Hello, I’m having a minor issue I cannot fix, any help would be appreciated, fairly new to GNU/Linux, please be gentle
I tried to install Chia Blockchain (npm/electron failed for some reason) and then I started getting a debug log everytime I open Dolphin
0 info it worked if it ends with ok
1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'run', 'electron' ]
2 info using npm@6.14.13
3 info using node@v14.17.0
4 verbose run-script [ 'preelectron', 'electron', 'postelectron' ]
5 info lifecycle chia-blockchain@~preelectron: chia-blockchain@
6 info lifecycle chia-blockchain@~electron: chia-blockchain@
7 verbose lifecycle chia-blockchain@~electron: unsafe-perm in lifecycle true
8 verbose lifecycle chia-blockchain@~electron: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/user/chia-blockchain/chia-blockchain-gui/node_modules/.bin:/home/user/chia-blockchain/venv/bin:/home/user/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin
9 verbose lifecycle chia-blockchain@~electron: CWD: /home/user/chia-blockchain/chia-blockchain-gui
10 silly lifecycle chia-blockchain@~electron: Args: [ '-c', 'electron .' ]
11 silly lifecycle chia-blockchain@~electron: Returned: code: 1 signal: null
12 info lifecycle chia-blockchain@~electron: Failed to exec electron script
13 verbose stack Error: chia-blockchain@ electron: `electron .`
13 verbose stack Exit status 1
13 verbose stack at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
13 verbose stack at EventEmitter.emit (events.js:376:20)
13 verbose stack at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
13 verbose stack at ChildProcess.emit (events.js:376:20)
13 verbose stack at maybeClose (internal/child_process.js:1055:16)
13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
14 verbose pkgid chia-blockchain@
15 verbose cwd /home/user/chia-blockchain/chia-blockchain-gui
16 verbose Linux 5.4.118-1-MANJARO
17 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "run" "electron"
18 verbose node v14.17.0
19 verbose npm v6.14.13
20 error code ELIFECYCLE
21 error errno 1
22 error chia-blockchain@ electron: `electron .`
22 error Exit status 1
23 error Failed at the chia-blockchain@ electron script.
23 error This is probably not a problem with npm. There is likely additional logging output above.
24 verbose exit [ 1, true ]
Dont know what it says and/or how to fix it.
any ideas/suggestions ?
Thank you.
