❯ inxi -zv8
Kernel: 7.1.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-7.1-x86_64
root=UUID=dab0df92-b969-492b-96f7-dd98534f84c3 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.6.5 tk: Qt v: N/A info: frameworks v: 6.27.0
wm: kwin_wayland vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
Mobo: ASUSTeK model: TUF GAMING B650M-E WIFI v: Rev 1.xx
Firmware: UEFI vendor: American Megatrends v: 3040 date: 09/12/2024
System RAM: total: 64 GiB available: 62.43 GiB used: 8.43 GiB (13.5%)
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 32 GiB speed: spec: 4800 MT/s actual: 6000 MT/s
volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: G Skill Intl part-no: F5-6000J3040G32G serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 9 9950X bits: 64 type: MT MCP arch: Zen 5 gen: 5
level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
model-id: 0x44 (68) stepping: 0 microcode: 0xB404022
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1.2 MiB desc: d-16x48 KiB; i-16x32 KiB L2: 16 MiB
desc: 16x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2982 min/max: 624/5756 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2982 2: 2982 3: 2982
4: 2982 5: 2982 6: 2982 7: 2982 8: 2982 9: 2982 10: 2982 11: 2982 12: 2982
13: 2982 14: 2982 15: 2982 16: 2982 17: 2982 18: 2982 19: 2982 20: 2982
21: 2982 22: 2982 23: 2982 24: 2982 25: 2982 26: 2982 27: 2982 28: 2982
29: 2982 30: 2982 31: 2982 32: 2982 bogomips: 275199
apic arat avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext bus_lock_detect
cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy constant_tsc
cpb cppc cpuid cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke
osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdt_a rdtscp rep_good sep sha_ni skinit
smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm
svm_lock syscall tce topoext tsc tsc_adjust tsc_scale umip user_shstk
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vnmi
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
xtopology
Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Type: vmscape mitigation: IBPB on VMEXIT
Device-1: NVIDIA GB202 [GeForce RTX 5090] vendor: CardExpert driver: nvidia
v: 610.43.02 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-11) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 5 speed: 32 GT/s ports: active: DP-2,DP-3
empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2b85 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.23 with: Xwayland v: 24.1.12
compositor: kwin_wayland driver: X: loaded: nvidia
gpu: nv_platform,nvidia,nvidia-nvswitch d-rect: 6000x1440 display-ID: 0
Monitor-1: DP-2 pos: primary,left model: Idek Iiyama PL3480WQ
serial: <filter> built: 2024 res: mode: 3440x1440 hz: 60 scale: 100% (1)
dpi: 110 gamma: 1.2 chroma: red: x: 0.686 y: 0.302 green: x: 0.251
y: 0.655 blue: x: 0.149 y: 0.063 white: x: 0.314 y: 0.329
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: 3440x1440,
2560x1440, 2560x1080, 1720x1440, 1920x1200, 1920x1080, 1600x1200,
1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768,
800x600, 720x576, 720x480, 640x480
EDID-Warnings: 1: parse_edid: unhandled CEA mode 90 2: parse_edid:
unhandled CEA mode 91 3: parse_edid: unhandled CEA mode 92 4: parse_edid:
unhandled CEA mode 76 5: parse_edid: unhandled CEA mode 75 6: parse_edid:
unhandled CEA mode 69 7: parse_edid: unhandled CEA mode 68 8: parse_edid:
unhandled CEA mode 78 9: parse_edid: unknown tag 112
Monitor-2: DP-3 pos: right model: Idek Iiyama PL2760Q serial: <filter>
built: 2020 res: mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 109 gamma: 1.2
chroma: red: x: 0.647 y: 0.345 green: x: 0.314 y: 0.627 blue: x: 0.137
y: 0.043 white: x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: 2560x1440, 2048x1280, 1920x1200,
1920x1080, 1600x1200, 1680x1050, 1600x1000, 1600x900, 1280x1024,
1440x900, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 610.43.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 5090/PCIe/SSE2
memory: 31.1 GiB display-ID: :0.0
API: Vulkan v: 1.4.350 layers: 6 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 5090 driver: nvidia v: 610.43.02
device-ID: 10de:2b85 surfaces: N/A
Device-1: NVIDIA GB202 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 5 speed: 32 GT/s
bus-ID: 01:00.1 chip-ID: 10de:22e8 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: ASUSTeK
bus-ID: 0d:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: EDIFIER G2000
driver: hid-generic,snd-usb-audio,usb-storage,usbhid type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 2d99:a005
class-ID: 0300 serial: <filter>
API: ALSA v: k7.1.1-3-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.6 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
Device-2: MEDIATEK MT7902 802.11ax PCIe Wireless Network Adapter [Filogic
310] vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 14c3:7902 class-ID: 0280
IF: wlp9s0 state: down mac: <filter>
Device-1: Realtek Bluetooth 5.4 Radio driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 0bda:a728
Report: rfkill ID: hci2 rfk-id: 4 state: up address: see --recommends
Device-2: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 13d3:3596
Report: ID: hci1 rfk-id: 1 state: up address: N/A
Local Storage: total: 3.64 TiB used: 249.28 GiB (6.7%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 52.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 57.57 GiB (3.1%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:6 label: Manjaro
uuid: dab0df92-b969-492b-96f7-dd98534f84c3
ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 664 KiB (0.0%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:5 label: N/A uuid: 525A-E682
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 57.57 GiB (3.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:6
label: Manjaro uuid: dab0df92-b969-492b-96f7-dd98534f84c3
ID-4: /mnt/backup raw-size: 400 GiB size: 392.66 GiB (98.16%)
used: 34.66 GiB (8.8%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:3
label: Backup uuid: 71770cc1-5014-4cfc-82ce-875e74bc1347
ID-5: /mnt/zusatz raw-size: 1.33 TiB size: 1.31 TiB (98.35%)
used: 157.05 GiB (11.7%) fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:4
label: Zusatz uuid: 46346c90-0e62-4233-a650-ad3bdc83c78f
ID-6: /var/cache raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
ID-7: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-4:2 info: Realtek Bluetooth 5.4 Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:a728 class-ID: e001 serial: <filter>
Device-2: 1-6:3 info: IMC Networks Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 13d3:3596 class-ID: e001 serial: <filter>
Device-3: 1-7:4 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Device-4: 1-8:5 info: Holtek USB Keyboard type: keyboard,HID
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 50mA
chip-ID: 04d9:a061 class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
Device-1: 3-1:2 info: EDIFIER G2000 type: mass storage,audio,HID
driver: hid-generic,snd-usb-audio,usb-storage,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 400mA
chip-ID: 2d99:a005 class-ID: 0300 serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 5-2:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2822
Hub-7: 5-2.1:3 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
Device-1: 5-2.1.1:9 info: Samsung Galaxy series misc. (MTP mode)
type: still imaging,abstract (modem),CDC-data driver: cdc_acm,usbfs
interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04e8:6860 class-ID: 0a00 serial: <filter>
Device-2: 5-2.3:4 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
type: keyboard,HID,smart card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
chip-ID: 1050:0407 class-ID: 0b00
Device-3: 5-2.4:6 info: CHERRY Wireless Device type: keyboard,mouse,HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 046a:0118 class-ID: 0300
Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-9: 6-2:2 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0822
Hub-10: 6-2.1:3 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
Hub-11: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
System Temperatures: cpu: 66.5 C mobo: 52.0 C
Fan Speeds (rpm): N/A
Packages: 1345 pm: pacman pkgs: 1321 libs: 361 tools: pamac,yay pm: flatpak
pkgs: 24
1: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
2: https://manjaro.grena.ge/stable/$repo/$arch
3: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 566
1: cpu: 22.2% command: zsh pid: 1240898 mem: 9.42 MiB (0.0%)
2: cpu: 15.9% command: konsole pid: 1240885 mem: 376.1 MiB (0.5%)
3: cpu: 6.1% command: firefox pid: 19689 mem: 1258.6 MiB (1.9%)
4: cpu: 3.4% command: kwin_wayland pid: 1255 mem: 517.3 MiB (0.8%)
5: cpu: 3.1% command: baloo_file pid: 1254 mem: 937.3 MiB (1.4%)
Memory top: 5 of 566
1: mem: 1258.6 MiB (1.9%) command: firefox pid: 19689 cpu: 6.1%
2: mem: 937.3 MiB (1.4%) command: baloo_file pid: 1254 cpu: 3.1%
3: mem: 892.3 MiB (1.3%) command: plasmashell pid: 1361 cpu: 0.7%
4: mem: 723.1 MiB (1.1%) command: conky pid: 1952 cpu: 0.8%
5: mem: 698.3 MiB (1.0%) command: strawberry pid: 148112 cpu: 0.9%
Processes: 566 Power: uptime: 7h 27m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.9 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
tool: systemctl
Compilers: gcc: 16.1.1 Shell: Zsh v: 5.9.1 running-in: konsole
inxi: 3.3.40
I completely reinstalled the system yesterday, but the error is still occurring exactly the same way.
Even if I just navigate through directories that contain one or two empty subdirectories, Dolphin still slows down and then freezes.
However, there’s nothing visible in the processes that would be causing any CPU load.
I can’t find anything in the logs either…
