Double menu bar in LibreOffice
kde
libreoffice
#1
this appeared after updating libre office I am 100% sure there is no double menu in KDE plasm panel
#2
Known issue: [Testing Update] 2019-02-10 - KDE Apps, Gambas, Qt5, VirtualBox, LibreOffice, Wine, Firefox
#3
i am on arch even after today’s updates issue is not resolved
#4
With which version of LO?
Bug report https://bugs.documentfoundation.org/show_bug.cgi?id=122287 made me think that it might be fixed in 6.2.0.2 (which might be different from the arch version 6.2.0-2).
Also according to https://bbs.archlinux.org/viewtopic.php?id=244116
the appimage might work. Did you try it?
According to the same post you could also try to build it (…) with --enable-kde5 --enable-qt5 as build options.
Cheers,
#5
i use software from repositories i am not fan/user of app images and i will try rebuilding with above build options.
#6
this looks ugly on my pc :face_vomiting:
#7
issue fixed in in recent update version LibreOffice (libreoffice-fresh) 6.2.0-3
