Downgrade Chromium - how?
The latest version broke something I need, how can I downgrade, pls?
Hello @qq88 :wink:
sudo downgrade --ala-only chromium
install downgrade before: pamac install downgrade
cheers
Am I doing it wrong?
[qq88@qq88-pc ~]$ sudo downgrade --ala-only chromium
[sudo] password for qq88:
sudo: downgrade: command not found
do sudo pacman -S downgrade
and then sudo downgrade --ala-only chromium
Stellar! Thank you!
