Hey guys I just wanted to report that there is problems with dash to dock 81 and made a issue report about it so I think it would be a good idea to downgrade it back to 80-1
opened 05:00PM - 16 May 23 UTC
Hey there I wanted to report a issue with dash to dock, I am unable to rearrange… the icons using dash to dock and the only way I was able to make it work was to set it to panel mode and also resizing icons doesn't not work unless it's set to panel mode. and have no idea why it's happening
I tried
dconf reset -f /org/gnome/shell/extensions/dash-to-dock/
But it is still broken.
[Screencast from 2023-05-17 02-58-17.webm](https://github.com/micheleg/dash-to-dock/assets/8393780/8964f0fd-6324-4719-b746-73dc1d29c645)
I am using Manjaro Gnome using the latest version 81 and tested both the extension package from Manjaros repo and from Gnome extensions and have the same issue.
