Dolphin: Menubar "no text" Items
Hi,
i am using Dolphin Version 21.04.3 with KDE Plasma.
In the Menubar i have the following items.
[ "No text", "No text", "No text", "No text", "No text", Settings, Help ]
How can I fix this bug?
This is most likely a theme issue - try switching to the Breath2 theme - check if it is solved.
I tested it with Breath2 and Breat2 2021 nothing changed.
When I hide the menubar and open it the burger menu, the item text will be displayed corretly.
@Dommmeee You can try by deleting (or just backing up) the dolphinrc file to see if it helps:
mv ~/.config/dolphinrc ~/.config/dolphinrc.bak
If it is of no use then revert back,
mv ~/.config/dolphinrc.bak ~/.config/dolphinrc
FIXED
With version 21.08.0 the bug it’s gone.
