Hi,
I have a fresh installation of Windows 10 (updated to Win11). The clean installation creates a 100 MB UEFI partition. Once installed, I choose to install Manjaro. At installation time claims it needs at least 200 MB in the UEFI partition, so I decided to increase the UEFI partition (copy to another partition, delete and create a new partition). Then I have installed Manjaro. The problem it seems Manjaro has formatted the UEFI partition and it only shows Manjaro folder.
sudo ls -l /boot/efi/EFI
drwx------ 2 root root 4096 8 de gen. 17:44 boot
drwx------ 2 root root 4096 8 de gen. 17:44 Manjaro
Should I reinstall Windows in order to recover the UEFI Windows?
I have another question… since I have 2 HDD and I have to choose manually partition. Should I check the /boot/grub (I think it was this path) in the / partition?
