau,vesa
gpu: nvidia,nvidia-nvswitch resolution: 1920x1080
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce GTX
1050/PCIe/SSE2
Device-1: Intel 200 Series PCH HD Audio driver: snd_hda_intel
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
Device-3: Trust GXT 258 Microphone
driver: hid-generic,snd-usb-audio,usbhid type: USB
API: ALSA v: k6.3.8-200.fc38.x86_64 status: kernel-api
Server-1: PipeWire v: 0.3.72 status: active
Device-1: Intel Ethernet I219-V driver: e1000e
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full
mac: 1c:1b:0d:97:f8:f7
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
type: USB
Local Storage: total: 2.69 TiB used: 1.61 TiB (59.8%)
ID-1: /dev/sda vendor: Samsung model: SSD 870 QVO 1TB size: 931.51 GiB
ID-2: /dev/sdb vendor: Western Digital model: WD1003FZEX-00K3CA0
ID-3: /dev/sdc vendor: SanDisk model: EMTEC X150 960GB size: 894.25 GiB
ID-1: / size: 145.01 GiB used: 72.64 GiB (50.1%) fs: ext4 dev: /dev/sda6
ID-2: /boot/efi size: 96 MiB used: 46.6 MiB (48.5%) fs: vfat
dev: /dev/sda2
ID-3: /home size: 191.45 GiB used: 122.63 GiB (64.1%) fs: ext4
dev: /dev/sda8
ID-1: swap-1 type: zram size: 8 GiB used: 0 KiB (0.0%) dev: /dev/zram0
ID-2: swap-2 type: partition size: 4.66 GiB used: 0 KiB (0.0%)
dev: /dev/sda7
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Processes: 367 Uptime: 13m Memory: available: 15.56 GiB
used: 4.28 GiB (27.5%) Shell: Zsh inxi: 3.3.27
</details>
<h3 id="op-desc">Description</h3>
When I try to start Steam either from the terminal or from the application launcher, the process just hangs and doesn't open the Steam client (has to be killed using `kill` or just `killall steam`).
The issue started appeared one day ago–Steam was working perfectly fine before that. I made no changes to the system, settings or anything in that time (auto-update might have happened though).
Executing `steam` in the terminal didn't print any errors or any lines that would differ from a successful launch. After "RegisterForAppOverview", it appears that `steamwebhelper` was repeatedly executed:
```text
steamwebhelper.sh[330664]: Runtime for steamwebhelper: defaulting to /home/onegen/.steam/debian-installation/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[330664]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
The longer I let it run, the more `steamwebhelper`s were spawned (seen in `htop` and `ps aux | grep 'steam'`, no window ever appeared. At this point, the program didn't respond to even SIGINTs and had to be forcibly killed.
By some miracle, I was able to start Steam in offline mode (`steam -offline`) once after running `steam --reset`. Games, incl. online ones, ran as expected. But sadly, after I restarted the computer again, not even the offline option helped (I tried resetting again, no change).
<details>
<summary>Addendum: Running <code>steam -bigpicture</code> fails in a…<i>peculiar way</i> (video)</summary>
[Screencast from 2023-07-03 00-08-47.webm](https://github.com/ValveSoftware/steam-for-linux/assets/84882649/84987064-f1ae-499d-8bd2-37af1d181f91)
</details>
<h4 id="op-reprod">Steps for reproducing this issue:</h4>
1. <span title="wow, really?">Run Steam</span>
<h4 id="op-attempts">What I tried so far:</h4>
- `steam -offline`
- `steam --reset`
- `steam --flushconfig`
- `steam -cef-disable-gpu`
- `steam -bigpicture`
- `DRI_PRIME=0 steam`
- Resetting the network & wiping the DNS cache
- Reinstalling CUDA
- Reinstalling VDPAU/VAAPI
- `dnf downgrade steam`
- `dnf reinstall steam`
- `dnf remove steam && dnf install steam`
- `rm -rf ~/.cache/nvidia/GLCache`
- `rm -rf ~/.steam/ ~/.steampath ~/.steampid`
- `rm -rf ~/.local/share/Steam/` (worked for a time, see [#9780 (comment)](https://github.com/ValveSoftware/steam-for-linux/issues/9780#issuecomment-1618175467))
- `steam -vgui` (works to a limited extent, see [#9780 (comment)](https://github.com/ValveSoftware/steam-for-linux/issues/9780#issuecomment-1616939803))
opened 01:42PM - 26 Jun 23 UTC
closed 06:49AM - 04 Jul 23 UTC
Steam client
Distro Family: Gentoo
#### Your system information
* Steam client version (build number or date): 1… 687386907
* Distribution (e.g. Ubuntu): Gentoo 1.0.0.76
* Opted into Steam client beta?: No
* Have you checked for system updates?: Yes
* Steam Logs:
[steam-logs.tar.gz](https://github.com/ValveSoftware/steam-for-linux/files/11869786/steam-logs.tar.gz)
* GPU: AMD
#### Please describe your issue in as much detail as possible:
When I tried running steam normally, its stuck on the loading screen to login to steam. Later on I tried steam --reset and checked what it displayed and here's what it says:
"Could not connect to X session manager: Authentication Rejected, reason : None of the authentication protocols specified are supported and h" I assume this is what's causing the issue but unsure.
#### Steps for reproducing this issue:
1. Start steam
(I'm still rather new to github so if there is any formatting issues, i apologize.)
Seems to be a few things to test for you in there
The problem is that before the system update Steam was working without errors (I mean the one with the new interface). Steam does not start properly after the update and the only way to start it is to run with the -vgui argument. In this launch, the friends windows no longer work. The arch wiki says this is probably due to a bug in the newer nvidia drivers, which is possible because I updated them so thought I’d ask how to downgrade those drivers. I saw posts on the manjaro forum about downgrading drivers but didn’t understand them.
bedna
11 July 2023 19:31
25
Yeah, as I stated earlier, and mentioned a bunch of times in the links I posted, it has to do with hardware acceleration.
I highly discourage you to change your drivers, but you do what you want ofc.
If many people are affected by this, I suspect it will get solved pretty soon.
It’s an inconvenience you probably have to live with for a short while.
Ok, so I used fix from the GitHub reply you posted, and so far it works (this one: Steam does not start, steamwebhelper keeps crashing in a loop · Issue #9780 · ValveSoftware/steam-for-linux · GitHub ). I’ll use Steam for a while and see how it works, and report back if something goes wrong again. I also appreciate the help You both have provided.
bedna
11 July 2023 19:54
27
It would be highly appreciated if you could post the exact method you used (with commands and explanations) and then mark that as a solution so other pople who might find this thread can immediately find the solution.
Example:
This is how I solved it:
I used the explanation in LINK
Open terminal and type:
steam -vgui
Steam > Settings > Interface, then disable hardware accelerated web views
In terminal do:
steam --reset
Once steam launches, close it fully
In terminal:
sudo rm -r ~/.cache/nvidia/GLCache
Steam should now keep launching normally
ABOVE IS JUST AN EXAMPLE!
According to this github answer this is how the problem was solved for me (for now).
Open terminal and do steam -vgui
Go to Settings > Interface, then disable hardware accelerated web views and close steam (fully)
In terminal do steam --reset
In terminal do sudo rm -r ~/.cache/nvidia/GLCache
Steam should now launch normally
system
Closed
14 July 2023 10:17
29
